G Skrevet 25. januar 2016 Del Skrevet 25. januar 2016 (endret) Vil VMware måtte endre på hvordan de virtualiserer CPU'er? https://en.wikipedia.org/wiki/Kaby_Lake On January 15, 2016, Microsoft announced that Windows 10 will be the only supported Windows platform for Kaby Lake processors. Siden det tradisjonellt sett har vært slik inntil nå at gjeste-OS'et arver verts-OS'ets CPU. Man kan vel neppe kunne forvente at la oss si Windows 7 eller WinXP skal fungere i VMware på Kaby Lake, dersom VMware ikke gjør nye tilnærmelser på virtualisering. Altså må det tilbys en form for CPU-emulering da vel? Rykter: Other features include improved on-board graphics capabilities, including expanded resolution support up to 5K at 60Hz. However the slide seems erroneous in its discussion of refresh rates, suggesting it could be higher on dual displays than on one at that resolution. It may be referring to the use of two simultaneous DisplayPort connections to drive a single display, which is the connection method used by current 5K monitors.The new chips will also support Intel’s “Optane,” or NVMe technology, Thunderbolt 3 ports, and Intel’s Ready Mode and RealSense technologies.The new Intel 200 chipset will support both new-generation Kaby Lake-S CPUs and sixth generation Core processors from the current-gen. It will provide support for as many as 30 I/O lanes, 24 of which can be reserved for PCI Express 3.0 slots – for GPUs and other add-in cards – and the rest for SATA connectors.Along with native support for USB 3.1, the new chipset will support as many as 10 USB 3.0 ports, though it seems likely that not all boards will have that many.Read more: http://www.digitaltrends.com/computing/skylake-successor-kaby-lake-detailed-in-leaked-intel-slides/ Endret 25. januar 2016 av G Lenke til kommentar https://www.diskusjon.no/topic/1705059-vmware-sp%C3%B8rsm%C3%A5l-fremtidige-tiln%C3%A6rminger/
wsp Skrevet 21. mars 2016 Del Skrevet 21. mars 2016 Hvis man bruker EVC kan man presentere en annen CPU til gjesteVMene enn den som fysisk står i serveren. Grunnen til at man vanligvis bruker EVC er fordi man skal kunne flytte VMer i fart mellom hoster med ulik type CPU. Microsoft har imidlertidig utsatt datoen for dette til 2018 nå: http://www.theregister.co.uk/2016/03/19/microsoft_windows_skylake/ Lars Lenke til kommentar https://www.diskusjon.no/topic/1705059-vmware-sp%C3%B8rsm%C3%A5l-fremtidige-tiln%C3%A6rminger/#findComment-23149302
G Skrevet 21. mars 2016 Forfatter Del Skrevet 21. mars 2016 (endret) Takker så mye for det innspillet. Jeg er bare en amatør som ikke har server VM-innsikt nok. Men, det er jo lov som jeg å forsøke å tenke logisk, om at ting kunne ha vært et problem. For i VMware Workstation som jeg selv bruker, som ikke er så innrettet mot serverdelen, så blir man jo helst tilbudt en fastlåst CPU, som hermer vertsmaskinens CPU. Men, kanskje EVC kan benyttes selv her om hardware har råe nok muskler på PC/Server man forsøker oppsett i? Endret 21. mars 2016 av G Lenke til kommentar https://www.diskusjon.no/topic/1705059-vmware-sp%C3%B8rsm%C3%A5l-fremtidige-tiln%C3%A6rminger/#findComment-23149581
wsp Skrevet 19. april 2016 Del Skrevet 19. april 2016 For i VMware Workstation som jeg selv bruker, som ikke er så innrettet mot serverdelen, så blir man jo helst tilbudt en fastlåst CPU, som hermer vertsmaskinens CPU. Men, kanskje EVC kan benyttes selv her om hardware har råe nok muskler på PC/Server man forsøker oppsett i? Man får til det samme også med Workstation selv om det ikke er tilgjengelig i GUIet. Man kan redigere VMens konfigfil manuelt og sette opp cpu masking. Finnes flere eksempler i denne tråden: https://communities.vmware.com/thread/446660?start=0&tstart=0 Lars 1 Lenke til kommentar https://www.diskusjon.no/topic/1705059-vmware-sp%C3%B8rsm%C3%A5l-fremtidige-tiln%C3%A6rminger/#findComment-23200838
G Skrevet 19. april 2016 Forfatter Del Skrevet 19. april 2016 Hvordan reagerer Windows 10 på disse CPU-endringene da? Vil den oppfatte det som et CPU-bytte, vil lisensen bli ugyldiggjort? Gitt at man har forhåndsinnstallert Win10 på en annen virtuell CPU da. Lenke til kommentar https://www.diskusjon.no/topic/1705059-vmware-sp%C3%B8rsm%C3%A5l-fremtidige-tiln%C3%A6rminger/#findComment-23200855
