AMD Polaris & Vega og midlertidig (?) Navi
ExcaliBuR
Gjest
AMD Crimson Edition 16.8.2 Hotfix
Fixed Issues
  • Overwatch™ may experience an application crash on some Radeon™ RX 480 configurations when using AMD Crossfire mode.
  • Vulkan™ information in the Radeon Settings software information tab may display an incorrect version.
  • Radeon WattMan may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot.
  • Hitman™ may experience graphical corruption when the game is set to use DirectX®12 API and using zoom with weapons.
  • Total War™: Warhammer may experience minor graphical corruption in some map textures on AMD Radeon R9 380.
  • Flickering may be observed in Rise of the Tomb Raider™ on some AMD Crossfire configurations using the DirectX®11 API.
  • Changing settings in Dragon Age Inquisition™ with the Mantle API may result in an application crash or driver recovery.
  • DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
  • Display may exhibit a minor flicker on Radeon RX 480 when Freesync is enabled on a games launch or exit.
  • Shadows may experience rendering issues in DOTA2™ when using the Vulkan™ API.
  • Textures may experience holes or gaps in DOOM™ when using the OpenGL API and three display AMD Eyefinity configurations.
  • Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
  • Performing a task switch with two cloned displays during full screen gaming may cause flickering on the extended display.
Known Issues
  • A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
  • DOTA2™ may experience an application hang when using the Vulkan™ API and changing resolution or game/quality settings.
  • DiRT™ Rally may experience rain drop flickering in some races when using AMD Crossfire mode.
  • Displays may fail to revert to previous configuration on exit when using a profiled application launched with Radeon Settings and “Launch with AMD Eyefinity” toggled on.
  • Assassin's Creed® Syndicate may experience a game crash or hang when in game settings are set to high or greater.
  • Low frame rate or stutter may be experienced Wolfenstein®: The Old Blood™ on Radeon™ RX 480.
  • Radeon RX 480 graphics may experience minor flickering in SteamVR benchmark when using AMD Crossfire mode.
  • Corruption may be experienced in Rise of the Tomb Raider using the DirectX®12 API on some Hybrid Graphics configurations when performing a task switch.
  • Shader Cache may remain be enabled when set to “off” in Radeon Settings on some Hybrid Graphics configurations.
  • Radeon RX 480 graphics may experience intermittent stuttering in The Division™ when high game settings are used and vsync is enabled.
  • Battlefield™ 4 may experience intermittent crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
  • Creating two or three display portrait Eyefinity groups in Radeon Settings “quick setup” and then clicking “arranging displays” may cause an error.
  • Radeon Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
  • World of Tanks™ may experience stuttering after performing a task switch in AMD Crossfire mode.
  • Rocket League™ may experience flickering when in AMD Crossfire mode.
  • DOTA2™ may experience lower than expected performance when in AMD Crossfire mode.
  • Ashes of the Singularity™ may experience an application crash with “crazy” in game settings and Multi-GPU enabled.
Endret av ExcaliBuR
Har et Nvidia 460 kort liggende om det skulle gå i dass. Da tester jeg :)
Så ikke ut til å fungere. Maskinen bootet ikke etter å ha flashet kortet. Fungerte å switche til den andre Bios'en på kortet for å få bootet maskinen igjen. Ser dårlig ut mtp å få til 8 gb på kortet da ser det ut til?
Forresten: Finnes det en måte å flashe den Biosen som ikke er i bruk på skjermkortet, eller må jeg sette i et til skjermkort og switche tilbake på Biosen for å flashe tilbake til orginal Bios?
Endret av hardkjerne
Har blitt bra der ja.
Har enda tilgode å oppleve trøbbel med driverne til FX systemet og R9 280 kortet mens jeg har allerede byttet Nvidia driver fra den siste som kom ut for en stund siden en som er litt mer stabil som ble lansert for 2 måneder siden.Mulig jeg er litt kravstor , men å få flimring i teksturer gidder jeg ikke selv om det var svært begrenset ( men på tven),
Begge systemene kjører på Windows 10.
Vanskelig å si hvorfor AMD nå kommer med Vega, men viser det seg at de mener at de kan slå de skjermkortene som Nvidia nå har tilgjengelig og Vega er klar for lansering så er det jo en god grunn til det.
Kommer de derimot med et kort som yter bedre men ikke like bra som toppkortene til Nvidia så må de ha en langt lavere pris for å kunne selge bra, da konkurrere de trolig med 1060 ( selv om de allerede klarer dette fint i DX12 med Polaris RX480 ) , og risikerer å kannabilisere sine tidligere kort om prisen er også lav.
Så personlig antar jeg at kortet må yte tilsvarende eller bedre enn 1070 og 1080...
Man må nesten smile litt av AMD sin PR-avdeling når det gjelder "lansering" av nye kort... :D
La oss se på Polaris:
November 2015 - Første hint på Twitter
Desember 2015 - Annonsering av Polaris
Janaur 2016 - Første demo
Mars 2016 - Nok en annonsering av arkitekturen
31. Mai 2016 - Produktannonsering
29. juni 2016 - Tilgjengelighet i butikkene.
Noen som vil tippe på når første Vega-produkt er i butikkene?
Tror Vega kommer før desember i år om bildene under kan stemme?
8GB GDDR5? Det tviler jeg på er Vega. Mulig det er et "dobbel-Polaris 10".
Hvis de skal bruke HBM2 så tipper jeg "annonsering" i oktober, "papir-lansering" i desember og tilgjengelighet i januar/februar.
Men har du noen kilder som virkelig sier at det er helt umulig at det kommer noen kort nå til oktober eller før 2017?
Om ting ligger på plass er det ikke umulig med tanke på at :
1 : Samsung annonserte at de startet masse produksjon av HBM2 allerede i Januar i år
2 : SK Hynix la til HBM2 produkter som kunne kjøpes i forskjellige konfigurasjoner allerede i August med forventet levering Q3
AMD valgte jo å komme med en twitter post nå nylig hvor de hintet at lanseringen var ganske så nærme .
Noen mener at det allerede har vært en del tester av Vega og at de to variantene ( Vega 10 og Vega 11 ) skal kunne konkurrere direkte med 1070 og 1080.
Fudzilla traff ganske greit på denne biten om de siste bildene som nå er sluppet hos Amd stemmer
Huff, det ser ut som det er vanskelig å kjøpe et RX 480 kort for tiden, det er rett og slett utsolgt :
https://www.nowinstock.net/computers/videocards/amd/rx480/
Ser ut som det er samme problemet med RX 470 , men det er ikke helt utsolgt enda :
https://www.nowinstock.net/computers/videocards/amd/rx470/
Konklusjon : Enten har Amd enorme produksjonsproblemer eller så selger de såpass bra at de klarer å selge ut alle sine skjermkort.
Men når det er sagt så selger 1060 også bra , eller som nevnt med Amd enorme produksjonsproblemer :
https://www.nowinstock.net/computers/videocards/nvidia/gtx1060/
Endret av Malvado
Rx480 referanse finnes på lager i norge.
Masse 1060 3. Part på lager. F.eks msi gaming x, så ingen fare ;)
Hvorfor sjekke utenfor Norge, når vi bor i Norge? :p
Endret av Nizzen
5 Millioner innbyggere kontra the World...
