Råeste gamer bærbar noensinne!
Råeste gamer bærbar noensinne!, ... eller hva?
denne?
eller..
denne?
Ja, hadde det ikke värt for at hele Lieberman shiten er fake! There is no such thing!
Fake Ja... LoL de er ikke fake.
Hvordan vet du at de ikke er fake, har du bestilt noe fra de? Kanskje du skulle forsöke?
lisa ciesniewski owns both leibermann-corp.com and go-l.com
She is listed at:
P.O. Box 10548
Marina del Rey
90295
CA
UNITED STATES
[email protected]
3105626814
3108210336
A quick search of exuis.com reveals it to be pretty empty, and liebermann-corp.com is non-existant as well.
But I did manage to find out She rides horses, and her home phone # is 310-902-2276, she drives a 1992 black toyota tercel (License Plate # 4PNE095). Hardly someone who should be part of a big ass startup. And also not really the type person you would think would work for a company located in Los Angeles.
Also the address for the company comes up as the same location (8726 S Sepulveda Blvd) for a TON of businesses, most of which are blue collar / retail businesses. So its probably a mall or possibly a big office building. Either way, again hardly the place for a manufacturer of highly custom PC's
Domain Name.......... go-l.com  Creation Date........ 2003-06-13  Registration Date.... 2003-06-13  Expiry Date.......... 2004-06-13  Organisation Name.... Exuis  Organisation Address. P.O. Box 10548  Organisation Address.  Organisation Address. Marina del Rey  Organisation Address. 90295  Organisation Address. CA  Organisation Address. UNITED STATESAdmin Name........... lisa ciesniewski  Admin Address........ P.O. Box 10548  Admin Address........  Admin Address........ Marina del Rey  Admin Address........ 90295  Admin Address........ CA  Admin Address........ UNITED STATES  Admin Email.......... [email protected]  Admin Phone.......... 3105626814  Admin Fax............ 3108210336Tech Name............ Tech Support  Tech Address......... 101 Marietta Street  Tech Address.........  Tech Address......... Atlanta  Tech Address......... 30303  Tech Address......... GA  Tech Address......... UNITED STATES  Tech Email........... [email protected]  Tech Phone........... +1.8005895060  Tech Fax............. +1.4045860001  Name Server.......... a.ns.interland.net  Name Server.......... b.ns.interland.net
Les mere her:
http://plex.us/outbursts/liebermann.html
De har kopiert alt fra apple.com
Mye er kopiert fra alienware også. I html koden ble det funnet masse bilder med sourcen direkte til http://www.alienware....... osv.
Også mye rare tagger som ikke har värt fjerna som "made with swift" etc.
Vil man ha sånne her maskiner så kan man vel mekke de fleste på egenhånd:
intel 3.2 ghz extreme edition cpu:
http://www.intel.com/personal/products/pen...eme_edition.htm
(keep in mind that the 3.8ghz/950mhz system offered is an overclocked 3.2ghz/800mhz system. many 3.2ghz users, even those without the EE version, run at this speed)
4gb 533mhz ddr533 memory:
http://www.geilusa.com/proddetail.asp?linenumber=24
(keep in mind dual channel DDR does not refer to DDR-II, but instead refers to two channels, ie banks of DDR. which, btw, is what is pictured in the image of their motherboard. although, claims of chipsets not existing for DDR-II are false as well. albeit it is a xeon system chipset, the intel 7205 chipset aka "granite bay" is released and supports true DDR-II.)
up to 16gb expansion memory using cenatek rocket drives:
http://www.cenatek.com/product_rocketdrive.cfm
(these are not nvram drives like puram. they are volatile and are powered by an external ac adapter as well as from the system bus. if all power is lost, so is all data. they are merely useful for lightening fast application usage while using the machine. they take PC133 off the shelf memory)
option PuRam technology:
http://www.m-sys.com/Content/Products/FFDFamily.asp
(puram technology is rebranded solid state flash disks. i assume they are using the 3.5 IDE form factor, although they are available in whatever form you wish)
ati radeon 9800 pro:
http://www.ati.com/products/radeon9800/rad...0pro/index.html
r404 based cooling system:
http://www6.tomshardware.com/cpu/20001103/vapochill-07.html
(asetek vapochill system... omg, look at the vapochill case. familiar?)
raid ata-133, raid s-ata 150, fibre channel, ultra320 scsi:
http://www.google.com
8x dvd writer:
http://www.plextor.com/english/products/708UF.html
(not this model, but technology exists)
magma pci bus expansion units:
http://www.magma.com/pci/7slot6466/index.html
(go-l photos even say magma on the board..)
firewire 400, firewire 800:
3com 3c940 gigabit lan:
http://www.3com.com/products/en_US/detail....&sku=3C940-MV00
example 550w vsf power supply:
http://www.bit-tech.net/review/123/
and for good measure, grand canyon display:
http://www.9xmedia.com/Pages-productivity-...d-a-system.html
Mulig Lieberman er fake, men det er ikke maskinene har selv bestilt en gjennom pc Torque(sager 8890). de har også et eget forum om bærbare. De fleste maskinene kommer opprinelig fra sager de selges til forhandlere under forskjellige navn.
Forhandlere:
http://pctorque.com/
https://www.voodoopc.com
http://www.hypersonic-pc.com
http://www.alienware.com
http://mrmulti.safeshopper.com/index.htm?577
http://www.sagernotebook.com
Forum til pc Torque der vil du få svar på alt vedrørende disse maskinene..
http://talknotebooks.com/
Det er veldig store prisforskjeller, anbefaler å velge en av de minst profilerte firmane.
Dette er også meget store og tunge maskiner så hvis dette ikke er ønskelig styr unna. Ønsker du en maskin med stor kraft så er dette abselutt noe å anbefale.
