Den nye Forumkaféen v2
L4r5
Gjest Slettet+9817324
From PWInsider:
LATEST ON RIC FLAIR
by Mike Johnson @ 5:51 PM on 8/16/2017
In regard to Ric Flair's condition, he is still currently in critical condition in Atlanta, GA.
A source close to the situation told PWInsider.com that while reports are out there that Flair had surgery on his colon, those are incorrect.It appears those stories began because Gene Okerlund mistakenly said colon on social media.
The surgery was actually on Flair's bowels due to a massive obstruction caused by a health issue that was complicated by other health issues that Flair had been dealing with, including heart issues that he was already aware of. The situation turned dire when Flair's kidneys shut down due to the obstruction and he is currently undergoing dialysis that will hopefully fix the situation and allow them to return to normal.
Flair was in extremely bad shape several days ago but the outlook, we are told, is better. However, we were cautioned that he is still in critical condition and anything can happen, so he's not out of the woods yet and is expected to need at least one more surgery in the weeks to come. This is NOT a case where Flair will wake up tomorrow and leave the hospital the next day.
(er nok alkorelatert , Naturgutten er glad i å drikke)
Gjest Slettet-lYlo5C
Du må ikke finne på å droppe ut av BI nå. Det vil du kanskje angre på resten av livet. Du kan heller ta den nye linja neste år. Gjør deg ferdig med en ting om gangen. ELlers blir bare 2 år på BI bortkastet tid. Ei fadderuke med festing bør pokker meg ikke avgjøre noe så viktig.
Av erfaring er det nesten umulig å ta opp igjen et studie etter at man slutter.
Ååå men vil ha fadderuke. Faen. Vil feste og pule. Vil ha makt.
Anbefales sterkt
Aldri blitt så mye festing og puling på meg før tror jeg
Anbefales sterkt
Har hatt en fadderuke. Fantastiske minner. Men vil ha en til. Endret av Lami
Dette er min andre fadderuke, er sykt sliten men er gøy. Alle fadderbarna har gitt opp omtrent, mens vi faddere drikker oss drita og spyr :) superfaddere
