Driver å lager en asp side i dreamweaver, setter oppe insert record som på andre sider jeg har laget i samma webprosjekt.
Får denne feilmeldingen:
Error Type:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E14)
[Microsoft][ODBC Microsoft Access Driver] Syntax error in INSERT INTO statement.
/Admin/Gjestebok/add.asp, line 121
Skjer ikke på noen av de andre dokumentene hvor insert record funksjonen i DW er brukt.
Koden er:(linje 121 sier MM_editCmd.Execute)
' *** Edit Operations: declare variables
Dim MM_editAction
Dim MM_abortEdit
Dim MM_editQuery
Dim MM_editCmd
Dim MM_editConnection
Dim MM_editTable
Dim MM_editRedirectUrl
Dim MM_editColumn
Dim MM_recordId
Dim MM_fieldsStr
Dim MM_columnsStr
Dim MM_fields
Dim MM_columns
Dim MM_typeArray
Dim MM_formVal
Dim MM_delim
Dim MM_altVal
Dim MM_emptyVal
Dim MM_i
MM_editAction = CStr(Request.ServerVariables("SCRIPT_NAME"))
If (Request.QueryString <> "") Then
 MM_editAction = MM_editAction & "?" & Server.HTMLEncode(Request.QueryString)
End If
' boolean to abort record edit
MM_abortEdit = false
' query string to execute
MM_editQuery = ""
' *** Insert Record: set variables
If (CStr(Request("MM_insert")) = "skriv") Then
 MM_editConnection = MM_db_STRING
 MM_editTable = "Gjestebok"
 MM_editRedirectUrl = "/Admin/Gjestebok/added.asp"
 MM_fieldsStr  = "tema|value|name|value|email|value|website|value|innlegg|value|time|value|dato|value|ip|value"
 MM_columnsStr = "tema|',none,''|name|',none,''|email|',none,''|website|',none,''|innlegg|',none,''|time|',none,''|date|',none,''|ip|',none,''"
 ' create the MM_fields and MM_columns arrays
 MM_fields = Split(MM_fieldsStr, "|")
 MM_columns = Split(MM_columnsStr, "|")
 ' set the form values
 For MM_i = LBound(MM_fields) To UBound(MM_fields) Step 2
   MM_fields(MM_i+1) = CStr(Request.Form(MM_fields(MM_i)))
 Next
 ' append the query string to the redirect URL
 If (MM_editRedirectUrl <> "" And Request.QueryString <> "") Then
   If (InStr(1, MM_editRedirectUrl, "?", vbTextCompare) = 0 And Request.QueryString <> "") Then
     MM_editRedirectUrl = MM_editRedirectUrl & "?" & Request.QueryString
   Else
     MM_editRedirectUrl = MM_editRedirectUrl & "&" & Request.QueryString
   End If
 End If
End If
' *** Insert Record: construct a sql insert statement and execute it
Dim MM_tableValues
Dim MM_dbValues
If (CStr(Request("MM_insert")) <> "") Then
 ' create the sql insert statement
 MM_tableValues = ""
 MM_dbValues = ""
   MM_formVal = MM_fields(MM_i+1)
   MM_typeArray = Split(MM_columns(MM_i+1),",")
   MM_delim = MM_typeArray(0)
   If (MM_delim = "none") Then MM_delim = ""
   MM_altVal = MM_typeArray(1)
   If (MM_altVal = "none") Then MM_altVal = ""
   MM_emptyVal = MM_typeArray(2)
   If (MM_emptyVal = "none") Then MM_emptyVal = ""
   If (MM_formVal = "") Then
     MM_formVal = MM_emptyVal
   Else
     If (MM_altVal <> "") Then
       MM_formVal = MM_altVal
     ElseIf (MM_delim = "'") Then  ' escape quotes
       MM_formVal = "'" & Replace(MM_formVal,"'","''") & "'"
     Else
       MM_formVal = MM_delim + MM_formVal + MM_delim
     End If
   End If
   If (MM_i <> LBound(MM_fields)) Then
     MM_tableValues = MM_tableValues & ","
     MM_dbValues = MM_dbValues & ","
   End If
   MM_tableValues = MM_tableValues & MM_columns(MM_i)
   MM_dbValues = MM_dbValues & MM_formVal
 Next
 MM_editQuery = "insert into " & MM_editTable & " (" & MM_tableValues & ") values (" & MM_dbValues & ")"
 If (Not MM_abortEdit) Then
   ' execute the insert
   Set MM_editCmd = Server.CreateObject("ADODB.Command")
   MM_editCmd.ActiveConnection = MM_editConnection
   MM_editCmd.CommandText = MM_editQuery
   MM_editCmd.Execute
   MM_editCmd.ActiveConnection.Close
   If (MM_editRedirectUrl <> "") Then
     Response.Redirect(MM_editRedirectUrl)
   End If
 End If
End If
Håper noen kan hjelpe da jeg står temmelig fast og dette kun skjer på dene ene siden, ingen andre jeg har laget senere.....
har prøvd å søke litt rundt, men de forslagene jeg har prøvd funker ikke.
