Hva er feil med dette ...
Ok .. egentlig lastet jeg ned koden fra free-php.net da men ...
Jeg har absolutt ingen erfaring med php men her er config.inc:
# script directory # no trailing slash
$script_dir = "C:\Mine dokumenter\klan side\design5\test\ContactForm\inc\mail.php";
# script url (url to script directory above)
# no trailing slash
$script_url = "http://home.no.net/regrry/mail.php";
# variables below corresponds to the Email to * in your contact form
# match the numbers to the value for which option maps to a specific email
# you can add more as long as you keep them in sync
$adminemail[1] = "[email protected]";
$adminemail[2] = "[email protected]";
$adminemail[3] = "[email protected]";
# preceeds the subject the user puts in on the contact form
$subjectheader = "[Contact Form]:";
# url the form will redirect to after sending email
$redirecturl = "http://home.no.net/regrry/contact.php";
# text that will display if you leave above variable blank
$finishedtext = "Thank you We will Reply asap!";
# how the message will show in the email
# you can reorder these how you wish or modify the message itself to your liking
# just be sure and leave the $variables in tact
$msg2 = "
   Email: $email
   Company: $company
   Phone: $phone
   Website: $website
   Message:$msg
Her er mail.php
<script LANGUAGE="JavaScript">
   <!-- Hide code from non-js browsers
   function validate()
       formObj = document.contact;
       if ((formObj.name.value == "") ||
           (formObj.email.value  == "") ||
           (formObj.subject.value  == "") ||
           (formObj.msg.value  == ""))
           alert("You have not filled in all required fields.");
           return false;
       else
           return true;
   // end hiding -->
</SCRIPT>
<TABLE BORDER=0 cellpadding=5 cellspacing=0>
 <TR>
   <TD>
      <TABLE BORDER=0 cellpadding=2 cellspacing=0>
        <form action="<? echo $script_url; ?>/contact.php" method="post" name="contact" onSubmit="return validate()">
        <TR>
          <TD>
               <BR>
               <DIV>
               1. Name *<BR>
               <input type=text value='your name' size=50 maxlength=50 name=name class='txtfield'><BR>
               2. Email Adress *<BR>
               <input type='text' value='[email protected]' size='50' maxlength='60' name='email'><BR>
               3. Webiste<BR>
               <input type='text' value='http://www.yoursite.com' size='50' maxlength='60' name='website'><BR>
               4. Email to *<BR>
               <select name='who'>
               <option value='1'>LaffeLord</option>
               <option value='2'>Webmaster</option>
               <option value='3'>Information</option>
               </select><BR>
               5. Subject *<BR>
               <input type='text' value='' size='50' maxlength='60' name='subject'><BR>
               6. Message *<BR>
               <textarea name='msg' rows='7' cols='50'></textarea><BR>
               </DIV>
               <input type='submit' value='submit'>* Field Required<BR>
         </TD>
       </tR>
       </FORM>
     </tABLE>
   </TD>
 </TR>
</tABLE>
Og her er header.php
<HTML>
<HEAD>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Contact Form</title>
<META name="description" content="">
<META name="keywords" content="">
<META name="revisit-after" content="7days">
<META name="robots" content="index, follow">
</HEAD>
<BODY BGCOLOR=#FFFFFF LEFTMARGIN=0 TOPMARGIN=0 MARGINWIDTH=0 MARGINHEIGHT=0 rightmargin=0>
Her er contact.php
<html>
<p>We will respond asap !</p>
</html>
Hmm enda en contact.php .... ps. denne contact filen lå i en annen mappe:
   include('inc/config.inc');
include($script_dir . 'header.php');
if ($_SERVER['REQUEST_METHOD'] == "POST") {
   mail("$adminemail[$who]", "$subjectheader $subject", "$msg2", "From: $email \nReply-To: $email");
      if ($redirecturl != "") {
         header("Location: $redirecturl");
      } else {
         echo "<br><center>$finishedtext</center><br>";
} else {
   include($script_dir . 'mail.php');
include($script_dir . 'footer.php');
Håper dette hjalp ...
Her skal det vel stå path'en til script directory på serveren?
Men hva er det som ikke virker? Lettere å hjepe hvis du sier hva som skjer/ikke skjer.
