Logitech USB mus Slackware 9.1
Min relevante del i XF86Config ser slik ut:
Section "InputDevice"
       Identifier  "Mouse1"
       Driver      "mouse"
       Option      "Protocol" "PS/2"
       Option      "Device" "/dev/mouse"
EndSection
Dette er i Slack 9.0, med Logitech Dual optical mus (skal vel egentlig ikke ha så mye å si? )
Hmm... I RH var det bare å plugge i musa (selv med X oppe) og bruke den...
Loker tydeligvis noe inne i et varmt sted med å aktivere tastaturet, blinker mange ganger med led (5 ganger trur eg) før X kommer (også etter å ha vært i virituelt konsoll). Dumper masse skit i dmsg:
Keyboard timed out[1]
min X config, som ellers virker veldig fint:
[kyrre@kyrre-laptop X11]$ cat XF86Config
# XFree86 4 configuration created by pyxf86config
Section "ServerLayout"
       Identifier     "Default Layout"
       Screen      0  "Screen0" 0 0
       InputDevice    "Mouse0" "CorePointer"
       InputDevice    "Keyboard0" "CoreKeyboard"
       InputDevice    "DevInputMice" "AlwaysCore"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
       RgbPath      "/usr/X11R6/lib/X11/rgb"
       FontPath     "unix/:7100"
EndSection
Section "Module"
       Load  "dbe"
       Load  "extmod"
       Load  "fbdevhw"
       Load  "glx"
       Load  "record"
       Load  "freetype"
       Load  "type1"
       Load  "dri"
EndSection
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#       Option  "Xleds"         "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#       Option  "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#       Option  "XkbModel"      "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#       Option  "XkbModel"      "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#       Option  "XkbLayout"     "de"
# or:
#       Option  "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#       Option  "XkbOptions"    "ctrl:swapcaps"
# Or if you just want both to be control, use:
#       Option  "XkbOptions"    "ctrl:nocaps"
       Identifier  "Keyboard0"
       Driver      "keyboard"
       Option      "XkbRules" "xfree86"
       Option      "XkbModel" "pc105"
       Option      "XkbLayout" "no"
EndSection
       Identifier  "Mouse0"
       Driver      "mouse"
       Option      "Device" "/dev/psaux"
       Option      "ZAxisMapping" "4 5"
       Option      "Emulate3Buttons" "no"
EndSection
# If the normal CorePointer mouse is not a USB mouse then
# this input device can be used in AlwaysCore mode to let you
# also use USB mice at the same time.
       Identifier  "DevInputMice"
       Driver      "mouse"
       Option      "Protocol" "IMPS/2"
       Option      "Device" "/dev/input/mice"
EndSection
Section "Monitor"
       Identifier   "Monitor0"
       VendorName   "Monitor Vendor"
       ModelName    "Generic Laptop Display Panel 1024x768"
       HorizSync    31.5 - 48.5
       VertRefresh  40.0 - 70.0
       Option      "dpms"
EndSection
Section "Device"
       Identifier  "Videocard0"
       Driver      "radeon"
       VendorName  "Videocard vendor"
       BoardName   "ATI Radeon Mobility M6"
       VideoRam    16384
EndSection
Section "Screen"
       Identifier "Screen0"
       Device     "Videocard0"
       Monitor    "Monitor0"
       DefaultDepth     24
       SubSection "Display"
               Depth     24
               Modes    "1024x768" "800x600" "640x480"
       EndSubSection
EndSection
Section "DRI"
       Group        0
       Mode         0666
EndSection
[dumpe masse digre configfiler]
EDIT: skriveleif
