AMD Polaris & Vega og midlertidig (?) Navi
ExcaliBuR
Gjest
Bulldozer var i utgangspunktet en traktor hvor fire hjul og en elendig motor ødela fordelen med noe av designet. Å påstå at man hadde 8 funksjonelle hjul når virkeligheten var mer lik 4 var ren idioti.
Heldigvis med ny ledelse og bruk av innovasjon og de som har virkelig peiling så har vi fått gode cpuer med priser som gir mye ytelse per krone.
jeg vil bare si dette var bra og rettferdig sagt/ skrevet. veldig nøytral og balansert.
terningkast 6
Endret av ex-jordbærplukkeren
20.4.2 Optional er ute. Litt kjærlighet til oss Vega eiere og.
Utgivelsenotater:
Spoiler
Radeon Software Adrenalin 2020 Edition 20.4.2 Highlights
Support For
  • Gears Tactics™
  • Predator: Hunting Grounds™
Fixed Issues
  • Radeon RX Vega series graphics products may experience a system hang or black screen when running Folding@Home while also running an application using hardware acceleration of video content.
  • A system crash or hang may be experienced when using Edge browser to play Netflix™ content.
  • XSplit™ may experience an application hang or freeze when performing a scene switch.
  • Minor stuttering may occur when performing a task switch with performance metrics overlay open in some games.
  • Overwatch™ may experience an intermittent crash while entering a game or during extended gameplay sessions.
  • Radeon RX 5700 series graphics product system configurations may intermittently experience a display loss or black screen while gaming or on desktop with a limited number of displays.
  • Radeon Software may experience an application crash when playing games with non-alphanumeric characters in the game title.
  • Radeon RX Vega series graphics products may experience an application crash with Microsoft® Teams when hardware acceleration is enabled.
  • An ‘Unable to get requirements’ error message may intermittently occur when viewing the Upgrade Advisor tab in Radeon Software.
  • Radeon RX Vega series graphics products may experience a system crash or TDR when playing games with Instant Replay or Record Desktop enabled.
  • Resolved an install issue where Error 1603 could occur when an installation prerequisite for Visual C++ was not correctly detected as installed.
Known Issues
  • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
  • Using Edge™ web browser to playback video content with a multi display system configuration may cause a system hang or crash after extended periods of use.
  • Performance Metrics Overlay and Radeon WattMan incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
  • Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
  • Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
  • Radeon RX Vega series graphics products may experience a system crash or TDR when performing multiple task switches using Alt+Tab.
  • Desktop or In-game corruption may occur intermittently when HDR is enabled.
  • Direct ML Media Filters are currently unavailable in Radeon Software Media gallery for video or image content.
  • Some users may still experience black screen or system hang issues during extended periods of gameplay. AMD will continue to monitor and investigate reports of these issues closely.
  • Some laptops may encounter a BSOD when installing Radeon™ Software Adrenalin 2020 Edition over an existing OEM graphics driver. To work around this issue, first uninstall the OEM graphics driver using Programs and Features within the Control Panel. Once complete, install the Radeon Software Adrenalin 2020 Edition package and select the Factory Reset option during setup.
Important Notes
  • AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2020 Edition can be found here.
Package Contents
The Radeon Software Adrenalin 2020 Edition 20.4.2 installation package contains the following:
  • Radeon Software Adrenalin 2020 Edition 20.4.2 Driver Version 19.50.29.27 (Windows Driver Store Version 26.20.15029.27015)
Quote
Fixed Issues
Å fytti, den der har vel skjedd alt for ofte. Har RX 5600 XT nå, som jo er et 5700-ish basert (nedskalert) kort.
Quote
Known Issues
Montro om Windows 10 også kan være en synder på dette problemet? Windows er jo ikke akkurat kjent for god minnebehandling, ref. ISLC-utility behøves fra Wagnardsoft :roll:
Endret av G
Har ikke for god teknisk innsikt på ting. Men, jeg kjører mye VMware, halvforkvaklet som ikke er "bare metal". Da oppå en annen Windows 10. Er så greit å kunne trykke på pause på "nettlesere" med dette grepet (siden VMware kan pause hele Win10) og fokusere på helt andre ting innimellom.
Jeg har en mistanke om at det er noe spinnvilt som ingen av de ansvarlige tar tak i, uansett hvem det måtte være. Plutselig så kan PC bli sirup også er det kun en Windows Update som surrer uannonsert i bakgrunnen. Er så mye man kan bli hodegal av med Windows. Jeg har f.eks. en lydaktig driver/programvare som fader så ofte maser om restart Sound Radar Sonic Radar anyone heard of it?
Jeg har til tider jævlig mye sånn svart skjermslukning i korte øyeblikk innimellom. Blir av og til verre når jeg åpner en VMware-gjest Win10. Men, jeg synes at dette er andres bord. Akkurat noe Windows-sertifisert gubbe vil jeg aldri ha lyst til å bli. Har lyst å være en glad amatørbruker med noe erfaring om det ene og det andre i flere tiår. Leve livet rett og slett.
Endret av G
On 4/25/2020 at 12:32 AM, ExcaliBuR said:
Sant. Men, adressering til skjermkortets minne skjer vel via skjermkortets driver?
Det stemmer. OS har ikke tilgang til å allokere minne på skjermkort, alt går via API og driver.
  • Innsiktsfullt 1
Quote
AMD’s beastly new Big Navi graphics card could be twice as powerful as the RX 5700 XT
https://www.techradar.com/news/amds-beastly-new-big-navi-graphics-card-could-be-twice-as-powerful-as-the-rx-5700-xt
Quote
AMD’s Big Navi 7nm GPU Flagship Allegedly Features 505mm² Large Die And RDNA2 – Suggests 2x The Performance Of The RX 5700XT
https://wccftech.com/amd-radeon-big-navi-21-gpu-505-mm-die/
Jeg personlig håper på at AMD og Nvidia ikke lar denne sjansen til å midt i COVID-19 kunne tilby litt ekstrem hjemmeunderholdning til folk. Det sitter garantert mye ungdom rundt omkring og gamer som bare det. De burde smi mens jernet er ekstra varmt. Få det ut i mai-juni og gjøre litt endring i lanseringstrend for en gangs skyld.
Endret av G
Håper bare de leverer mer ytelse for pengene. De må gjerne komme med 10.~20.000kr kort, så lenge det blir en merkbar forbedring i ytelse/pris over hele rekken med kort.
Har ikke vært nevneverdig forbedring i ytelse/pris de siste fire årene og covid-19 har ikke hjulpet (fleste skjermkort fra ca 4000kr ser ut til å ha steget med 500~1000kr siden mars).
Fungerer disse Asus skjermkortene som de skal eller er det problemer med de. Jeg har googlet litt rundt på nett og kommet over en del problemer, så jeg lurer på om dette er ting som er løst med nye drivere eller om dette er et produkt en bør holde seg unna.
Asus Radeon Dual RX 5700 OC
Jeg ser at det leveres i denne pakken:
https://www.elkjop.no/product/gaming/gaming-pc-stasjonar/63459/edge-diy-stasjonar-gaming-pc-gjor-det-selv-sett-amd-rx5700
Edit: Kom til at nyere drivere har løst problemene.
Endret av Svein M
  • 3 uker senere...
Satan, jeg blir så lei når skjermen begynner å flimre. Typiskt slår seg av til svart et sekund eller to. Og en får en rekke perler av dette på "ei snor"..
AMD RX5600 XT Sapphire-kort, Windows 10 som jo har hatt ymse sikkerhetsoppdatering de siste døgn.
Kabel i bruk er Displayport på 60 Hz Viewsonic monitor.
Blir ikke klok på det. Men det er ikke gøy om PC er upålitelig i de øyeblikk en fokuserer på noe hvor en behøver et jevnt skjermbilde. Det har vært stabilt veldig lenge. Og i det jeg skriver dette så har PC oppført seg stabilt på noen timer allerede. Har en feeling at det er Windows som glitcher.. :wallbash:
Endret av G
eneste måten du kan feilsøke en "windows" glitch på er å kjøre en ren installasjon av windows. men om jeg var deg, ville jeg testet en annen kabel før jeg startet på det.
Edit: se også etter om kabelen krysser strømkabler og lignende som kan ha elektromagnetisk forstyrrelse om kabelen er dårlig isolert.
Endret av kjeLL//
  • Innsiktsfullt 1
AMD var så fornøyde med 20.4.2 Optional at de har fått den WHQL sertifisert.
Release notes:
Spoiler
Support For
  • Gears Tactics™
Fixed Issues
Known Issues
Important Notes
Package Contents
  • Radeon Software Adrenalin 2020 Edition 20.4.2 Driver Version 19.50.29.27 (Windows Driver Store Version 26.20.15029.27017)
