AndersT2 Skrevet 11. juli 2015 Del Skrevet 11. juli 2015 Vel, når jeg bruker min sub og LFE inngangen på den, så forbi går den alle innstillinger på selve suben. Alt det foretas i forforsterkeren, slik at da skal all info i mine surroundback høyttalere under 120hz sendes til LFE kanalen eller frontene av. Det står klart og tydelig i manualen på min forforsterker. Fra forforsterkeren: "Sound below the crossover frequency is cut off from the output of the speakers set in “Small”. This cut off bass frequency is output from the subwoofer or front speakers." Set subwoofer and LFE signal range playback. Subwoofer Mode Select low range signals to be reproduced by subwoofer. LFE (Default): The low range signal of the channel set to “Small” speaker size is added to the LFE signal output from the subwoofer. LFE+Main: The low range signal of all channels is added to the LFE signal output from the subwoofer. LPF for LFE Set LFE signal playback range. Set this when you want to change the playback frequency (low pass filter point) of the subwoofer. 80 Hz / 90 Hz / 100 Hz / 110 Hz / 120 Hz / 150 Hz / 200 Hz / 250 Hz (Default : 120 Hz) Fra Suben: "The LFE inputs on your SuperCube subwoofer are direct coupled inputs which are not affected by the subwoofer’s low-pass filter or low-pass crossover control." Lenke til kommentar
Soulitaire Skrevet 11. juli 2015 Del Skrevet 11. juli 2015 Hva får deg til å tro at jeg prater om innstillinger på selve subwooferen? Lenke til kommentar
