Jaghi Skrevet 26. august 2015 Del Skrevet 26. august 2015 Hei. Har nettopp bygget en 1151 socket, i5 skylake, med ddr4 ram og windows 10 Har hittil fått 2 forskjellige bsod'r og klarer ikke sirkle meg inn til hva som kan være feil. Den første er en IQRL_less_than _equal noe og den andre er en MEMORY_MANAGEMENT. De første bsodene dukket opp etter 4 min spill av Diablo3. Har noe info fra .dmp filen: ******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************MEMORY_MANAGEMENT (1a)# Any other values for parameter 1 must be individually examined.Arguments:Arg1: 0000000000041792, The subtype of the bugcheck.Arg2: fffff680000a6000Arg3: 0100000000000000Arg4: 0000000000000000Debugging Details:------------------TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2BUGCHECK_STR: 0x1a_41792DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULTPROCESS_NAME: explorer.exeCURRENT_IRQL: 2LAST_CONTROL_TRANSFER: from fffff80124dff2ee to fffff80124dcfd00STACK_TEXT:ffffd000`216245a8 fffff801`24dff2ee : 00000000`0000001a 00000000`00041792 fffff680`000a6000 01000000`00000000 : nt!KeBugCheckExffffd000`216245b0 fffff801`24caedf0 : 00000000`00000000 ffffd000`21624a80 ffffe001`d3fbcd38 fffff801`25094a27 : nt! ?? ::FNODOBFM::`string'+0x209eeffffd000`216247b0 fffff801`2508e2ac : 00000000`14af0000 ffffe001`d450b3c0 00000000`00000000 00000000`00000000 : nt!MiDeleteVad+0x4b0ffffd000`216248e0 fffff801`2508e967 : 00000000`0f1acb00 00000000`00000008 00000000`14af0000 00000000`0f1ab501 : nt!MiUnmapViewOfSection+0xecffffd000`216249b0 fffff801`24dda363 : ffffe001`d2986840 00000000`0f1ab1b0 ffffe001`d2986840 ffffe001`d3fbc840 : nt!NtUnmapViewOfSectionEx+0x77ffffd000`21624a00 00007ff9`71bf4fea : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x1300000000`0f1ab868 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7ff9`71bf4feaSTACK_COMMAND: kbFOLLOWUP_IP:nt! ?? ::FNODOBFM::`string'+209eefffff801`24dff2ee cc int 3SYMBOL_STACK_INDEX: 1SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+209eeFOLLOWUP_NAME: MachineOwnerMODULE_NAME: ntIMAGE_NAME: ntkrnlmp.exeDEBUG_FLR_IMAGE_TIMESTAMP: 55c9bcb6FAILURE_BUCKET_ID: X64_0x1a_41792_nt!_??_::FNODOBFM::_string_+209eeBUCKET_ID: X64_0x1a_41792_nt!_??_::FNODOBFM::_string_+209eeFollowup: MachineOwner--------- Etter at jeg kjørte en windows memory diagnostic og den feilet, lurer jeg på om det kan være defekt minne, eller kanskje at psu'en (750w corsair tx) er gammel (men da ville jeg vel hatt andre problemer?). Legger ved .dmp filen. Hadde satt stor pris på rask hjelp. Lenke til kommentar
snippsat Skrevet 26. august 2015 Del Skrevet 26. august 2015 (endret) Etter at jeg kjørte en windows memory diagnostic og den feilet, lurer jeg på om det kan være defekt minne, Du får kjøre Memtest86+,og ikke windows diagnostic tullet. MEMORY_MANAGEMENT (1a) peker mot feil på minnet. Det er 9-tester alle må ha 0-feil, kun feil i test-5 kan greie man redde seg unna da som regel med høyere spenning til minnet. Jeg svarte akkurat på en samme post her Det samme gjelder for deg,sette riktig spenning,MHz,tilgangstider i BIOS. Teste parvis,ved feil 1 og 1 brikke. Legger ved .dmp filen. Det er bedre om du legger ved alle .dmp filene(zip/rar) og ikke en utskrift, da jeg kan se på dette selv i WinDbg. Endret 26. august 2015 av snippsat Lenke til kommentar
Jaghi Skrevet 26. august 2015 Forfatter Del Skrevet 26. august 2015 Takker for svar. Skal prøve å kjøre memtest og gi svar. Originalt installerte jeg ved en feil w10 32 bits versjon når jeg fikk den første bølgen av BSOD'r. Installerte w10-64bit og fikk en IRQL-bsod da også, men den lagret seg ikke i minidump mappen. Eneste .dmp fil jeg har å er den jeg la ved i forrige innlegg. Kjørte forresten to til wmd og de gikk igjennom.. Lenke til kommentar
Jaghi Skrevet 26. august 2015 Forfatter Del Skrevet 26. august 2015 (endret) Nå fikk jeg en ny mem-bsod idet jeg laget denne posten.. prøvde å fremprovosere noe med mange tabs og youtube klipp. Inkluderer alle dmp i .rar dump.rar Endret 26. august 2015 av Jaghi Lenke til kommentar
Jaghi Skrevet 26. august 2015 Forfatter Del Skrevet 26. august 2015 Nå fikk jeg en ny mem-bsod idet jeg laget denne posten.. prøvde å fremprovosere noe med mange tabs og youtube klipp. Inkluderer nye .dmp. Og en BAD_POOL_HEADER rett etter omstart. Lenke til kommentar
Jaghi Skrevet 26. august 2015 Forfatter Del Skrevet 26. august 2015 (endret) Ferdig med å kjøre memtest og fikk ingen errors, (men den hang seg opp nå jeg prøvde å exite). Nå er jeg virkelig rådvill... Endret 26. august 2015 av Jaghi Lenke til kommentar
snippsat Skrevet 26. august 2015 Del Skrevet 26. august 2015 Har sett over dump filene. Synes det er merkelig at du ikke fikk noen feil i memtest86+. Jeg har alltid likt memtest86+ best,men nå har ikke den blitt oppdatert siden 2013. Du får prøve memtest86 ,som er oppdatert nylig tenker da spesielt på at du har ddr-4 minne. Det kan også være en driver som lager problemet. Se på denne linken Når jeg kjører WinDbg har du 41793 Ser på det samme,reference count som dropper under 0. 2: kd> k Child-SP RetAddr Call Site ffffd000`224375a8 fffff801`cd20430e nt!KeBugCheckEx ffffd000`224375b0 fffff801`cd0b3df0 nt! ?? ::FNODOBFM::`string'+0x20a0e ffffd000`224377b0 fffff801`cd4932ac nt!MiDeleteVad+0x4b0 ffffd000`224378e0 fffff801`cd493967 nt!MiUnmapViewOfSection+0xec ffffd000`224379b0 fffff801`cd1df363 nt!NtUnmapViewOfSectionEx+0x77 ffffd000`22437a00 00007fff`ad344fea nt!KiSystemServiceCopyEnd+0x13 00000000`0574e5d8 00000000`00000000 0x00007fff`ad344fea 2: kd> dt nt!_MMPFN fffff6800005e230 +0x000 ListEntry : _LIST_ENTRY [ 0x01000000`00000000 - 0x00000000`00000000 ] +0x000 TreeNode : _RTL_BALANCED_NODE +0x000 u1 : <unnamed-tag> +0x008 PteAddress : (null) +0x008 VolatilePteAddress : (null) +0x008 PteLong : 0 +0x010 OriginalPte : _MMPTE +0x018 u2 : _MIPFNBLINK +0x020 u3 : <unnamed-tag> +0x024 NodeBlinkLow : 0 +0x026 Unused : 0y0000 +0x026 VaType : 0y0000 +0x027 ViewCount : 0 '' +0x027 NodeFlinkLow : 0 '' +0x028 u4 : <unnamed-tag> Du har også BAD_POOL_HEADER (19) The pool is already corrupt at the time of the current request. This may or may not be due to the caller. The internal pool links must be walked to figure out a possible cause of the problem, and then special pool applied to the suspect tags or the driver verifier to a suspect driver. Du må du først teste med memtest86,ingen feil her heller. Slå på driver verifer ,post de nye dump filene etter at driver verifer er slått på. Lenke til kommentar
Jaghi Skrevet 31. august 2015 Forfatter Del Skrevet 31. august 2015 Tusen takk for svar og hjelp SnippSat. Det viser seg selvfølgelig at det var en enklere løsning på problemet. Hovedkortet ASrock fatality k4, har som standard en klokkefrekvens på rammen på 2133mhz (noe jeg antar struper den nødvendige strømmen rammen trenger). Jeg skrudde denne opp til 2400mhz og voilá, ingen mer bluescreen! Lenke til kommentar
