Worms 3d
Advanced Options
It is also possible within the Worms 3D launcher to alter advanced game aspects with extension command line debug options used during game development.
Function Command
Run windowed /WIN
Resolution screen width /W <pixel width>
Resolution screen height /H <pixel height>
Software keyboard /KEY
Music enable /MUSIC
Music disable /NOMUSIC
Movie disable /NOMOVIES
Voice disable /SHUTUP
HUD disable /NOHUD
FPS mouse invert /INVERTMOUSEFP
3PS mouse invert /INVERTMOUSETP
Utilising the advanced options is executed at user discretion and care must be taken especially when specifying custom game resolutions that may not be automatically detected. Please ensure that your system is capable of displaying higher resolution modes before entering any custom values.
You may possibly incur damage to your display if an unsupported high resolution screen mode is entered. For instance to get a resolution of 1280x768 in a windowed mode the advanced option line would have to be entered as /WIN /W 1280 /H 768 to override default settings. Custom text entry in this section is retained for future use.
Håper det hjalp :)
