Halo 5 kaféen
I hodet mitt trodde jeg at friuken nå skulle treffe lanseringen av Halo 5, men det var selvsagt feil :p  Kjenner jeg er veldig,veldig klar for ett nytt eventyr i dette universet nå altså. At dette skal ha seriens til nå største kampanje lover også gull for min del, som ikke er så opptatt av online biten i Halo :)
Gjest Slettet+32asd4f
Ah, så klønete av Microsoft. Andre som har bestilt Halo 5-samleutgaven fra Microsoft og opplever dette?
Heldigvis har jeg allerede spillet og fullført det men jeg vil ha statuen. :p
Ja, rundet den i løpet av helgen.
Godt spørsmål. Jeg kan ikke si så mye ennå (presse, NDA), men litt skuffende, kanskje. Tror fansen vil være like delt med 5 som de var med 4.
Må nesten spille igjennom en gang til.
SUPPORT: ISSUES LAUNCHING HALO 5: GUARDIANS
We know you’re excited to finally get your hands on Halo 5: Guardians on October 27, and we wanted to make sure you’re ready to jump in right away. If you’ve digitally pre-ordered Halo 5: Guardians on your Xbox One before September 21 and are NOT using Instant On power mode, you may still have an incorrect “stub file” for the title, which is simply a placeholder file. Players that have this particular version of the stub file will be required to delete it, and reinstall the title.
If you’ve pre-ordered on or after September 21, you should be ready to download the necessary updates as they become available. Once these updates have been installed, you’ll then be able to play Halo 5: Guardians. If you’re unsure if you’ve got this particular stub file, here’s how you can check:
Go to My games & apps
Sort your game collection by selecting Installed à Sort by size
- If your Halo 5: Guardians game size is greater than 40 GB, you’ve got the correct version, and you’re ready to download the necessary updates when they become available.
If your Halo 5: Guardians game size is less than 40 GB, you’ve got an incorrect stub file, and will need to delete that version and reinstall the game.
For information on reinstalling games on the Xbox One, head here: https://support.xbox.com/en-US/xbox-.../install-games
While we anticipate this affecting a small number of players, we want to ensure everyone is ready to play come launch day. For all updates on Halo 5: Guardians, stay tuned to Halo Waypoint and @Halo on Twitter. See you online, Spartans!
