First Time Build with Corsair Graphite 380t
Im going to be building my first computer, with help from an experienced friend. I will be using this mini case Corsair Graphite 380t, I'm wondering if all the parts listed below will fit well and give enough power for the machine, or if there's anything to look out for!
Questions
- Does it only have one HDMI port? Im guessing the second monitor will have to use another connector
- How many SSDs and HDDs will it fit? Im planning one 1 SSD and 1 HDD, but I might add more in the future!
- Does it have Wi-Fi or Bluetooth? I think the motherboard says that
The Build:
Display 1 Samsung S27C650D 27tum 1920 x 1080
Display 2 Samsung S27C650D 27tum 1920 x 1080
Case: Corsair Graphite 380T White
Motherboard: ASUS ROG MAXIMUS VI IMPACT - mITX / Z87
Memory: Crucial BallistixSport 16GB 1600MHz
CPU: Intel Core i5 4690K 3,5GHz
CPU Cooler: Corsair Hydro H60 V2 CPU Kylare
GPU: EVGA GeForce GTX970 SC ACX 2.0 4GB
PSU: EVGA SuperNOVA 850 G2
Gjest bruker-293283
You can use displayport cables to connect your displays to the GPU. You can fit two 2.5" drives(SSD or HDD) and two 3.5" drives(HDD or SSD with bracket). The motherboard has both bluetooth and wifi.
All the parts will fit, and a 650W power supply will suffice.
No, you can't use both the motherboard and gpu displayports at the same time, only gpu. Then you get a total of 3 Displayport outputs :)
Hm okay, why is that? I don't know much about computer building. What ports will be available from behind the computer? I thought that the DisplayPort from the motherboard would be there, since all the USBs are there too
Also, will H80i GT fit in the Corsair 380t? It looks like trouble in this thread
http://www.sweclockers.com/forum/127-corsair/1365676-h80gt-far-inte-plats-i-en-380t/
Endret av supindahood
Why did they put ports in the motherboard if they can't be used? I hope the USB ports can be used atleast
You can use the USB ports.
They have put the ports there because some people don't buy a dedicated graphic card (you don't need it for Web surfing, watching movies etc).
Then you put in a graphic card, you are "replacing" the internal graphic card on the cpu with a dedicated graphic card (like Gtx 970)
