Prostata-stimulering for menn, tips?
Har kjøpt en Naughty Boy prostatavibrator, men hvordan bruke den? Vil bruke den alene nå i starten.
Jeg forstår at det kan ta tid for å bli vane med den og lære seg riktig bruk. Vil gjerne oppnå en sterkere orgasme enn ved masturbering.
Fant en veiledning på hjemmesiden til Aneros, en annen produsent. Er dette en god start, eventuelt andre tips?
Preparation
These instructions are a good baseline for your sessions with the Aneros. We encourage you to experiment with different positions, breathing exercises, relaxation techinques, and methods of arousal. And remember, the Aneros is hands-free. First, learn how to prepare for an Aneros session.
Preparation
  • To insure hygienic operation, make sure the rectum is empty before use. The rectum is generally empty, but we recommend rinsing the rectum with a rectal syringe – commonly available at your local pharmacy.
  • Lie on either side and bend the knees close to the stomach. This is intended to allow you to relax and to best orient the massager towards the prostate.
  • Apply a liberal amount of lubricant to the anus and to the Aneros Massager. You can do this using your finger. A generic lubricant applicator or Aneros Marksman lubricant applicators are good options here as well. This step is important because the Aneros functions best when suspended within this fluid environment. The Aneros will actually be moving, pivoting, inside your body. This is a key to its effectiveness.
Relaxation/Concentration
Now that you have completed the preparations, learn how to insert your Aneros Massager. Relax, then begin your breathing exercises and contractions.
Stage 1 – Relaxation & Concentration
Position the Aneros Massager so that the perineum abutment (tab top of the thicker, upturned arm) will press against the perineum acupressure spot when the Aneros Massager is fully inserted into the anus. The thinner, curled arm should be oriented towards the back.
Slowly insert the Aneros Massager about one half of the way into the anus; it will then be drawn the rest of the way into the rectum and accurately position itself against the prostate with the perineum abutment pressing firmly against the perineum acupressure spot. The anal canal, front wall of the rectum, prostate, and the perineum acupressure point will be stimulated simultaneously by the Aneros Massager. At this time, many inexperienced users will feel the urge to urinate.
IMPORTANT: * The perineum abutment (top of front arm) should always press against the perineum during use. It is very important to keep the Aneros Massager facing in the proper direction. If you insert the Aneros Massager backwards, you can not correctly stimulate the involved sex organs. This will drastically reduce the effectiveness of the Aneros Massager.
To ensure that the Aneros Massager is properly inserted, use the handle/guide to position the perineum abutment against the perineum acupressure spot. The perineum acupressure spot is located between the anus and the scrotum, usually 1.5 to 2 inches from the anus toward the scrotum.
Keep the perineum area dry to ensure the perineum abutment won’t slip from the perineum acupressure spot.
When the Aneros Massager is fully drawn into the anus, you will initially feel the pressure of the foreign object. For best results, allow 10 to 20 minutes for relaxation. During this time, we recommend meditative breathing exercises.
Slowly inhale for 4 – 8 seconds, hold this breath for several seconds, now slowly exhale for 4 – 8 seconds. Relax and concentrate on the sensations in the anal area. The anus will accommodate the Aneros Massager and the foreign sensation will fade. Release all tensions and expectations with each exhalation.
Contractions
Anal Sphincter Muscle Contractions are fuel for the Aneros. In this section, you will learn more about these contractions and their relationship to different levels of pleasure.
Stage 2 – Contraction Exercises
Now that you are fully relaxed and building awareness of the sensations inside the anal canal, you are ready to begin the contraction exercises. Continue to breath slowly and begin to contract the sphincter muscle in time with your breathing. Inhale deeply as you contract the muscles and exhale as you relax. Repeat this exercise 20 – 30 times. Now your body is ready to achieve a new kind of orgasm.
Note: This exercise strengthens the anal sphincter and increases the blood circulation to the region. Increased circulation results in fresh supplies of oxygen and constant purging of toxins. Thus, these exercises will not only tone the lower tracts but cleanse them as well. Sexual sensitivity will also increase.
Now you can begin to touch your body wherever you feel sexually sensitive, these actions will add to your pleasure. However, avoid stimulating the penis at this time, as it may cause ejaculation.
Concentrate your mind on your prostate. Slowly contract your anal sphincter to about one fourth to half of full contraction strength and maintain this level of contraction. Holding this level of contraction is difficult – anal muscles will quiver and may spasm causing a vibration that corresponds to the muscle’s involuntary movements. This dynamic interaction between the voluntary and involuntary muscular contractions is important in achieving hands-free ejaculation.
Because the Aneros Massager is suspended unstably within the anal canal, the slightest muscular action and even the pulsing of blood vessels infiltrating the anal canal and surrounding the prostate is detected by the Aneros and directly transmitted to the anal canal, prostate and the perineum acupressure point. These sensations are positively relayed back to the anus, and this chain reaction accelerates to a nearly explosive point. During this session, it is possible to adjust the location of the Aneros by slightly increasing or decreasing your contraction strength. In this manner, you may position the Aneros Massager to a point most preferable to you. In conjunction with the degree of pressure applied to the perineum acupressure point, all points along the front wall of the rectum from the anus to the ampulla of vas above the prostate will reflect different types and degrees of pleasurable sensations. This area is a treasure trove of erogenous stimuli.
Gentle anal contraction is more likely to cause anal orgasms, whereas stronger contractions will lead to prostate-generated orgasms or a combination of sensations.
Note: At this time, lubricant plays an important role to keep the Aneros Massager as slippery as possible so that the massager’s movement is easily effected by the anal sphincter’s actions.
Make a strong contraction of your anal sphincter. As you increase the strength of the contraction, the Aneros Massager will be drawn deeper toward the prostate as it moves in a stroking motion with increasing pressure. The perineum abutment accordingly increases the pressure on the perineum acupressure point. During this practice you can lie on your back and push your hips down against a surface if you like. This helps the Aneros add more pressure against the prostate and the perineum.
Extend the Pleasure
You are now at the point where you have complete control over your contractions. Use this control to prolong the pleasure and have orgasm after orgasm with your Aneros massager.
Stage 3 – Extending the Pleasure
When the Aneros Massager gets you to that pinnacle where ejaculation feels imminent, try to stay at this point by controlling the degree of your sphincter contractions. The deep feeling gradually increases and accumulates to the peak point. The muscles of your whole body are contracted and shaken by this strong orgasm without ejaculation. This orgasm comes repeatedly like ocean waves. The duration of this peak orgasm is probably longer (more than 2 minutes) and stronger than a normal ejaculatory orgasm, and this orgasm has a sharp peak rising from a continuous higher plateau stage. At this apex, most of your glands, including your salve gland and anal secretion gland, prepare for ejaculation, but your penis does not ejaculate. It is a superior and different experience.
Another remarkable thing about this orgasm is that it is physically controllable. This means you can achieve this orgasm as many times as you want by controlling the anal sphincter and regulating body tension. Also, unlike the penis ejaculatory orgasm, each of these orgasms will have a different signature. Consequently, it is possible for you to experience several different kinds of orgasms in one session.
Note: Your body is completely responsible for manipulating the mechanism of the Aneros Massager. You can in effect turn “off” the device by completely relaxing your sphincter, and turn it “on” by contracting your sphincter. In this manner, it is possible to prolong and build up the effect of the subsequent orgasm.
Penile Stimulation
Using the Aneros is a journey into awareness of your own body. Here we describe some techniques used to reach what have been reported to us as altered states of euporia. This is the Dream Orgasm, the Super-O.
Stage 4 – Penile Stimulation
Now you may stimulate the penis glans if you prefer. This will bring you close to the threshold of ejaculation. When you feel ejaculation to be imminent, immediately stop penile stimulation to avoid ejaculation and quickly add more tension to the sphincter, muscles controlling erection, and your entire body.
Contract your anal sphincter together with the penis erection muscles as strong as you can. This practice will cause more blood to flow through your penis. You will actually feel your penis expanding and swelling. Keep this contraction as long as you can. This is very good practice to maximize prolonged expanded erection of your penis without a vacuum pump, penis ring, etc.
Note: For best results, bend the knees close to the stomach, squeeze the scrotum between the inner thighs (you can cross your thighs to squeeze more) then stretch your legs so that the penis skin and the scrotum are pulled back toward the base. It seems like the penis itself is stretched out, increasing its hardness and sensitivity. You may feel some pleasurable tautness caused by the stress added to the skin. As you approach orgasm, you will feel a contraction-like movement within the testicles.
Some people have ejaculatory orgasms without penile glans stimulation. Sometimes, just the tension applied to the penile skin will cause ejaculation. Ejaculatory orgasm can be easily achieved through stimulation of the penis glans.
You may also choose to have intercourse while using the Aneros Massager. This kind of ejaculation should be the strongest. When you reach the point of no return, you will feel your anus begin to pump rhythmically, relaxing and contracting several times before the start of ejaculation. During the ejaculation, the strong orgasmic contractions will cause the Aneros Massager to stroke the prostate and other vital sex organs with each contraction. This action will completely empty your prostate of fluid. The strength and the amount of the ejaculation will be far greater than that achieved by any other conventional sexual technique.
Euphoric States
Stage 5 – Altered States of Euphoria
For the advanced user:
To build upon the preceding practices you must gain a greater awareness of your mind and body – and learn to integrate this awareness into practice. The most sublime orgasms are achieved when you do so without penile stimulation and without exerting external force upon the Aneros. To achieve these results, you must concentrate on using and feeling the sphincter contractions to slowly and methodically control the movement of the Aneros and other muscles of the body.
Begin by slowly increasing tension to the anal sphincter as you stretch your legs and arc your body, adding complete body muscle tension as strongly as you can. Perform these movements slowly, keeping your mind focused on the variations of sensation throughout your body.
Try to increase body tension to the point where your muscles are quivering but not cramping. Continue with the contractions of the sphincter – first slowly, then more quickly. Maintain synchronized breathing as much as possible – If the muscles begins to tire, try to hold the contraction at less than maximum (i.e. Don’t tense up) for several seconds at a time. You can gauge this by attempting to stabilize the pressure that the perineum tab exerts solely by contracting the sphincter. This may take some practice.
Avoid direct stimulation of the penis. Continue to add more whole-body muscle tension until this practice brings you to the threshold of ejaculation. Just before that point, adjust or loosen your body tension to remain balanced upon that threshold, without passing over to the point of ejaculation. Immediately after you halt ejaculation, another new kind of strong orgasm will appear. The source of this orgasm is shifted from the prostate to the anus (this phenomenon will appear only when you come close to the threshold of ejaculation without touching your penis). This orgasmic peak will continue for several minutes, much different from the typical ejaculatory orgasm. In this manner, an extended, more powerful orgasm can be experienced. Many users have reportedly entered into euphoric and altered states of consciousness during this phase.
Anonymous poster hash: 32cd8...5d8
Leste at regelmessig tømming av prostata minsker sjansen for prostatakreft. Uten at jeg har lenke til den saken nå da.
Man tømmer forsåvidt prostata ved vanlig masturbering/sex også, men prostatastimulering er jo godt da.
Bro science. Prostata tømmer seg helt fint på egen hånd når det trengs selv om man ikke selv fremkaller ejakulasjon.
Til TS: stapp inn i rumpa den enden der vibratoren ikke sitter og juster på ting til det føles digg. Du kjenner når den tuppen treffer prostata, for å si det sånn.
Anonymous poster hash: f8264...0eb
(TS her)
Om noen vil la tabu begrense dem her i livet, så for all del, men det er ikke meg. :wee:
Har lest litt mer rundt og tror jeg vil anskaffe en Aneros. Det er visst mye å ta hensyn til ved prostata-stimulering, og min første tanke om å putte den inn og runke som normalt var visst en bom. Tvert imot anbefaler de å holde seg unna penis, siden den fort kan bli overstimulert og føre til ejakulasjon, som avslutter festen. I tillegg fungerer det veldig forskjellig fra normal masturbering, der du kan dra den ut, slite litt i den og så er det gjort.
Det viktig å ta seg tid og være tolmodig. Det varierer visst stort hvor lang tid det tar før den enkelte oppnår serieorgasmer, og spesielt Super-O, som visstnok er den hellige gral. Men alle som skriver om det, sier at det er viktig å ikke være utolmodig, da kan det gå tregere. Tvert imot var veien til de forskjellige orgasmene veldig moro. Folk er forskjellige og noen oppnår aldri de beste orgasmene, selv etter årevis med bruk.
Fant etter hvert en Wiki for Aneros som går ganske detaljert inn i hvordan du bør gå frem. Ganske lang tekst, men det ser ut som forberedelser og stemningen er ganske avgjørende. Prostata er ikke en knapp du bare kan trykke på.
Dersom jeg vil prøve andre med vibrasjon, så har seg sett på Nexus Revo 2, som får mye god omtale. Finnes og de som er manuelle, der du bruker hendene til å bevege den.
Det finnes mange forskjellige meninger rundt helseeffekten av prostata-stimulering, men jeg har sett fleire uttalelser fra leger som sier at det ikke finnes studier som påviser det, og det er ikke noe viktig poeng for min del. Dersom det skulle ha noen fordel så er det flott, betyr det ingenting så er det greit.
Min erfaring med prostata og prostataorgasmer er at de er veldig mye mer intense enn vanlige orgasmer. Jeg har prøvd sånn aneros-greier, men jeg fikk aldri skikkelig fart på det. Kan ha noe med anatomien min å gjøre, men for meg virket den for liten og/eller for kort, så den traff aldri skikkelig.
Jeg har for øvrig etter hvert begynt å få til hands-free prostataorgasmer uten å ha noe i rompa i det hele tatt; kun ved rytmisk sammentrekning av bekkenmuskulaturen (kegel-øvelser basically). Kan godt tenkes opplevelsen hadde blitt enda bedre hadde jeg brukt slike leketøy det snakkes om her i tråden.
(ikke TS, igjen)
Stimulering der er ikke noe jeg gjør for ofte selv. Ganske sjelden. Men litt eksperimentering har jeg nå gjort. Første opplevelse: Gjorde rent skaftet på et hardplastshåndtak på skrujern. Var ganske ok, og det funket.
Kjøpte en silikondildo en gang. Den var avstøpt av en nokså stor kar. Silikonmaterialet er altfor hardt, og størrelsen passet ikke for denne bruken, synes jeg da. Det endte med at jeg fikk litt ubehag og blødde litt. Det fikset seg naturlig. Gikk til doktor og ba ham sjekke for hemorider. Så han stappet et, hehe periskop opp bak der, og fant ingenting alvorlig sa han. Jeg kastet selvfølgelig den fæle harde silikondildoen. Ellers kan jeg si om den at den ikke luktet særlig sunt, den stinket fra silikonmaterialet. Men, jeg skulle jo ikke bære den i kroppen som et silikoninnlegg.
Noen som har plantet buttplug der bak og gått rundt en hel / halv dag. Har det tilgode ;)
Neste gang kjøpte jeg en Anal angler. Masse småkuler som er i formen på en analdildo. Den er grei nok, men ikke noe supert overtak på skrujernet. Mulig det finnes mye bedre produkter, ala det dere diskuterer her i tråden.
Jeg klarer meg fint i det daglige med kjæreste (dame) og runking med eller uten porno. Så får analeksperimentering være et ekstra gode man kan ty til hvis man får lyst.
Anonymous poster hash: 82578...5cd
