Cities: Skylines-tråden
Jeg skal ærlig innrømme at det frister altså.
Har ikke satt meg nok inn i hva som kommer som en gratis oppdatering og hva som må kjøpes.
Sto vel ganske greit her:
1.3.0-f4
Paid content Snowfall Expansion
  • Winter theme added
  • 3 winter maps
  • 3 new winter parks
  • 4 new landmark buildings
  • Snow (generated on buildings)
  • Snowfall
  • Northern lights
  • Chirper variations and new chirps
  • Winter citizens
  • Winter trees
  • Winter props
  • Cars slow down on snow
  • Some twinkle!
  • New sounds
  • New music
  • Winter versions for a few After Dark growables added
  • Tram added
  • Tram rails, electricity poles and models
  • Tram roads and bridges/tunnels
  • Tram stops
  • Tram depot
  • Thumbnails and tooltips
  • Added to the public transport Info view
  • Added to the economy panel
  • Snow plows, that remove the snow from roads, and snow dump
  • Heating
  • Pipes
  • Geothermal Heating Plant
  • Boiler Station
  • Road maintenance service
  • Road maintenance truck and depot
  • Road condition affects car speed
  • Sauna
  • Temperature affects electricity and heat consumption
  • 8 new Steam achievements
  • 4 new policies
  • New loading tips
  • New loading images
Free for all players:
  • Expanded public transportation UI
  • Line detail / visibility icons
  • Public transport lines panel (sorting of lines by name, vehicle count, passenger count or number of stops, color and renaming and day/night/daynight lines settings) available from the public transport info view
  • Theme editor
  • Added information on which custom map theme is used for a map to New game, Load game, New map and Load map panels, including the theme author name
  • Warning added when trying to use a map or save that has a missing custom map theme
  • New map panel allows custom themes when starting a new map
  • Weather
  • Rain
  • Fog
  • 5 new Steam achievements
  • Thermometer shows current temperature either in Celsius or Fahrenheit
  • Trams/taxi in info view now scalable size
  • Tunnel entrances have lights
  • WORKSHOP PANEL NOW DO ... INSTEAD OF CUTTING TEXT !!!!!
  • Background menu image fading based on what DLCs are owned
  • Main menu DLC badges
  • Building collision height includes props/trees
  • Small fixes for numerous buildings
  • Terrain cliffs and sand have now higher texel density.
  • Terrain cliff and sand textures have been improved and more uniformly tiled relative to different themes.
  • Fixed: Expansion 1: "2x2 Pub" gets built in Tourism districts and not Leisure districts
  • Fixed: Expansion 1: Design: 1x1_Souvenir Shops are built in Leisure Specilization districts.
  • Fixed: Expansion 1: Three assets are in the wrong category in the Asset Editor
  • Fixed: Expansion 1: "2x2 Beauty Salon" has wrong sort of names
  • Fixed: Expansion 1: Polish text for "User Interface Volume" goes out of bounds
  • Fixed: Russian option text in Display Mode scroll list goes out of bounds
  • Fixed: SPA/RUS: Options: The Aspect Ratio drop-down menu has cut-off text
  • Fixed: Magicka Theme Park is unevenly lit at night
  • Fixed: There is no "Normal" style for European maps
  • Fixed: Animated parks and unique buildings have flashing people and animals when viewed from the Electricity info view
  • Fixed: Elevated roads cannot be upgraded
  • Fixed: Some parks can be built under an elevated road, causing collision issues
  • Fixed: Solar Power plants description doesn't match the functionality
  • Fixed: It's possible to access locked construction menu tabs if loading into a smaller city save game from a large city save game
  • Fixed: Some citizens remain in parks indefinitely and sometimes retain their child bodies
  • Fixed: Graphics: Most props on the Magicka Theme Park are losing textures while zoomed out
  • Fixed: Tourism drops significantly in cities which have reached an attractiveness limit
  • Fixed: If too many 1x1 buildings are built close to each other, they, along with nearby buildings, will disappear if the user zooms out the
    view.
  • Fixed: An error message appears when attempting to continue a power line by selecting the top-most part of a pylon.
  • Fixed: AI: After loading a saved game, multiple vehicles return to their depot.
Mener jeg leste om at de jobber med dynamiske årstider.
Fint om du kunne finne ut hvor du leste det, for jeg mener å ha lest det motsatte: at det ikke er aktuelt (litt avhengig av hvordan man tolker det korte utsagnet). Hadde vært gledelig om det viser seg at de egentlig ikke har bestemt seg helt endelig iallfall.
Finner det ikke igjen. :(
Det stod vel ikke direkte at de jobbet med det, men at det i første omgang ville være fast årstid.
Da har man plotta ned deler av gamle nedre Manhattan og fått tatt noen skikkelig flotte bilder som like godt kunne vært ekte.
Fra Brooklyn:
Endret av Gjest
  • 2 uker senere...
Skeptisk til Snowfall når det mangler dynamisk årstider... Det virker jo som hele poenget med en slik utvidelse spør du meg, er vel ytterst få som finner det spesielt interessant å spille med vinter 24/7? Men så vil jeg jo gjerne ha tilgang på trikkene da...
så siden jeg likte simcity burde jeg like dette? er det vanskelig spill og vanskelig å sette seg inn i?
Ja, og nei. Det eneste som er vanskelig er å få trafikken til å flyte, men du blir ikke straffet så voldsomt for trafikkork uansett. Istedenfor å spørre, hvorfor ikke bare prøve, så finner du ut av det selv? Du har jo spillet.
Noen som vet om noen mods som øker rekkevidden på alt :?
Prøver å bygge byer men man må jo ha alt av de nødvendigste tingene i hvert nabolag/blokk
Har du økt de ulike budsjettene?
Ikke de siste gangen jeg har prøvd nå, men gjorde det i begynnelsen uten å merke så alt for stor forskjell
