[Løst] Problem med WAN eller LAN
Har problem med enten boksen fra Telenor eller Asus routeren (RT-N66U).
Problemet er at jeg mister nettet ofte, og må som regel restarte boksene.
Noen ganger holder det å restarte Asus boksen, andre ganger begge.
Telenor boksen er satt i "transparent" modus og Asus boksen skal ta seg av alt (Telenor bruker PPOE om det har noe å si).
I tillegg har jeg konfigurert VPN tilgang utenifra (Innebygde løsningen i Asus boksen).
Trenger litt hjelp med å tolke om loggen fra Asus boksen kan avsløre om feilen ligger i Asus- eller Telenor boksen.
Full logg siste 2 dager.
Mar 2 06:57:35 rc_service: ntp 524:notify_rc restart_upnp
Mar 2 06:57:35 rc_service: ntp 524:notify_rc restart_diskmon
Mar 2 06:57:35 rc_service: waitting "restart_upnp" via ntp ...
Mar 2 06:57:35 miniupnpd[523]: received signal 15, good-bye
Mar 2 06:57:36 syslog: SNet version started
Mar 2 06:57:36 miniupnpd[567]: HTTP listening on port 39777
Mar 2 06:57:36 miniupnpd[567]: Listening for NAT-PMP traffic on port 5351
Mar 2 06:57:37 disk monitor: be idle
Mar 2 06:57:38 pppd[434]: System time change detected.
Mar 2 06:57:44 crond[384]: time disparity of 2190596 minutes detected
Mar 2 06:57:55 ntp: start NTP update
Mar 2 06:59:57 ntp: start NTP update
Mar 2 07:00:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.0.20 10:0b:a9:58:50:78
Mar 2 07:00:04 dnsmasq-dhcp[373]: DHCPNAK(br0) 192.168.0.20 10:0b:a9:58:50:78 wrong network
Mar 2 07:00:07 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 10:0b:a9:58:50:78
Mar 2 07:00:07 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 07:00:07 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 07:00:07 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 07:00:13 dnsmasq-dhcp[373]: DHCPINFORM(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 07:00:13 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 07:56:42 pptpd[545]: MGR: dropped slow initial connection
Mar 2 07:59:59 ntp: start NTP update
Mar 2 08:00:02 ntp: start NTP update
Mar 2 08:17:12 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 2 08:17:12 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 2 08:58:55 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 2 08:58:55 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 2 08:59:57 ntp: start NTP update
Mar 2 09:59:57 ntp: start NTP update
Mar 2 10:02:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 2 10:02:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 2 10:16:19 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 10:16:19 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 10:16:19 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 10:16:19 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 10:18:00 kernel: eth2: received packet with own address as source address
Mar 2 10:19:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 10:19:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 10:20:07 kernel: eth2: received packet with own address as source address
Mar 2 10:21:15 kernel: eth2: received packet with own address as source address
Mar 2 10:21:16 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 10:21:16 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 10:24:25 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 2 10:24:25 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 2 10:58:39 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 192.168.5.96 a4:17:31:58:15:af
Mar 2 10:58:39 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 10:58:41 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 192.168.5.96 a4:17:31:58:15:af
Mar 2 10:58:41 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 10:58:49 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 192.168.5.96 a4:17:31:58:15:af
Mar 2 10:58:49 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 10:58:49 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 10:58:49 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 10:59:57 ntp: start NTP update
Mar 2 11:28:05 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 2 11:28:05 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 2 11:48:52 kernel: eth1: received packet with own address as source address
Mar 2 11:48:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 11:48:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 11:48:57 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 11:48:57 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 11:57:22 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 11:57:22 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 11:57:22 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 11:57:22 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 11:58:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 11:58:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 11:58:49 miniupnpd[567]: Expired NAT-PMP mapping port 16067 UDP removed
Mar 2 11:58:49 miniupnpd[567]: Expired NAT-PMP mapping port 16067 TCP removed
Mar 2 11:59:57 ntp: start NTP update
Mar 2 12:05:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 12:05:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 12:05:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 12:05:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 12:05:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 2 12:05:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 2 12:06:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 12:06:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 12:06:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 12:06:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 12:07:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 12:07:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 12:10:29 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 12:10:29 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 12:12:48 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 2 12:12:48 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 2 12:15:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 12:15:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 12:20:15 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:20:15 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:21:15 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:21:15 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:23:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:23:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:24:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:24:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:26:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:26:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:27:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:27:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:29:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:29:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:30:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:30:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:32:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:32:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:33:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:33:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:35:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:35:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:36:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:36:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:38:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:38:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:39:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:39:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:41:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:41:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:42:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:42:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:43:58 miniupnpd[567]: Expired NAT-PMP mapping port 26462 TCP removed
Mar 2 12:43:58 miniupnpd[567]: Expired NAT-PMP mapping port 26462 UDP removed
Mar 2 12:44:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:44:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:45:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:45:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:47:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 12:47:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 12:59:45 kernel: eth2: received packet with own address as source address
Mar 2 12:59:59 ntp: start NTP update
Mar 2 13:06:42 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 13:06:42 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 13:10:59 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 13:10:59 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 13:14:19 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 2 13:14:19 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 2 13:20:39 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 13:20:39 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 13:22:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 13:22:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 13:25:29 kernel: eth1: received packet with own address as source address
Mar 2 13:38:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 2 13:38:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 2 13:50:29 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 13:50:29 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 13:55:34 kernel: eth2: received packet with own address as source address
Mar 2 13:55:57 kernel: eth1: received packet with own address as source address
Mar 2 13:56:00 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 13:56:00 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 13:56:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 13:56:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 13:59:37 kernel: eth1: received packet with own address as source address
Mar 2 14:00:01 ntp: start NTP update
Mar 2 14:16:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 14:16:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 14:36:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 14:36:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 14:40:36 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 2 14:40:36 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 2 14:42:02 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 14:42:02 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 14:42:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 14:42:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 14:45:21 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 14:45:21 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 14:59:57 ntp: start NTP update
Mar 2 15:16:59 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 2 15:16:59 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 2 15:59:57 ntp: start NTP update
Mar 2 16:26:28 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 2 16:26:28 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 2 16:37:30 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 16:37:30 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 16:38:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:38:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:39:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:39:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:40:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 16:40:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 16:40:49 kernel: eth1: received packet with own address as source address
Mar 2 16:41:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:41:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:42:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:42:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:42:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:42:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:43:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:43:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:43:37 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:43:37 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:44:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:44:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:44:06 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:44:06 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:44:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:44:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:45:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:45:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:45:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:45:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:46:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:46:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:46:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:46:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:47:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:47:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:47:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:47:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:48:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:48:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:48:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:48:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:48:35 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:48:35 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:49:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:49:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:49:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:49:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:50:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:50:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:50:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:50:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:51:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:51:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:51:12 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 2 16:51:12 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 2 16:51:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:51:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:52:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:52:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:52:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 16:52:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 16:59:59 ntp: start NTP update
Mar 2 17:45:26 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 2 17:45:26 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 2 17:46:51 kernel: eth2: received packet with own address as source address
Mar 2 17:47:25 kernel: eth1: received packet with own address as source address
Mar 2 17:52:25 kernel: eth2: received packet with own address as source address
Mar 2 17:53:31 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 17:53:31 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 17:53:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 17:53:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 17:54:30 kernel: eth2: received packet with own address as source address
Mar 2 17:55:22 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 17:55:22 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 17:55:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 17:55:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 17:56:59 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 17:56:59 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 18:00:01 ntp: start NTP update
Mar 2 18:15:38 kernel: eth2: received packet with own address as source address
Mar 2 18:15:40 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 18:15:40 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 18:15:40 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 18:15:40 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 18:25:47 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 18:25:47 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 18:25:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 18:25:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 18:30:53 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 2 18:30:53 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 2 18:59:57 ntp: start NTP update
Mar 2 19:36:46 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 2 19:36:46 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 2 19:59:59 ntp: start NTP update
Mar 2 20:00:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 2 20:00:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 2 20:20:51 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 20:20:51 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 20:58:43 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 2 20:58:43 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 2 20:59:57 ntp: start NTP update
Mar 2 21:11:09 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 21:11:09 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 21:11:12 miniupnpd[567]: HTTP Connection from 192.168.5.66 closed unexpectedly
Mar 2 21:43:28 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 2 21:43:28 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 2 21:45:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 21:45:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 21:59:59 ntp: start NTP update
Mar 2 22:51:45 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 22:51:45 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 22:51:48 miniupnpd[567]: HTTP Connection from 192.168.5.66 closed unexpectedly
Mar 2 22:54:41 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 2 22:54:41 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 2 22:59:57 ntp: start NTP update
Mar 2 23:02:44 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 2 23:02:44 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 2 23:10:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 23:10:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 23:10:30 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 23:10:30 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 23:10:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 23:10:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 23:12:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 23:12:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 23:12:07 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 2 23:12:07 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 2 23:13:09 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 23:13:09 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:13:09 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:13:09 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:13:10 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 23:13:10 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:13:10 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:13:10 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:14:35 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:14:35 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:16:05 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:16:05 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:17:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:17:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:19:12 kernel: eth2: received packet with own address as source address
Mar 2 23:19:12 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 23:19:12 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 23:19:31 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 2 23:19:31 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:19:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 2 23:19:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 2 23:20:59 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 2 23:20:59 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 2 23:59:59 ntp: start NTP update
Mar 3 00:11:54 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 00:11:54 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 00:19:21 kernel: eth2: received packet with own address as source address
Mar 3 00:31:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 00:31:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 00:47:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 00:47:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 00:59:57 ntp: start NTP update
Mar 3 01:59:59 ntp: start NTP update
Mar 3 02:05:20 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 02:05:20 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 02:05:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 02:05:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 02:40:27 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 02:40:27 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 02:59:57 ntp: start NTP update
Mar 3 03:17:35 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 03:17:35 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 03:40:25 kernel: eth2: received packet with own address as source address
Mar 3 03:48:32 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 03:48:32 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 03:58:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 03:58:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 03:59:59 ntp: start NTP update
Mar 3 04:19:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 04:19:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 04:59:57 ntp: start NTP update
Mar 3 05:10:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 05:10:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 05:20:10 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 05:20:10 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 05:36:10 kernel: eth2: received packet with own address as source address
Mar 3 05:54:35 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 05:54:35 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 05:54:35 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 05:54:35 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 05:55:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 05:55:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 05:56:02 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 05:56:02 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 05:56:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 05:56:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 05:57:53 pppd[434]: No response to 10 echo-requests
Mar 3 05:57:53 pppd[434]: Serial link appears to be disconnected.
Mar 3 05:57:53 pppd[434]: Connect time 1380.6 minutes.
Mar 3 05:57:53 pppd[434]: Sent 983483418 bytes, received 1799367973 bytes.
Mar 3 05:57:53 dnsmasq[373]: read /etc/hosts - 5 addresses
Mar 3 05:57:53 dnsmasq[373]: using nameserver 130.67.15.198#53 for domain bb.online.no
Mar 3 05:57:53 dnsmasq[373]: using nameserver 193.213.112.4#53 for domain bb.online.no
Mar 3 05:57:56 WAN Connection: Fail to connect with some issues.
Mar 3 05:57:56 stop_nat_rules: apply the redirect_rules!
Mar 3 05:57:59 pppd[434]: Connection terminated.
Mar 3 05:57:59 pppd[434]: Sent PADT
Mar 3 05:57:59 pppd[434]: Modem hangup
Mar 3 05:58:09 pppd[434]: PPP session is 192 (0xc0)
Mar 3 05:58:09 pppd[434]: Connected to 88:e0:f3:b4:5d:7a via interface eth0
Mar 3 05:58:09 pppd[434]: Using interface ppp0
Mar 3 05:58:09 pppd[434]: Connect: ppp0 <--> eth0
Mar 3 05:58:10 pppd[434]: PAP authentication succeeded
Mar 3 05:58:10 pppd[434]: peer from calling number 88:E0:F3:B4:5D:7A authorized
Mar 3 05:58:10 pppd[434]: local IP address 193.x.x.236
Mar 3 05:58:10 pppd[434]: remote IP address 88.x.x.1
Mar 3 05:58:10 pppd[434]: primary DNS address 193.213.112.4
Mar 3 05:58:10 pppd[434]: secondary DNS address 130.67.15.198
Mar 3 05:58:10 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 3 05:58:10 rc_service: ip-up 885:notify_rc stop_pptpd
Mar 3 05:58:10 rc_service: ip-up 885:notify_rc start_pptpd
Mar 3 05:58:10 pptpd[887]: MGR: Config file not found!
Mar 3 05:58:10 pptpd[887]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Mar 3 05:58:10 pptpd[887]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar 3 05:58:10 pptpd[889]: MGR: Manager process started
Mar 3 05:58:10 pptpd[889]: MGR: Maximum of 10 connections available
Mar 3 05:58:10 pptpd[894]: MGR: Config file not found!
Mar 3 05:58:10 pptpd[894]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Mar 3 05:58:10 pptpd[894]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar 3 05:58:10 pptpd[896]: MGR: Manager process started
Mar 3 05:58:10 pptpd[896]: MGR: Maximum of 10 connections available
Mar 3 05:58:10 dnsmasq[373]: read /etc/hosts - 5 addresses
Mar 3 05:58:10 dnsmasq[373]: using nameserver 130.67.15.198#53 for domain bb.online.no
Mar 3 05:58:10 dnsmasq[373]: using nameserver 193.213.112.4#53 for domain bb.online.no
Mar 3 05:58:10 rc_service: ip-up 885:notify_rc stop_upnp
Mar 3 05:58:10 miniupnpd[567]: received signal 15, good-bye
Mar 3 05:58:10 rc_service: ip-up 885:notify_rc start_upnp
Mar 3 05:58:11 syslog: SNet version started
Mar 3 05:58:11 ntp: start NTP update
Mar 3 05:58:11 miniupnpd[936]: HTTP listening on port 38487
Mar 3 05:58:11 miniupnpd[936]: Listening for NAT-PMP traffic on port 5351
Mar 3 05:58:11 WAN Connection: WAN was restored.
Mar 3 05:59:57 ntp: start NTP update
Mar 3 06:22:17 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 06:22:17 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 06:59:57 ntp: start NTP update
Mar 3 07:04:57 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 07:04:57 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 07:15:51 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 10:0b:a9:58:50:78
Mar 3 07:15:51 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 07:15:51 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 07:15:51 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 07:15:55 dnsmasq-dhcp[373]: DHCPINFORM(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 07:15:55 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 07:44:00 kernel: eth2: received packet with own address as source address
Mar 3 07:49:19 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 07:49:19 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 07:49:19 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 07:49:19 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 07:51:14 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 07:51:14 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 07:51:14 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 07:51:14 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 07:51:23 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 10.10.1.146 7c:11:be:bb:4f:08
Mar 3 07:51:23 dnsmasq-dhcp[373]: DHCPNAK(br0) 10.10.1.146 7c:11:be:bb:4f:08 wrong network
Mar 3 07:51:28 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 7c:11:be:bb:4f:08
Mar 3 07:51:28 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 07:51:29 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 07:51:29 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 07:51:48 pptpd[896]: MGR: initial packet length 18245 outside (0 - 220)
Mar 3 07:59:59 ntp: start NTP update
Mar 3 08:02:16 kernel: eth2: received packet with own address as source address
Mar 3 08:05:35 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 08:05:35 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:05:35 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:05:35 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 08:07:02 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 08:07:02 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:07:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:07:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 08:17:20 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 08:17:20 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 08:21:08 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:21:08 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 08:21:34 kernel: eth2: received packet with own address as source address
Mar 3 08:23:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 08:23:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 08:23:54 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 08:23:54 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 08:29:37 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 08:29:37 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 08:43:14 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 08:43:14 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 08:46:22 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 7c:d1:c3:e4:fd:3b
Mar 3 08:46:22 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.79 7c:d1:c3:e4:fd:3b
Mar 3 08:46:24 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.79 7c:d1:c3:e4:fd:3b
Mar 3 08:46:24 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.79 7c:d1:c3:e4:fd:3b Axels-Air
Mar 3 08:46:26 miniupnpd[936]: unsupported NAT-PMP version : 2
Mar 3 09:00:01 ntp: start NTP update
Mar 3 09:00:43 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 09:00:43 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 09:07:50 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 09:07:50 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 09:08:33 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 10.10.2.1 7c:2f:80:55:b9:d1
Mar 3 09:08:33 dnsmasq-dhcp[373]: DHCPNAK(br0) 10.10.2.1 7c:2f:80:55:b9:d1 wrong network
Mar 3 09:08:37 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 7c:2f:80:55:b9:d1
Mar 3 09:08:37 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.93 7c:2f:80:55:b9:d1
Mar 3 09:08:37 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.93 7c:2f:80:55:b9:d1
Mar 3 09:08:37 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.93 7c:2f:80:55:b9:d1 C610A-IP
Mar 3 09:33:45 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 09:33:45 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 09:34:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 09:34:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 09:58:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 09:58:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 09:59:57 ntp: start NTP update
Mar 3 10:14:19 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.38.103 38:59:f9:44:2f:b9
Mar 3 10:14:19 dnsmasq-dhcp[373]: DHCPNAK(br0) 192.168.38.103 38:59:f9:44:2f:b9 wrong network
Mar 3 10:14:22 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 38:59:f9:44:2f:b9
Mar 3 10:14:22 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 10:14:30 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 38:59:f9:44:2f:b9
Mar 3 10:14:30 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 10:14:30 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 10:14:30 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 10:14:34 dnsmasq-dhcp[373]: DHCPINFORM(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 10:14:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 10:19:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 10:19:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 10:23:55 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 10:23:55 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 10:44:12 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 10:44:12 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 10:46:26 miniupnpd[936]: Expired NAT-PMP mapping port 5354 UDP removed
Mar 3 10:49:50 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 10:49:50 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 10:57:36 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 10:57:36 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 10:57:36 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 10:57:36 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 10:58:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 10:58:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 10:58:33 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.60 7c:11:be:bb:4f:08
Mar 3 10:58:33 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.60 7c:11:be:bb:4f:08 iphone
Mar 3 10:58:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 10:58:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 10:59:57 ntp: start NTP update
Mar 3 11:00:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 11:00:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 11:01:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:01:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:02:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:02:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:04:36 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:04:36 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:09:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 11:09:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 11:10:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 11:10:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 11:11:02 dnsmasq-dhcp[373]: DHCPDISCOVER(br0) d0:22:be:e5:24:59
Mar 3 11:11:02 dnsmasq-dhcp[373]: DHCPOFFER(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 11:11:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 11:11:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 11:11:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:11:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:11:09 kernel: eth1: received packet with own address as source address
Mar 3 11:11:09 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 11:11:09 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 11:11:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:11:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:12:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:12:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:13:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:13:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:13:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:13:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:14:01 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 11:14:01 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 11:14:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 11:14:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 11:14:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:14:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:15:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:15:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:15:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:15:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:16:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:16:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:16:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:16:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:19:32 kernel: eth1: received packet with own address as source address
Mar 3 11:20:03 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:20:03 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:20:33 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:20:33 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:21:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:21:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:21:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:21:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:22:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 11:22:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 11:23:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:23:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:23:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 11:23:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 11:24:05 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 11:24:05 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 11:32:21 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 11:32:21 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 11:38:23 kernel: eth1: received packet with own address as source address
Mar 3 11:40:26 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 11:40:26 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 11:59:59 ntp: start NTP update
Mar 3 12:08:21 miniupnpd[936]: Expired NAT-PMP mapping port 26462 TCP removed
Mar 3 12:08:21 miniupnpd[936]: Expired NAT-PMP mapping port 26462 UDP removed
Mar 3 12:23:21 miniupnpd[936]: Expired NAT-PMP mapping port 16067 UDP removed
Mar 3 12:23:21 miniupnpd[936]: Expired NAT-PMP mapping port 16067 TCP removed
Mar 3 12:25:39 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 12:25:39 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 12:33:09 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 12:33:09 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 12:39:02 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.93 7c:2f:80:55:b9:d1
Mar 3 12:39:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.93 7c:2f:80:55:b9:d1 C610A-IP
Mar 3 12:40:54 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 12:40:54 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 13:00:01 ntp: start NTP update
Mar 3 13:25:40 miniupnpd[936]: Expired NAT-PMP mapping port 16067 UDP removed
Mar 3 13:25:40 miniupnpd[936]: Expired NAT-PMP mapping port 16067 TCP removed
Mar 3 13:30:08 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 13:30:08 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 13:56:41 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.66 c8:f7:33:ab:a4:c3
Mar 3 13:56:41 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.66 c8:f7:33:ab:a4:c3 Samsung5
Mar 3 13:59:57 ntp: start NTP update
Mar 3 14:02:42 kernel: eth2: received packet with own address as source address
Mar 3 14:06:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:06:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:11:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:11:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:16:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:16:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:19:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:19:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:27:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:27:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:30:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:30:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:31:13 dnsmasq-dhcp[373]: DHCPINFORM(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 14:31:13 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 14:37:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 14:37:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 14:39:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:39:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:41:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:41:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:44:06 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.96 d0:22:be:e5:24:59
Mar 3 14:44:06 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.96 d0:22:be:e5:24:59 android-9329984121c4d663
Mar 3 14:45:14 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 14:45:14 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 14:46:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:46:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:51:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:51:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:55:31 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 14:55:31 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 14:56:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:56:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:58:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:58:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:59:34 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 14:59:34 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 14:59:57 ntp: start NTP update
Mar 3 15:11:00 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 15:11:00 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 15:47:46 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 15:47:46 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 15:55:59 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.93 7c:2f:80:55:b9:d1
Mar 3 15:55:59 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.93 7c:2f:80:55:b9:d1 C610A-IP
Mar 3 15:59:57 ntp: start NTP update
Mar 3 16:23:55 miniupnpd[936]: Expired NAT-PMP mapping port 26462 TCP removed
Mar 3 16:23:55 miniupnpd[936]: Expired NAT-PMP mapping port 26462 UDP removed
Mar 3 16:32:04 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.62 38:59:f9:44:2f:b9
Mar 3 16:32:04 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.62 38:59:f9:44:2f:b9 Hanna-PC
Mar 3 16:45:08 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 16:45:08 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 16:59:57 ntp: start NTP update
Mar 3 17:48:36 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 17:48:36 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 17:51:39 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.89 00:08:5d:3d:d7:2c
Mar 3 17:51:39 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.89 00:08:5d:3d:d7:2c 6739i00085D3DD72C
Mar 3 17:59:57 ntp: start NTP update
Mar 3 18:06:28 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.86 e4:11:5b:04:51:e0
Mar 3 18:06:28 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.86 e4:11:5b:04:51:e0 HP0451E0
Mar 3 18:15:02 dnsmasq-dhcp[373]: DHCPINFORM(br0) 192.168.5.87 10:0b:a9:58:50:78
Mar 3 18:15:02 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.87 10:0b:a9:58:50:78 Lenovo-PC
Mar 3 18:59:57 ntp: start NTP update
Mar 3 19:01:36 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.54 00:08:5d:3d:d7:3c
Mar 3 19:01:36 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.54 00:08:5d:3d:d7:3c 6739i00085D3DD73C
Mar 3 19:10:50 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.93 7c:2f:80:55:b9:d1
Mar 3 19:10:50 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.93 7c:2f:80:55:b9:d1 C610A-IP
Mar 3 19:36:21 WAN Connection: Ethernet link down.
Mar 3 19:36:21 stop_nat_rules: apply the redirect_rules!
Mar 3 19:36:46 WAN Connection: WAN was restored.
Mar 3 19:36:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 3 19:37:16 pppd[434]: No response to 10 echo-requests
Mar 3 19:37:16 pppd[434]: Serial link appears to be disconnected.
Mar 3 19:37:16 pppd[434]: Connect time 819.1 minutes.
Mar 3 19:37:16 pppd[434]: Sent 1695082998 bytes, received 650900976 bytes.
Mar 3 19:37:16 WAN Connection: Ethernet link down.
Mar 3 19:37:16 stop_nat_rules: apply the redirect_rules!
Mar 3 19:37:16 dnsmasq[373]: read /etc/hosts - 5 addresses
Mar 3 19:37:16 dnsmasq[373]: using nameserver 130.67.15.198#53 for domain bb.online.no
Mar 3 19:37:16 dnsmasq[373]: using nameserver 193.213.112.4#53 for domain bb.online.no
Mar 3 19:37:21 WAN Connection: Fail to connect with some issues.
Mar 3 19:37:22 pppd[434]: Connection terminated.
Mar 3 19:37:22 pppd[434]: Sent PADT
Mar 3 19:37:22 pppd[434]: Modem hangup
Mar 3 19:37:52 pppd[434]: PPP session is 189 (0xbd)
Mar 3 19:37:52 pppd[434]: Connected to 88:e0:f3:b4:5d:7a via interface eth0
Mar 3 19:37:52 pppd[434]: Using interface ppp0
Mar 3 19:37:52 pppd[434]: Connect: ppp0 <--> eth0
Mar 3 19:37:52 pppd[434]: PAP authentication succeeded
Mar 3 19:37:52 pppd[434]: peer from calling number 88:E0:F3:B4:5D:7A authorized
Mar 3 19:37:52 pppd[434]: local IP address 193.x.x.236
Mar 3 19:37:52 pppd[434]: remote IP address 88.x.x.1
Mar 3 19:37:52 pppd[434]: primary DNS address 193.213.112.4
Mar 3 19:37:52 pppd[434]: secondary DNS address 130.67.15.198
Mar 3 19:37:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 3 19:37:52 rc_service: ip-up 1045:notify_rc stop_pptpd
Mar 3 19:37:53 rc_service: ip-up 1045:notify_rc start_pptpd
Mar 3 19:37:53 pptpd[1047]: MGR: Config file not found!
Mar 3 19:37:53 pptpd[1047]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Mar 3 19:37:53 pptpd[1047]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar 3 19:37:53 pptpd[1049]: MGR: Manager process started
Mar 3 19:37:53 pptpd[1049]: MGR: Maximum of 10 connections available
Mar 3 19:37:53 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 3 19:37:53 pptpd[1059]: MGR: Config file not found!
Mar 3 19:37:53 pptpd[1059]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Mar 3 19:37:53 pptpd[1059]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar 3 19:37:53 pptpd[1061]: MGR: Manager process started
Mar 3 19:37:53 pptpd[1061]: MGR: Maximum of 10 connections available
Mar 3 19:37:53 dnsmasq[373]: read /etc/hosts - 5 addresses
Mar 3 19:37:53 dnsmasq[373]: using nameserver 130.67.15.198#53 for domain bb.online.no
Mar 3 19:37:53 dnsmasq[373]: using nameserver 193.213.112.4#53 for domain bb.online.no
Mar 3 19:37:53 rc_service: ip-up 1045:notify_rc stop_upnp
Mar 3 19:37:53 miniupnpd[936]: received signal 15, good-bye
Mar 3 19:37:53 rc_service: ip-up 1045:notify_rc start_upnp
Mar 3 19:37:53 syslog: SNet version started
Mar 3 19:37:53 miniupnpd[1096]: HTTP listening on port 52834
Mar 3 19:37:53 miniupnpd[1096]: Listening for NAT-PMP traffic on port 5351
Mar 3 19:37:56 WAN Connection: WAN was restored.
Mar 3 19:37:56 ntp: start NTP update
Mar 3 19:47:52 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.97 a4:17:31:58:15:af
Mar 3 19:47:52 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.97 a4:17:31:58:15:af Notandi-PC
Mar 3 19:56:57 dnsmasq-dhcp[373]: DHCPREQUEST(br0) 192.168.5.56 00:08:5d:3d:d7:3e
Mar 3 19:56:57 dnsmasq-dhcp[373]: DHCPACK(br0) 192.168.5.56 00:08:5d:3d:d7:3e 6739i00085D3DD73E
Mar 3 19:59:57 ntp: start NTP update
Mar 3 20:30:46 pptpd[1106]: CTRL: Client 84.208.204.15 control connection started
Mar 3 20:30:47 pptpd[1106]: CTRL: Starting call (launching pppd, opening GRE)
Mar 3 20:30:47 pptp[1107]: Plugin pptp.so loaded.
Mar 3 20:30:47 pptp[1107]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Mar 3 20:30:47 pptp[1107]: pppd 2.4.7 started by Island, uid 0
Mar 3 20:30:47 pptp[1107]: Using interface ppp10
Mar 3 20:30:47 pptp[1107]: Connect: ppp10 <--> pptp (84.208.204.15)
Mar 3 20:30:50 pptpd[1106]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Mar 3 20:30:50 pptp[1107]: MPPE 128-bit stateless compression enabled
Mar 3 20:30:50 pptp[1107]: Cannot determine ethernet address for proxy ARP
Mar 3 20:30:50 pptp[1107]: local IP address 192.168.5.1
Mar 3 20:30:50 pptp[1107]: remote IP address 192.168.99.2
Utdrag av et tidsrom med problemer:
Håper noen kan guide meg litt videre i feilsøkingen :)
Orker ikke å tolke loggene, har du tidspunkt og dato når dette skjedde sist? Da vi se akkurat på tidspunktet.
Ops, jeg så ikke nederste spoiler...
Endret av Gjest
Her er det tydelig problem med trådparene som fører linja di. Du får ringe 05000 og be de utføre en linjesjekk samt feilmelde at du opplever dropp på linja :)
  • 3 uker senere...
