Java Virtual Machine Problem
Cy'
Jeg tror jeg har malt meg inn i et hjørne. Alle lanchere jeg prøver å kjøre stoppes av et vindu med tittel Java Virtual Machin Problem.
Error: Could not create the JVM.
Error: A fatal exception has occurred. Program will exit.
Jeg har prøvd alt jeg kunne google meg til. Prøvd diverse xmx/xms variabler, uten hell. Og da jeg nå har avinstallert Java på maskinen og prøver å installer det på nytt igjen så hindrer ironisk nok problemet meg for å installer Java igjen.
Er det noen som har noe erfaring med problemet?
System Information
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.141211-1742)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 09/03/09 15:52:51 Ver: 08.00.15
Processor: Intel® Core i7 CPU 920 @ 2.67GHz (8 CPUs), ~2.7GHz
Memory: 12288MB RAM
Available OS Memory: 12280MB RAM
Page File: 3466MB used, 21090MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Display Devices
Card name: NVIDIA GeForce GTX 760
Manufacturer: NVIDIA
Chip type: GeForce GTX 760
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1187&SUBSYS_847A1043&REV_A1
Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: Generisk PnP-skjerm
Monitor Model: SyncMaster
Monitor Id: SAM03F2
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4475 (English)
Driver Version: 9.18.13.4475
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 11/13/2014 01:20:36, 19966344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C7-11CF-8862-77A41CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1187
SubSys ID: 0x847A1043
Revision ID: 0x00A1
Endret av Cy'
