Parity Error
Corbin
Fant denne:
  Sitat
I heard two beeps during POST, but all the device are installed properly and the system also boot up successfully. Can you tell me the meaning of the BIOS beep sounds? Is there any error occurs during booting?
Normally, there is no beep during POST unless you installed an USB device. The beep sound means the number of usb devices present. For example: You will hear two low beeps if you install two USB devices. However, you will hear one loud beep if no hard disk is connected to the motherboard.
Får du noen beskjeder fra ASUS POST Reporter? Den stemmen som gir beskjed når noe er galt?
