Samsung S6 Edge Smart manager bug?
Hei! Har kjøpt en ny Samsung S6 Edge, som beskrivelsen sier så har jeg en "trussel" som det sies inne på Smart manager: Det står der "det er oppdaget uautoriserte handlinger. start enheten på nytt for å tilbakestille eventuelle uautoriserte endringer."
Har selvfølgelig restartet mobilen, skannet den på nytt osv. men får fortsatt opp"sikkerhetsvarsel"
Takker for svar!
Takker for svar!
Hei
Fikk dette fra Samsung support UK
Welcome to Samsung Galaxy Smart Customer Support
12:05
Hi Are you familiar with this problem? “Unauthorized actions have been detected. Restart your phone to undo any unauthorized changes.” My phone is a Samsung S6 edge. And i got i 22.jun I have tried: I've tried both soft and hard factory reset. I've signed out of all accounts
12:05
12:06
Hello, how are you today?
12:06
Thank you for providing me with the information above.
12:06
Fine. Problem with my new phone only
12:06
I can confirm Samsung are aware of the issue your facing, there will be an software update which will resolve the popup notification.
12:07
So this is the software on the phone? So I just need and wait for new software ??
12:09
Yes Haakon, it is a software issues, it's nothing to worry about. The update will be released soon and will be available via Smart Switch.
Endret av haakaak
  • 2 uker senere...
  • 2 uker senere...
