Hei
Noen som kan hjelpe meg med  sekunder.java
/*program som regner om timer, minutter og sekund til sekunder*/
/* en time=3600 sekunder, ett minutt=60 sekunder, z=antall sekunder*/
/*leser inn time/er, minutt/er og sekund/er og beregner antall sekunder*/
import static javax.swing.JOptionPane.*;
public class sekunder{
 public static void main(String[] args) {
  int x=3600;int y=60;int z=25;
  String timetxt=showInputDialog( "tast inn en time eller antall timer");
  int time=parseInt(timetxt);
  String mintxt=showInputDialog( "tast inn ett minutt eller antall minutter");
  int minutter=parseInt(mintxt);
  String sectxt=showInputDialog( "tast ett sekund eller antall sekunder");
  int time=parseInt(sectxt);
  totantall_sekunder=(time *x)+(minutter*60)+z;
  showMessageDialog(null, totantall_sekunder);
Feilmeldinger:
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:13: error: cannot find symbol
  symbol:   method parseInt(String)
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:16: error: cannot find symbol
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:19: error: variable time is already defined in method main(String[])
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:19: error: cannot find symbol
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:20: error: cannot find symbol
  symbol:   variable totantall_sekunder
C:\Users\Public\Documents\JavaProgrammering\sekunder.java:21: error: cannot find symbol
6 errors
Tool completed with exit code 1
