Kjetil Lura Skrevet 16. april 2017 Rapporter Del Skrevet 16. april 2017 Hehe, takker for den. Men ja nok nå off topic Lenke til kommentar
Donkey Kong Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 (endret) Anmeldelser er ute. Gjennomgående er 580 noe raskere enn 480. http://www.tomshardware.com/reviews/amd-radeon-rx-580-review,5020-3.html Akkurat som forventet, med andre ord. Likevel fremstår 580 som god valuta for pengene hvis prisen tilsvarer 480. Det raskeste kortet i 2000-3000 kr-klassen. Endret 18. april 2017 av Donkey Kong Lenke til kommentar
Nizzen Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 580 er på lager i flere nettbutikker. Uten å være bias, så er det bedre å spare litt til for å kjøpe et gtx 1070 1 Lenke til kommentar
Lixxon Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Så man også spare enda mer igjen for en skjerm med gsync.. 2 Lenke til kommentar
HKS Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Fra AnandTech sin review: As for the competitive landscape then, AMD’s situation has improved, though I fear by not enough. Across the full spread of games in our benchmark suite, the RX 580 and GTX 1060 6GB change lead a few different times, so the RX 580 is able to best NVIDIA’s best in absolute performance in the right games. The problem for AMD is that those games appear to be too few; as a result the RX 580 trails the GTX 1060 by an average of 7% at both 1080p and 1440p. AMD has narrowed the gap somewhat – this was an 11% deficit with the RX 480 – but not by enough. And coupled with AMD’s worse power efficiency, this puts AMD in a tough spot. The biggest challenge right now is that GTX 1060 prices have come down to the same $229 spot just in time for the RX 500 series launch, so AMD doesn’t have a consistent price advantage. http://www.anandtech.com/show/11278/amd-radeon-rx-580-rx-570-review/17 Lenke til kommentar
RamGuy Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Så man også spare enda mer igjen for en skjerm med gsync.. Du må ikke ha skjerm med Gsync eller Free Sync.. Lenke til kommentar
The Jackal Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Er det kommet noen launchdato for vega enda egentlig? Lenke til kommentar
Malvado Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Tomshardware kom med en nøktern test av RX 580 8GB som ja er en rebrand men med høyere klokk og noen småpuss her og der : http://www.tomshardware.com/reviews/amd-radeon-rx-580-review,5020-9.html Får du tak i dette kortet til en billigere penge enn tilsvarende 1060 til Nvidia og har ikke råd for et 1070 så er det ikke et så ille kjøp, men vær obs på hvilke spill du spiller per dags dato og hva du kommer til å spille fremover. Personlig ser ting langt mer balansert ut ytelsemessig mellom Nvidia og Amd akkurat der ( 1060 6Gb vs 580 8GB ) så jeg personlig hadde nok kjøpt det kortet som passer best i forhold til lommeboka... Lenke til kommentar
Lixxon Skrevet 18. april 2017 Rapporter Del Skrevet 18. april 2017 Er det kommet noen launchdato for vega enda egentlig? Mai er blitt nevnt en del, men ingenting konkret Lenke til kommentar
ExcaliBuR Skrevet 19. april 2017 Forfatter Rapporter Del Skrevet 19. april 2017 (endret) Har tydeligvis vært en Q&A med Don Woligroski hos tom'sHardware Syntes svaret hans om et spørsmål om FreeSync var interessant: Vega performance compared to the Geforce GTX 1080 Ti and the Titan Xp looks really nice. Men, man må selvfølgelig ta det med en klype salt som det heter. I tillegg er Crimson 17.4.3 ute for de som først og fremst har hamstret 5x0: Radeon Software Crimson ReLive Edition 17.4.3 Highlights Support for Windows®10 Creators Update. Support for Radeon RX 580 Series Graphics. Support for Radeon RX 570 Series Graphics. Known Issues Radeon WattMan may fail to apply settings on some Radeon R9 390 series graphics products. Radeon Settings may crash on switching Windows® user after toggling AMD CrossFire™ technology mode. A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background. Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue. Known Issues for Radeon ReLive The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues. Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products. Radeon ReLive may intermittently fail to work after performing task switches of applications. A work around is to disable and then enable the feature in Radeon Software. Radeon ReLive may exhibit corruption in recordings when capturing Microsoft Office applications. Radeon ReLive may experience recording or streaming issues when task switching using ALT+TAB. Endret 19. april 2017 av ExcaliBuR Lenke til kommentar
leifeinar Skrevet 19. april 2017 Rapporter Del Skrevet 19. april 2017 ser hos Techpowerup at sapphire 580 drar 66 watt mere enn et gtx1080 som yter 50% bedre.... de fleste tall er tragiske bortsett fra pris. Lenke til kommentar
Nizzen Skrevet 19. april 2017 Rapporter Del Skrevet 19. april 2017 ser hos Techpowerup at sapphire 580 drar 66 watt mere enn et gtx1080 som yter 50% bedre.... de fleste tall er tragiske bortsett fra pris.XD Passer bra hvis det stemmer Lenke til kommentar
HKS Skrevet 19. april 2017 Rapporter Del Skrevet 19. april 2017 I og med at 500-serien kun er et "overklokka rebrand" så er det mulig å flashe ditt gamle RX 480-kort til RX 580. Ville dog vært forsiktig med dette hvis ikke jeg hadde en 3. part 480-kjøler. Første revisjon av 480 med kun 6-pin PCIe-strøm har svakheter i power-delivery. Merk at dette vil føre til økt effektbruk og økt varmeutvikling. https://videocardz.com/68696/amd-radeon-rx-480-can-be-flashed-to-rx-580 Lenke til kommentar
nagina Skrevet 20. april 2017 Rapporter Del Skrevet 20. april 2017 Når tror dere vi får nytt versjon av dette bildet, bare nå bytter man RX480 med RX580 Joda, man glemmer ikke slikt så enkelt, husker AMD folk skrytet med dette bildet ^^ Lenke til kommentar
Malvado Skrevet 20. april 2017 Rapporter Del Skrevet 20. april 2017 Noen småting : *Flashing av et 480 til 580 kort er ikke anbefalt, den originale pcb'en til 480 hadde jo problemer med strøm og varme og dette vil jo på ingen måte bli bedre når 580 kortet trekker opp mot 50 til 65W mer... *Man må også huske på at dette er Polaris 20 XLX som selv om det ikke er store endringer så ser man jo at det er langt flere eksemplarer som nå oppnår hastigheter som ved lansering av Polaris var relativt sjeldent, selv ved overklokk. *Pcb'en (Amd har ikke lansert sitt eget kort, det er partnerne som gjør det ) ser ut til å ha blitt forbedret hos alle og det er gjort mer nøkterne strømfordelinger nettopp for å unngå problemene man hadde med de første RX 480 kortene. Det som er spennende å se er at både Nvidia og Amd har økt ytelsen i DX12 spill og Amd faktisk også en del i DX11 spill, noe som gjør at ting er langt mer "jevnt" der. Men med en gang man ser på moderne titler som krever en del minne ser det ut som ytelsen faller mer hos Nvidia enn det gjør hos Amd på de eldre kortene med under 3Gb minne. Personlig mener jeg at Nvidia sitt 1060 6 Gb kort er et bra kort som gjør det bra, men Amd stiller også sterkt men trekker mer strøm, skal man i det hele tatt vurdere er det igjen viktig å se på hva man har å bruke i penger og hvilke spill man kommer til å spille, men siden sistenevnte nå er ganske jevnt vil jeg si at det må bli opp til lommeboka og preferanser. Lenke til kommentar
Quakecry Skrevet 20. april 2017 Rapporter Del Skrevet 20. april 2017 Har virkelig lyst å oppgradere 290X kortet mitt. Håper Vega blir det nye 290X! 1 Lenke til kommentar
Nizzen Skrevet 20. april 2017 Rapporter Del Skrevet 20. april 2017 Har virkelig lyst å oppgradere 290X kortet mitt. Håper Vega blir det nye 290X! Varmt og høyt strømforbruk? Nei takk! Ytelsen i sin tid var jo fin. Hadde 2 stk 290x Sapphire tri X, som jeg hadde EK vannblokker på etterhvert. Lenke til kommentar
Quakecry Skrevet 20. april 2017 Rapporter Del Skrevet 20. april 2017 Har virkelig lyst å oppgradere 290X kortet mitt. Håper Vega blir det nye 290X!Varmt og høyt strømforbruk? Nei takk! Ytelsen i sin tid var jo fin. Hadde 2 stk 290x Sapphire tri X, som jeg hadde EK vannblokker på etterhvert.Varmt, joda. Ligger på 78-82 grader. Men for en ytelse kortet har hatt over så lang tid. 2 Lenke til kommentar
Donkey Kong Skrevet 21. april 2017 Rapporter Del Skrevet 21. april 2017 (endret) 290x duger fortsatt til solid 1080p-gaming. Ikke gale for et snart 4 år gammelt kort. Selv har jeg refreshen 390x. Fikk det for 3500 kroner på Finn høsten 2015. Ja, kortet er varmt og det bråker litt, men har hatt veldig god ytelse for pengene. Er lenge til jeg må gi opp 1080p Ultra. Endret 21. april 2017 av Donkey Kong Lenke til kommentar
Vanderen Skrevet 21. april 2017 Rapporter Del Skrevet 21. april 2017 Vega vil ikke ha noe problemer med ytelsen til pascal! Det spennende er om Nvidia vil kontre Vega med pris/ytelse med volta! Lenke til kommentar
