Bryn Skrevet 15. november 2003 Del Skrevet 15. november 2003 Hei. Jeg har kjøpt en Pentium4 2.60Ghz (200Mhz FSB) Northwood PC800 Passer ikke den cpu. på dette HKet: The IT7-MAX2 V2.0, a flagship motherboard, is part of the ABIT MAX Series products, and offers users a robust, High performance, next generation Pentium 4 platform for the Intel 845PE chipset, with 533MHz FSB, DDR333 and ABIT SoftMenu™ Technology. Overall System operation is enhanced with a peak 2.7 GB/s bandwidth. Moreover, it is highly integrated with the latest technologies: Serial ATA 150 and ATA133 IDE RAID technology give you higher performance and efficient data transfer rate. The expanded connectivity via USB 2.0, IEEE 1394, and ABIT Media XP multi function front panel (including S/P DIF Out and Card Reader function) gives users an easy way to connect to today’s hottest peripherals. On-board 10/100M LAN provides high-speed networking capability, and built-in 6-channel audio delivers a rich multimedia experience. IT7-MAX2 V2.0 looks to the feature, giving users an all-new experience of system quality and performance. Features: ATA 133 RAID 0/1/0+1 Supports the most advanced ATA133 HDDs with RAID 0/1/0+1, onboard HPT374 RAID controller enables enhanced functionality and HDDs performance without the cost of additional add-on cards ABIT SoftMenu™ Overclocking The overclocking function includes CPU frequency, multiplier, CPU Vcore and memory voltage adjustment available to maximize your system performance. USB 2.0 Supports 480 Mb/sec data transfer rate Support speed up to 480 Mb/s. Approximately forty times faster than conventional USB 1.1 IEEE 1394 Supports 400/200/100Mb/sec data transfer rate ABIT Media XP (Optional) ABIT's MAX series is the next evolution of the home PC! Compatible with the ABIT MAX Series Motherboard, Media XP provides the PC Industry the opportunity to deliver a flexible and cost reduced method of implementing audio, USB, IEEE1394, IR remote control and card readers widely used in today's PCs. Jeg får ikke mer enn 1300ghz ut av den. Eller kan jeg gjøre noe i bios? Takk for all hjelp Lenke til kommentar
Boralis Skrevet 15. november 2003 Del Skrevet 15. november 2003 Det kortet støtter vel ikke 800 mhz nei, det står jo også (med 533mhz) Lenke til kommentar
Bryn Skrevet 15. november 2003 Forfatter Del Skrevet 15. november 2003 Jeg ser at den har bare 533mhz , men kan jeg ikke kjøre den på cpu en på bare 533mhz da. Lenke til kommentar
ahpadt Skrevet 15. november 2003 Del Skrevet 15. november 2003 Jeg ser at den har bare 533mhz , men kan jeg ikke kjøre den på cpu en på bare 533mhz da. Det er standard settings på CPUEN. Det blir som å si at du vil ha en Ferrari til å gå i 400 når den egentlig ikke klarer med enn 300.. Lenke til kommentar
Bryn Skrevet 15. november 2003 Forfatter Del Skrevet 15. november 2003 ja, det betyr vel et nytt Hk det da. Jeg la ikke merke til at denne cpuen hadde 800mhz når jeg kjøpte den. Lenke til kommentar
C0bra Skrevet 15. november 2003 Del Skrevet 15. november 2003 Du kan jo prøve å sette fsb til 200.. men på eget ansvar.. Lenke til kommentar
FuglFøniks Skrevet 15. november 2003 Del Skrevet 15. november 2003 Jeg får ikke mer enn 1300ghz Ikke verst Lenke til kommentar
C0bra Skrevet 15. november 2003 Del Skrevet 15. november 2003 Jeg får ikke mer enn 1300ghz Ikke verst Hehe ikke så rent lite det nei.. Lenke til kommentar
Bryn Skrevet 15. november 2003 Forfatter Del Skrevet 15. november 2003 Du kan jo prøve å sette fsb til 200.. men på eget ansvar.. Har prøvd det, men det gikk ikke. Lenke til kommentar
z1nox Skrevet 16. november 2003 Del Skrevet 16. november 2003 Jeg får ikke mer enn 1300ghz ut av den. Eller kan jeg gjøre noe i bios? Takk for all hjelp å nå ble jeg misunnelig Lenke til kommentar
