Linux på Norsk
Tror jeg ville installert Lubuntu istedet for Xubuntu på en så treg atom-CPU. Lubuntu er mer lettdrevet enn Xubuntu. Du kan endre språk på begge.
Edit: Jeg testet Lubuntu i fjor på en Acer Aspire One med lignende hardware (1GB ram / gammel atom cpu) og det gikk greit. Har den ikke lengre så kan ikke sjekke  om norsk språk, men tror det skal være mulig på både lubuntu og xubuntu siden begge er Ubuntu varianter.
Endret av nilsch
Bruk engelsk i Linux, det er noe herk hvis du skal google deg frem til svar på et problem når OSet har norsk språk.
Jeg likte ikke Lubuntu (heller ikke Ubuntu), jeg bruker Linux Mint på den ordinære PC'en min og Peppermint 6 på en eldre laptop.
Peppermint 6 krever litt mer enn Lubuntu, men den ser mye bedre ut enn både Lubuntu og Xubuntu IMO.
http://peppermintos.com/
There are a few things you should know before installing Peppermint, notably some things such as system requirements and a couple of disclaimers.
For a modern operating system, Peppermint has what many people would call "very modest" system requirements. One of the original goals we set when we first started working on the project was to keep the system requirements low in order to offer the best possible performance to the widest variety of hardware. The absolute minimum required specs are as follows:
  • 256 MB of RAM
  • Processor based on Intel x86 architecture
  • At least 3 GB of available disk space
Again, do note that these are the absolute minimum required specs. We strongly recommend having something a little stronger to install on. Our minimum recommended specs are as follows:
  • 512 MB of RAM
  • At least 4 GB of available disk space
Taking it a step further, the preferred minimum specs on a candidate for installation are as follows:
  • 1 GB of RAM
  • x86_64 or amd64 compatible processor
  • At least 4 GB of disk space
Peppermint generally installs and runs without issue on most systems that have at least the preferred minimum specs; however, there are always some exceptions. Many of these exceptions come in the form of systems that require proprietary drivers to properly function. Common examples of this include systems with NVIDIA or AMD/ATI graphics cards, or wireless cards from select manufacturers. Fortunately, Peppermint includes the "Software & Updates" application which contains a section called "Additional Drivers" which will scan your system and inform you if you need any proprietary drivers to be installed, and will offer to install them for you. This will usually solve these issues immediately; however, there is no guarantee that this will provide a working solution.
EDIT: Chromixium kan også vurderes. Chromebook aktig OS   http://chromixium.org/
Endret av Membership Expired
Har ikke prøvd Chromixium.
Ta å søk på youtube, det er noen videoer der.
Jeg ville lastet ned og testet Peppermint, jeg har en clean Peppermint 6 på en HP Pavilion G7.
I Peppermint 6 fungerte Rikstotosiden uten problemer, der er Chromium default nettleser. I Linux Mint er Firefox default nettleser, men jeg bruker Chromium uten Flash og da fungerer ikke videoene. Flere og flere kutter ut Adobe Flash pga malware, virus osv.
Du ha vel en i3 i den, og det er kanskje her det butter, men har chromebox og der er ikke slike problemer, chrome er vel bare en nettleser, laster ned dette nå så vil jeg teste.
er ikke helt sikker på hw i chromeboxen, men den kostet snaut 1000kr, så om en atom er på linje så burde chromixium fungere også med flash, hvis det er det samme os som i chromeboxen
Endret av wyswyg
Chromixium er debian/ubuntu basert Linux distro. Peppermint er det samme.
HP'en har en AMD Athlon II P360 CPU, den er ikke like god som en i3 men den er bedre enn din. Itillegg er det 64bit og 4GB RAM.
Her er noen linker:
http://www.everydaylinuxuser.com/2014/01/6-more-great-linux-operating-systems.html
http://www.techrepublic.com/blog/10-things/10-solid-linux-distributions-for-your-netbook/
http://www.leeenux-linux.com/
Hva slags Atom-CPU er det? Finnes jo en del av de etterhvert.. den som sitter i netbook'en min er dual core og 64-bit, treig som fy, men tross alt noen hakk kjappere enn første generasjon.
sjekket dette nå, og det er en single core, det hadde jeg ikke trodd.
den blir vist i systeminfo med 2 oppføringer, da er det vel bare å glemme denne
youtube fungerer mye bedre enn rikstoto, får se om jeg kan bruke den til ett eller annet, er 320 gb hd i den
men som sagt youtube spiller jeg nå, egentlig helt smooth, så en unge kan vel få denne med lubuntu :)
http://ark.intel.com/products/35466/Intel-Atom-Processor-Z520-512K-Cache-1_33-GHz-533-MHz-FSB
edit: nei youtube er heller ikke bra, kanskje den kan bli en lokal nettsky hehe
Endret av wyswyg
Hvis du ikke skal bruke den som PC så kan du bruke den som media"book"/senter...
Prøv Kodibuntu. www.kodi.tv
Se om du får spilt av filmer med notebook'en. Du kan installere genesis add-on....
http://blog.en.uptodown.com/netbook-media-center-kodi/
Da laster jeg ned kodibuntu, men jeg har ikke tro på dette lengre, kan se ut som youtube og flashplayer krever en dual cpu.
men om kodibuntu kan kjøres fra usb skal jeg gi det en sjanse
