GeForce Gtx 10**/Titan og Pascal tråden
Download MSI AfterBurner 4.1.1
http://www.guru3d.com/news-story/download-msi-afterburner-4-1-1.html
Revision history - Version 4.1.1
  • Added core voltage control for reference design NVIDIA GeForce GTX TITAN X series graphics cards
  • Added core voltage control for reference design NVIDIA GeForce GTX 980 Ti series graphics cards
  • Now core voltage control via NCP4206 is unlocked on reference design NVIDIA GeForce GTX 690, NVIDIA GeForce GTX 780 and
  • NVIDIA GeForce GTX TITAN series graphics cards when extended MSI voltage control mode is selected
  • Added new third party voltage control mode. Traditionally we provided voltage control on reference design graphics cards or on custom design MSI graphics cards only. However, rich set of PWM controllers supported by MSI Afterburner core allows implementing voltage control on many third party custom design graphics cards as well. With this version we introduce original concept of user extendable voltage control mode, allowing experienced users to get access to programmable MSI Afterburner core, get access to full range of voltage controllers supported by it, create custom hardware database and program MSI Afterburner to provide voltage control on many third party custom design graphics cards. Third party voltage control mode requires populating and downloading third party hardware database, please visit MSI Afterburner discussion forums to help adding your custom design cards to the database or download the latest database version.
  • Fixed bug causing application to crash when “layered with alpha” skin composition mode is selected, application is minimized to system tray and properties are accessed via the context menu of detached monitoring window
  • Improved hardware monitoring module:
    • Added negative temperatures monitoring support for NVIDIA GPUs
    • Fixed extended CPU family and model detection to address issue with incorrect maximum junction temperature (Tjmax) detection on some Intel CPUs
    • Now power users can override the maximum junction temperature (Tjmax) via configuration file if necessary
    • Added temperature monitoring for AMD Family 10h – 16h micro architecture CPUs. Please take a note that this functionality is currently experimental and disabled by default. Power users can unlock AMD CPU temperature monitoring via [CPUHAL] section in the configuration file if necessary
    • Added correction formulas support. Now you can apply a custom correction formula to any data source in hardware monitoring module. Correction formulas can be useful to apply temperature offsets to custom temperature sensors if necessary (e.g. set formula to “x+20”), display effective memory clock instead of base clock (e.g. set formula to “x*2”), display per-GPU memory usage instead of total memory usage on Crossfire systems (e.g. set formula to “x/2”) and many, many more.
    • Hardware Monitoring Log file format has been upgraded to v1.5 to provide correction formulas support.
    • Added “CPU load” graph to multicore CPUs. The graph is displaying the average CPU load across all CPU cores.  :w00t:  (på tide)
    • Added “CPU temperature” graph to thermal monitoring capable multicore CPUs. The graph is displaying the maximum CPU temperature across all CPU cores
    • o Added connection retry counter to Logitech LCD monitoring module. Now MSI Afterburner stop trying to connect to Logitech LCD after some failed connection attempts instead of trying to connect to it in endless loop. Retry counter implementation is aimed to bypass the problem with GDI resource leak in Logitech LCD API, which could cause application to crash after some period of time when output to LCD is enabled on the system with no Logitech LCD connected to it
    • Added dynamic output format for min / max limits displayed on the graphs. Now MSI Afterburner uses integer output format for limits if the range between minimum and maximum limits is greater than 1, otherwise it uses floating point output format
  • Improved skin engine:
    • Added support for altered USF skins obfuscation scheme used in most recent versions of third party overclocking tools
    • Drastically reduced load time for obfuscated USF skin files (*.UXF). Now MSI Afterburner open obfuscated skin files roughly 10 times faster than the previous version
    • Reduced skinned GUI initialization time due to cached access to the skin header
    • Added support for negative GPU temperature indicators in all skins supplied with application
  • Multimedia timer resolution is no longer hardcoded to 10ms. The resolution is now adjustable and set to 16ms by default to reduce timer interrupts related CPU load at the cost of losing some smoothness in GUI animation. Power users can override timer resolution via the configuration file if necessary
  • Updated kernel mode driver provides new IOCTLs for safe access to PCI bus required for temperature monitoring on AMD CPUs
Endret av Nizzen
Nei, fordi korta er under vann :p
Om jeg gidder å teste tviler jeg på også :D
Vel han fikk jo bare 0.02 V mer vcore :p
stusselige greier ja. Selv om potensialet er mye høyere selvsagt. Skal jo ikke mye til for å smøre på litt tykkere strek med blyanten.
Har ikke vært så oppdatert i det siste. Noen som vet hvor godt Titan X'en liker ekstra spenning. Samt hvor godt VRMen takler (på vann eller bedre).
Endret av Andrull
Får de lov til dette av nvidia da? De var vertfall strenge på dette med 3. Parts kjølere på de andre titan kortenne, gigabyte la vel med sin egen kjøler så du måtte montere selv på titan black for å komme rundt dette.
Endret av Evil-Duck
Hmmm...
Denne tråden bør endre navn til "GeForce GTX Titan X tråden"
Regner med at dere vil ha en ny tråd når det kommer Pascal-baserte Titan-kort neste år! ;)
Rævva produktnavn. Alt for langt over 980-ytelsen til å hete Ti. Når kommer kortet som ligger mellom 980Ti og 980 da? 980 Metal, var det ikke? :)
Test av kortet der det blir slått av 295x2 på 4K for det meste , men på alt annet er det noe bedre enn de andre kortene til Nvidia med opp til 10 - 20 fps mer avhengig av spill og innstillinger  :
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_980_Ti/15.html
Er heller ikke så veldig stor forskjell mellom dette kortet og et vanlig 980 kort så jeg tror nok det er bedre for de fleste å enten vurdere 1 x 980 eller 2 x 980 med mindre dette kortet blir tilgjengelig til en fin pris.
Ikke så veldig stor forskjell? Det er jo MYE større forskjell mellom 980 og 980 Ti enn 970 og 980? I snitt 25% er mye.
Da blir 980-tri sli kanskje ikke så ille alikevel :hmm:
Det vil fortsatt være svakere enn 980 Ti SLI selv med perfekt skalering. 980 Ti leverer jo jevnt over 25% bedre ytelse enn 980.
Ser i de fleste benchmarks at 980 tri sli er kraftigere enn titan x sli tho.
Skru på 8x msaa i GTA V så skjønner du at VRAMen på 980 ikke er på langt nær nok, kanskje ikke på Ti heller faktisk.
Hvor lenge er det til Pascal og 14nm? Klarer ikke helt å engasjere meg for GTX 980 Ti når jeg vet at det å endelig få beveget seg bort fra denne 28 nm flaskehalsen virkelig kan by på en skikkelig løft i ytelse med neste generasjon.
Ett år, sånn ca.
Nettopp. Samtidig så håper jeg folk ikke kjøper 980 eller 980ti for å spille i 1080p. Det er litt for dumt.
Det gjør at behovet for mye vram er viktig (pgA høyere oppløsning). Flesteparten av AAA titlene i år bruker over 4gb vram når man spiller i høyere oppløsning.
Jeg tenker jeg kommer til å kjøpe 980 Ti for min 1080p-monitor.
Ellers: VRAM-bruk != VRAM-krav, dagens titler bruker så mye VRAM de overhodet kan for å minimere lastetider og streaming fra HDD, det betyr ikke at spillene ikke vil kjøre bra med mindre VRAM. Ta BF4 for eksempel, først på 4K med MSAA aktivert begynner 3GB VRAM å være en flaskehals, og selv da er det bare snakk om å trenge 3.5GB reelt sett.
