Hvordan ble nettverksadministrasjon gjort før AD?
_X_
Det er jo bare å se på hva IETF sier selv det.
3. Goals of RMON
o Offline Operation
There are sometimes conditions when a management station will
not be in constant contact with its remote monitoring devices.
This is sometimes by design in an attempt to lower
communications costs (especially when communicating over a WAN
or dialup link), or by accident as network failures affect the
communications between the management station and the probe.
For this reason, RMON allows a probe to be configured to
perform diagnostics and to collect statistics continuously,
even when communication with the management station may not be
possible or efficient. The probe may then attempt to notify
the management station when an exceptional condition occurs.
Thus, even in circumstances where communication between
management station and probe is not continuous, fault,
performance, and configuration information may be continuously
accumulated and communicated to the management station
conveniently and efficiently.
o Proactive Monitoring
Given the resources available on the monitor, it is potentially
helpful for it to continuously run diagnostics and to log
network performance. The monitor is always available at the
onset of any failure. It can notify the management station of
Kilde: https://www.ietf.org/rfc/rfc3577.txt
Takk! Mye bra info her.
Kan jeg spørre om en ting til?
Brannslukkingsdrift og forebyggende drift er jo dyrt å gjennomføre hver for seg, hverfall dersom man rendyrker en av metodene. Men hva er egentlig årsaken til det? Og hvor bør man plassere seg i forhold til de 2 metodene?
NESTEN lyst å spørre om hva data man har til grunnlag for dette spørsmålet...
"Brannslukkingsdrift og forebyggende drift er jo dyrt å gjennomføre hver for seg" = Hva er alternativet?
"hverfall dersom man rendyrker en av metodene" = Hva koster det ene og den andre?
Men for å svare på spm. så blir det samme som B82. Men alt er relativt. For en bank koster brannslukking mye mer enn forebyggende da det koster dem mye å ha nedetid. For en mindre bedrift/ikke like "oppetid avhengig" bedrift kan brannslukking være mest lønnsomt for man fikser de faktiske problemene og bruker ikke timer på å "løse problemer som ikke er der".
  • 3 uker senere...
Hvis to private nettverk er koblet til hverandre ved hjelp av VPN-forbindelse over Internett. Hva slags innvirkning på kommunikasjon har brannmurer og rutere på vegen mellom dæm to nettverkene?
Endret av _X_
  • 2 uker senere...
