AMD Polaris & Vega og midlertidig (?) Navi
ExcaliBuR
Gjest
https://wccftech.com/tsmc-2nm-orders-secured-samsung-in-trouble/
2 nm det er små greier det. Kan AMD også sikre seg dette fra TSMC etterhvert, og ikke kun Apple?
Quote
TSMC Currently Has More Than a 50 Percent Market Share - Apple May Have Secured 2nm Orders From Its Partner
A fresh report from DigiTimes states that TSMC has reportedly determined that Hsinchu Baoshan will be a center for the development of 2nm technology. While it’s not confirmed which clients have managed to secure orders from TSMC for its 2nm node, the report does mention that it might be none other than Apple. The Cupertino giant has already been reported multiple times to give 100 percent of its 5nm orders to TSMC, and it looks like the same thing will be repeated once Apple prepares its custom 3nm SoC.
Sliter med "blurry" skjerm etter jeg instalerte mitt amd kort. Har prøvd å forandret på alt av settings men finner ikke ut hva som gjør dette.
Noen tips? Bilde fra reddit men det slår meg at det sikkert ser flott ut hos dere :p F.eks FartingPhanteam sitt nick som er uthevet er vanskelig å lese og eller er det blurry. Noen tips?
MysticoN skrev (54 minutter siden):
Søk på ClearType i Windows?
20.8.3 Optional er ute.
Release notes:
Spoiler
Radeon Software Adrenalin 2020 Edition 20.8.3 Highlights
Support For
  • Project CARS 3™
  • Marvel’s Avengers™
  • Fortnite™
    • Using AMD’s latest driver Radeon™ Software Adrenalin 2020 edition 20.8.3, a Radeon™ RX 5700 XT GPU offers an average 12% better FPS performance in Fortnite™ (DX12) on the Epic setting, vs. the previous driver iteration, Radeon Software Adrenalin 2020 edition 20.8.1.RS-340
Added Vulkan® Support
  • VK_EXT_extended_dynamic_state
    • This extension adds more dynamic states. This allows applications to reduce the need to recompile and bind pipeline state objects.
  • VK_EXT_private_data
    • This extension allows applications to store application-defined data in a 64-bit private data slot.
  • VK_EXT_image_robustness
    • This extension adds stricter requirements such that drivers return default RGBA values instead of undefined values for out-of-bounds reads. The number of components returned depends on the number of components present in the selected format.
  • VK_GOOGLE_user_type
    • This extension indicates the driver’s support for shader modules using the SPV_GOOGLE_user_type SPIR-V extension.
Fixed Issues
  • Mortal Shell™ may experience a game or application crash when opening the inventory window in game.
  • Enabling HDR on some Radeon FreeSync 2 displays, may intermittently cause the display refresh rate to be forced to the FreeSync ranges minimum refresh rate during gameplay.
  • Surviving Mars™ may experience an application crash or hang at launch on Radeon RX 5000 series graphics products.
  • eFootball PES 2020™ may experience an application crash at launch on Radeon RX 5000 series graphics products.
  • Radeon Overlay may not be available or may fail to invoke on Hybrid Graphics system configurations when playing Hyper Scape™.
  • Counter-Strike: Global Offensive™ may experience intermittent stutter when some applications are running in the background such as third party matchmaking clients or Discord™.
  • YouTube playback may become frozen with Microsoft® Edge player and Chrome™ when played on an extended display on some AMD Ryzen™ 7 3000 series and AMD Ryzen™ 4000 series APU system configurations.
Known Issues
  • Project CARS 3™ may experience mirror like corruption when using VR during game menus on GCN based Radeon graphics products.
  • Project CARS 3™ may experience performance issues when the Radeon Software performance metrics overlay is enabled.
  • Performance issues may be experienced when playing Horizon Zero Dawn™ on select Radeon Vega graphics.
  • With Radeon FreeSync enabled on Radeon RX 5000 series system configurations, task switching to another display or application may cause the display to flicker for a few moments.
  • Brightness flickering may be experienced on some VP9 video content playback through applications or web browsers on Radeon RX 5000 series graphics product system configurations.
  • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
  • Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
  • With HDR enabled, Windows® desktop may experience flickering, and performing a task switch while in a game may cause colors to become washed out or over saturated.
  • Audio may experience instability when connected through an Audio Video Receiver via HDMI® on Radeon RX 5000 series graphics products.
  • Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
  • Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
  • AMD will continue to monitor and investigate any new reports of black screen or system hang issues during extended periods of gameplay closely. Users are encouraged to use the new Bug Reporting Tool for any issues they may encounter.
Footnotes
  • RS-340, Testing by AMD Performance Labs as OF August 24, 2020 using a test system configured with an Ryzen 7 3800XT CPU, 16GB DDR4-3200MHz memory, a Radeon™ RX 5700 XT graphics card and Windows 10 x64 with Radeon Software Adrenalin 2020 Edition 20.8.3, vs. a similarly configured system with Software Adrenalin 2020 Edition 20.8.1, using the game Fortnite™ on the Epic preset and DirectX®12. Performance may vary.
Important Notes
  • AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2020 Edition can be found here.
Package Contents
The Radeon Software Adrenalin 2020 Edition 20.8.3 installation package contains the following:
  • Radeon Software Adrenalin 2020 Edition 20.8.3 Driver Version 20.20.27.01 (Windows Driver Store Version 27.20.12027.1001).
Quote
Den der tok seriøst veldig lang tid før de fikset på. Kan man håpe at det er fikset for alltid? :p
ExcaliBuR skrev (13 timer siden):
Release notes:
  Vis skjult innhold
Support For
  • Project CARS 3™
  • Fortnite™
Fixed Issues
Known Issues
Footnotes
Important Notes
Package Contents
Så langt en stabilt og bra driver hos meg ihvertfall :)
G skrev (16 minutter siden):
Kan hende det kommer tilbake i neste, men forhåpentligvis ikke.
De har ihvertfall hatt to teams tidligere som har alternert på driverversjonene. Og da har det hendt at noe av hva det ene teamet har fikset ikke har kommet med det andre teamets release.
  • Innsiktsfullt 1
Om AMD bruker TSMC 7nm EUV i RDNA2 får vi nok garantert en god utfordrer til 3080 selv om RDNA2 ikke bruker GDDR6X, men bruker de en litt mer raffinert 7nm og ikke EUV tipper jeg vi heller snakker noe ala 2080ti/3070, men trolig med lavere energiforbruk da de har lova 50% mer ytelse pr watt enn RDNA1 som var bedre enn Turing på ytelse pr watt når de kjørte konservativ volt (5700 og 5600XT 0.9-1.0V), men dårligete enn Turing (1.0-1.05V) når de kjørte volt til himmels (5700XT med 1.2V).
