deve87 Skrevet 28. november 2015 Del Skrevet 28. november 2015 Audi MMI systemet støtter MP3 og det er kun via Windows vanlig dataCD brenning, som gjør CDn leslig for MMI. Brennes den via Nero 12 som vanlig dataCD(UDF), blir CDn uleselig. Begge CDene har MP3 filene på seg etter brenning. Virker ingen forskjell på dem når jeg prøver de i en PC etterpå. Regner med det er noe jeg må huke av eller noe sånt i Nero :-) Lenke til kommentar
Actibus Skrevet 28. november 2015 Del Skrevet 28. november 2015 (endret) Prøv disse innstillingene, oversatt med google translate fra tysk. http://www.motor-talk.de/forum/mmi-dvd-cd-wechsler-mp3-faehig-nur-iwe-brennen-t1643344.html Burn CD as multisession ( " CD Rom ISO " ) -- Settings: allow, under File Options "Mode 1 " , character set " ISO 9660 " , to Joliet , path depth and more than 255 characters UDF er vel i hovedsak for CD-RW og DVD? (ISO 9660 have been used as the main CD format for many years now. Most of the CD nowsdays still use this format, the benefit of this format is that it is readable by all CD drive or CD player, and can be shared between PC and MAC. Universal Disk Format (UDF) is a newer file system for CD and DVDdeveloped and managed by the Optical Storage Technology Association as the successor to the ISO 9660 standard. UDF overcomes limitations of ISO 9660 and redirectors such as CDFS. UDF is used to ensure compatibility across platforms, as well as among various CD and DVD applications. UDF is required for DVDs, and is used by DVD to contain MPEG audio/video streams, UDF is also used by CD-R and CD-RW in a process called packet writing that makes CD writing more efficient in terms of the time and disk space required. Endret 28. november 2015 av Actibus Lenke til kommentar
deve87 Skrevet 30. november 2015 Forfatter Del Skrevet 30. november 2015 Takk for svar. Det å velge ISO CD fungerte :-) Lenke til kommentar
