Dragen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Hey Agents, here is a consolidated video of all the info that Yannic, Hamish, and Kevin talked about during a podcast the held over the server maintenance period. Please excuse the mistakes below. I'm slapping this up quickly so I can jump on the beta. Huge thanks again to /u/Gorgathian for monitoring the stream and gathering info! 7 min reached capacity of what took 2 hours in Closed. 60% Americans joined at server start 3 or 4 servers crashed, and some players couldn't reconnect for * 30 or 40 minutes in order to capture your save. Sometimes it wouldn’t capture save and it would be in around 10 minutes of where you actually were. Why Scheduled maintenance? Fixing small issues that come up during the day. Just a reset in general to "clean up". Missed the third reason because I was typing the first two. Scheduled maintenance will occur once a week when the game launches. MIKE error is type of error, number designation tells the devs more specifics. Make sure to report the number if you make a report. They stressed to make sure to give feedback on the forums. Vote on the polls "Beta Intel" sectio on the forum site. Killing Cleaners is today’s daily assignment - Three tank weak point, ea hip and back Free Consumables in the Rewards vendor in the BoO 25% of players have more than 4 hours of gameplay. 6% have 8 hours 43% of players entered the DZ First 7 minutes reached capacity that the closed beta had. More than 60% of players in first day from America. Helped 2 million civies 22 million medkits used 107 top medkit user Daily assignment CIV - Helped 2 million civs They are sending rewards to the reward vendor for the top five people for helping the CIVs. Lenke til kommentar
GnilreG Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Deconstructe eller selge junk? Lenke til kommentar
Skulkesyk Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Deconstructe eller selge junk? selg det i betan siden du ikke kan crafte noka Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Hadde en nesten 5 timers økt på PC versjonen igår. Fortsatt gøy! Tok å spilte endel på PS4 versjonen også og jeg synes nesten grafikken har blitt litt bedre? Godt mulig det er bare oppe i hode mitt. Men fy for et pent spill. Lenke til kommentar
Nisirius Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Hadde en nesten 5 timers økt på PC versjonen igår. Fortsatt gøy! Tok å spilte endel på PS4 versjonen også og jeg synes nesten grafikken har blitt litt bedre? Godt mulig det er bare oppe i hode mitt. Men fy for et pent spill. Oh nydelig! Hvordan syns du det funker på PS4 ? Kanskje jeg skal laste det ned og teste betaen der mens jeg venter på nytt skjermkort Lenke til kommentar
Vakuum Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Husk å stille brightness i settings. Jeg dreit meg ut på det, og det har faktisk ganske mye å si. Hvis du har riktig brightness få føles ting mye mer "ekte" ut. Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Oh nydelig! Hvordan syns du det funker på PS4 ? Kanskje jeg skal laste det ned og teste betaen der mens jeg venter på nytt skjermkort Synes det fungerer veldig bra. Det er endel input lag i forhold til PC versjonen. Så det tar litt tid å bli vant til forskjellen. Ser ut som det hjelper endel om en stiller ned på sharpness i spillet. Men alt i alt så har jeg kost meg på både PC og PS4 versjonen. To opp! Lenke til kommentar
Akrabra Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Vet ikke hva jeg syntes om spillet enda. Spilte 3 timer igår kveld og jeg likte det egentlig veldig godt, men ble ikke fengslet. Skal hive meg på igjen ikveld og spille en del mer, så får vi se! Likte veldig godt våpenfølelsen, og det som er av RPG elementer. Syns heller ikke fiendene var noe særlig spongy som folk klagde på tidligere. Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Fienden er jo spongy pga det er et RPG spill. Virker som endel ikke skjønner hva det innebærer. Lenke til kommentar
Akrabra Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Fienden er jo spongy pga det er et RPG spill. Virker som endel ikke skjønner hva det innebærer. Jepp, og jeg liker det. Liker number crunching, det betyr at jeg kan gå hardt inn på theorycrafting osv. Skjønner at det ikke er for alle, men funker fint for meg. Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Jepp, og jeg liker det. Liker number crunching, det betyr at jeg kan gå hardt inn på theorycrafting osv. Skjønner at det ikke er for alle, men funker fint for meg. Enig. Det er det lille ekstra som er med på å løfter spillet. Om det hadde vært kun sikt og skyt så hadde det nok fort blitt veldig simpelt. Litt som Star Wars Battlefront egentlig. Det funker for noen men selv vil jeg ha litt mer kjøtt på beina Lenke til kommentar
.AN.XVIII.IV:. Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Noen som har funnet skin mods? Virker ut som det er umulig å finne... Lenke til kommentar
Gabri3L Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Jeg fant en på closed beta, men har ikke spilt så mye på open enda. Er det noe point i å gå opp på den tredje skill'en? Lenke til kommentar
Vakuum Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Hvordan ser denne videoen ut for dere? Tester ut å fikse brightness etter opptak. Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Ser bra ut det der. Men hva er det du har gjort? Juster lys styrke etter du har tatt det opp? Isåfall hvorfor? Lenke til kommentar
Vakuum Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Ser bra ut det der. Men hva er det du har gjort? Juster lys styrke etter du har tatt det opp? Isåfall hvorfor? Brightness-instillingen in-game blir ikke overført på screenshots og opptak i shadowplay. Så jeg må legge den på manuelt selv.. Lenke til kommentar
Vakuum Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Noen som har funnet skin mods? Virker ut som det er umulig å finne... Fikk en fra sivile. Ser jo helt klart mer bad ass ut nå. Lenke til kommentar
LarZen Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Ah I see. Ja der så du virkelig bad ass out Lenke til kommentar
Comma Chameleon Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 Fikk en turkis sprayboks til våpen forrige beta og en hvit en denne. Ikke noe superspesielt, men liker at man kan ha litt farger på våpnene. Kjører man alt svart og nøytralt så føler jeg at alt blir en stor grøt bare. Må skille seg litt ut i New York . Lenke til kommentar
Boss-Znakemaster Skrevet 20. februar 2016 Del Skrevet 20. februar 2016 (endret) Syns det var digg å se hvor skarpe texturene var i spillet til sammenligning med f.eks GTA5. Er virkelig ett godt steg opp. Drev å testet å sette ned innstillinger for å prøve å få spillet til å kjøre stabilt i 60 fps på 780n. Så textures på bildet er ikke på maks, men likevel var jeg meget overasket over hvor klar menyen på veggen i ene kaffesjappa var når jeg kom inn. Testet også betaen littegrann på Xbox One. Meget imponert over hvor pent det så ut til å være på konsoll. Correction: Testet å sette alt på low, finnes ikke texture options i betaen. Er kun skarpe textures som er mulige å bruke. Er spent å se om det finnes ett sett som er skarpere og eventuelt hvor mindre skarp de andre er. Eventuelt hvor mye fps som kan vinnes ved å f.eks kjøpe på medium textures. Endret 20. februar 2016 av Boss-Znakemaster Lenke til kommentar
