DataFMT
Er bare å kjøre det som en "router on a stick"/"firewall on a stick"-oppsett, så slipper du å styre med å skulle ha inn ett ekstra NIC.
1.10.1
Realtek* 8111GN
-CG
Gigabit Ethernet Controller
The
Realtek 8111GN
CG
Gigabit Ethernet Controller supports the following features:
10/100/1000 BASE
T IEEE 802.3
compliant
Energy Efficient Ethernet (EEE) IEEE802.3az support
Low Power Idle (LPI) mode
Dual interconnect between the Integrated LAN Controller and the Physical Layer
(PHY):
PCI Express
based interface for active state operation (S0) state
SMBUS for host and management traffic (Sx low power state)
Compliant to IEEE 802.3x flow control support
802.1p and 802.1q
TCP
, IP, and UDP checksum offload
(for IPv4 and IPv6)
Full device driver compatibility
Kilde: https://downloadmirror.intel.com/23417/eng/DN2820FYKH_TechProdSpec05.pdf
802.1q = VLAN-støtte.
Det er unormalt at ikke NIC støtter VLAN, og jeg har vel ikke vært borti det selv tidligere.
