Norton System Works 2002
Troxx
Får denne feilmeldingen:
"The procedure entry point?SRStopRedirect@@YAKK@Z could not be located in the dynamic link library SymRedir.dll"
Hva kan være galt... ??
Dessuten fungerer ikke oppdatering (via LiveUpdate) av Utilities og Speed Disk...
Hvordan fixe dette??
Mvh Troxx
Kanskje dette kan hjelpe, hentet fra symantec:
Error: "navapw32.exe - Entry Point Not Found" then "The procedure entry point ?SRStopRedirect@@YAKK@Z could not be located..."
Situation:
Norton AntiVirus (NAV) is installed as a stand-alone product or as a part of Norton SystemWorks (NSW). After running LiveUpdate and downloading a Symantec Redirector program update, you see the error message "navapw32.exe - Entry Point Not Found" followed by "The procedure entry point ?SRStopRedirect@@YAKK@Z could not be located in the dynamic link library SymRedir.dll." This error might also happen during restart after installing either Norton Internet Security (NIS) or Norton Personal Firewall (NPF).
Solution:
Symantec is investigating this problem. The cause is unknown, and there is no solution at this time. This document will be updated when new information or a solution is found.
For instructions to work around the problem, see the NAV document "Error: "navapw32.exe - Entry Point Not Found" then "The procedure entry point ?SRStopRedirect@@YAKK@Z could not be located...."
Product(s): Norton SystemWorks 2002
Operating System(s): Windows XP
Document ID: 2002020711524207
Date Created: 02/07/2002
Last Modified: 02/21/2002
