Forskjeller på UPS?
Q3. How many types of UPS?
There are three typical types of UPS: OFF LINE, ON LINE, and LINE INTERACTIVE.
Q4. What is called OFF LINE UPS?
Off-line UPS will supply power only when power failure.
Q5. What is called ON LINE UPS?
Under normal situation, On-line UPS will supply power from transformer and will transfer to bypass only when UPS is out of order, overload, or overheat.
Q6. What is called LINE INTERACTIVE UPS?
Under normal situation, Line Interactive UPS will supply power from bypass through transformer. At this moment, transformer becomes charger. When power failure, transformer will transfer battery power to AC output.
Q7. How to choose the right UPS?
1. Understand specifications of all UPS.
2. Consider the requirements of power quality.
3. Understand the current capacity of UPS and consider the future expanding.
4. Choose the reputed brands and manufacturers.
5. Choose UPS based on our requirements.
Q8. What are important items you should evaluate when buying an UPS?
1. UPS reliability and stability.
2. The excellent engineers and the ability of products creation.
3. High efficiency and low noise.
4. Suppliers' reputation and financial situation.
5. International safety approvals such as TUV,UL,CSA, and so on.
6. Plant certifications such as ISO9001, ISO9002, and so on.
enkelte billigvarianter UPS'er leverer firkantkurver, noe som ømfintlig elektronikk kan ta skade av over tid. anbefaler derfor at du forsikrer deg om at den UPS'en leverer sinuskurve ved batteridrift.
Mvh, Jan Erik
I løpet av mine ca. 16 mnd. hos Makker AS (norsk UPS importør/leverandør), så var en av mine oppgaver å lære opp og støtte "mine" forhandlere i å gjøre sluttkunden om viktigheten av å ha en UPS. Komplett var IKKE en våre kunder, da dette er et marked (B2C) hvor APC er totalt dominerende (hatten av for deg Erik Vennmoe), og har gjort en UTROLIG innsats på innsalgsbiten.
Det er dog ETT område hvor de "svikter" litt (men det gjør jo stort sett alle andre også), og det er på opplæringen av de butikkene som henvender seg til hjemmebrukerene....
For å gjøre det enklere å forstå hovedsakene rundt UPS, så har jeg limt inn en del linker til sider hvor det finnes info. forklart på en enkel måte (håper du er enig).
Micropower-norsk UPS distributør
Teknisknytt
Elektronikknett
Phoenix-Med over 20.000 elektro komponenter og utstyrsenheter
Lynvarsel i Danmark og litt av Sørlandet
Makker-norsk UPS importør
En trivelig fyr ved navn Oddvar som har ca 35 års elektro-erfaring
Powerware-UPS(Fiskars/Invensys)
UPS kalkulator
APC Norge
Lykke til ! :p:
