Hva kan eg slette?
abc234
Hei
Ønsker å "rydde" litt på maskinen min....
Men har masse "microsoft" programmer, hva kan slettes av desse?
Legger her ved liste av hele maskinen, men er kun ute etter info ang microsoft filer som ikke har noe foruftig å gjøre med installerte pgm...
@BIOS GIGABYTE 24.11.2012 2.12
Adobe Flash Player 16 ActiveX Adobe Systems Incorporated 26.01.2015 6.00 MB 16.0.0.296
Adobe Flash Player 16 NPAPI Adobe Systems Incorporated 26.01.2015 6.00 MB 16.0.0.296
Adobe Photoshop CS6 Adobe Systems Incorporated 27.04.2014 2.84 GB 13.0
Adobe Reader XI (11.0.08) Adobe Systems Incorporated 29.08.2014 182 MB 11.0.08
AMD Catalyst Install Manager Advanced Micro Devices, Inc. 07.01.2015 26.7 MB 8.0.916.0
Antec CC Antec 24.11.2012 5.06 MB 1.00.00
Antec CC (Driver Removal) 27.04.2014
Auslogics Duplicate File Finder Auslogics Labs Pty Ltd 23.06.2014 19.7 MB 3.5.4.0
AutoCAD 2013 - English Autodesk 05.02.2013 19.0.55.0
Autodesk Content Service Autodesk 27.04.2014 3.0.84.0
Autodesk Inventor Fusion 2013 Autodesk, Inc. 05.02.2013 585 MB 2.0.0.206
Autodesk Inventor Fusion plug-in for AutoCAD 2013 Autodesk 05.02.2013 0.2.0.230
Autodesk Material Library 2013 Autodesk 05.02.2013 94.9 MB 3.0.13
Autodesk Material Library Base Resolution Image Library 2013 Autodesk 05.02.2013 71.4 MB 3.0.13
Autodesk Sync Autodesk, Inc. 05.02.2013 45.3 MB 3.5.24.0
AVG 2015 AVG Technologies 24.01.2015 2015.0.5646
Avinstaller skriver EPSON PX730 Series SEIKO EPSON Corporation 01.12.2012
Battlefield 3™ Electronic Arts 07.12.2014 1.6.0.0
Camtasia Studio 8 TechSmith Corporation 22.04.2013 353 MB 8.0.4.1060
CCleaner Piriform 01.01.2015 5.01
CutePDF Writer 3.0 CutePDF.com 26.11.2012 3.0
DAEMON Tools Pro DT Soft Ltd 27.04.2014 4.41.0315.0262
DAEMON Tools Pro Advanced DAEMON Tools Pro Advanced 27.04.2014 4
DES 2.0 Gigabyte 24.11.2012 1.00.0000
Driver Genius Driver-Soft Inc. 25.11.2012 16.9 MB 12.0
Entity Framework 6.1.1 Tools for Visual Studio 2013 Microsoft Corporation 23.11.2014 145 MB 12.0.30610.0
EPSON Scan Seiko Epson Corporation 27.04.2014
FARO LS 1.1.406.58 FARO Scanner Production 05.02.2013 21.5 MB 4.6.58.2
FastStone Capture 7.6 FastStone Soft 27.04.2014 7.6
Google Chrome Google Inc. 24.11.2012 40.0.2214.93
Google Drive Google, Inc. 30.01.2015 35.0 MB 1.19.8406.6504
Google Earth Plug-in Google 11.01.2014 83.8 MB 7.1.2.2041
Google Talk Plugin Google 11.11.2014 14.3 MB 5.38.6.0
IIS 8.0 Express Microsoft Corporation 23.11.2014 35.2 MB 8.0.1557
IIS Express Application Compatibility Database for x64 23.11.2014
IIS Express Application Compatibility Database for x86 23.11.2014
Intel® Control Center Intel Corporation 24.11.2012 1.2.1.1007
Intel® Management Engine Components Intel Corporation 07.01.2015 10.0.30.1072
Intel® Update Manager Intel Corporation 07.01.2015 22.6 MB 2.4.3
Java 7 Update 71 Oracle 09.11.2014 119 MB 7.0.710
Jottacloud version 3.0.24.205 Jotta AS 16.11.2014 35.0 MB 3.0.24.205
Logitech Webcam Software Logitech Inc. 27.04.2014 2.51
Malwarebytes Anti-Malware version 2.0.2.1012 Malwarebytes Corporation 03.06.2014 53.1 MB 2.0.2.1012
Microsoft .NET Framework 4 Multi-Targeting Pack Microsoft Corporation 28.04.2013 83.5 MB 4.0.30319
Microsoft .NET Framework 4.5 Multi-Targeting Pack Microsoft Corporation 23.11.2014 41.8 MB 4.5.50710
Microsoft .NET Framework 4.5 SDK Microsoft Corporation 23.11.2014 18.5 MB 4.5.50710
Microsoft .NET Framework 4.5.1 Microsoft Corporation 23.11.2014 38.8 MB 4.5.50938
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack Microsoft Corporation 23.11.2014 49.3 MB 4.5.50932
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) Microsoft Corporation 23.11.2014 74.5 MB 4.5.50932
Microsoft .NET Framework 4.5.1 SDK Microsoft Corporation 23.11.2014 19.4 MB 4.5.51641
Microsoft ASP.NET MVC 2 Microsoft Corporation 12.04.2013 482 KB 2.0.50217.0
Microsoft ASP.NET MVC 2 - Visual Studio 2010 Tools Microsoft Corporation 12.04.2013 2.25 MB 2.0.50217.0
Microsoft ASP.NET MVC 3 Microsoft Corporation 28.04.2013 592 KB 3.0.20105.0
Microsoft ASP.NET Web Pages Microsoft Corporation 28.04.2013 1.14 MB 1.0.20105.0
Microsoft Help Viewer 1.0 Microsoft Corporation 12.04.2013 3.97 MB 1.0.30319
Microsoft Help Viewer 2.0 Microsoft Corporation 27.04.2014 12.1 MB 2.0.50727
Microsoft Help Viewer 2.1 Microsoft Corporation 23.11.2014 12.1 MB 2.1.21005
Microsoft Silverlight Microsoft Corporation 31.08.2013 50.6 MB 5.1.20513.0
Microsoft Silverlight 3 SDK Microsoft Corporation 12.04.2013 31.9 MB 3.0.40818.0
Microsoft Silverlight 4 SDK Microsoft Corporation 28.04.2013 51.6 MB 4.0.60310.0
Microsoft Silverlight 5 SDK Microsoft Corporation 28.04.2013 77.5 MB 5.0.61118.0
Microsoft SQL Server 2008 (64-bit) Microsoft Corporation 12.04.2013
Microsoft SQL Server 2008 Browser Microsoft Corporation 12.04.2013 7.94 MB 10.1.2531.0
Microsoft SQL Server 2008 Native Client Microsoft Corporation 12.04.2013 6.37 MB 10.1.2531.0
Microsoft SQL Server 2008 R2 Data-Tier Application Framework Microsoft Corporation 12.04.2013 330 KB 10.50.1447.4
Microsoft SQL Server 2008 R2 Data-Tier Application Project Microsoft Corporation 12.04.2013 11.8 MB 10.50.1447.4
Microsoft SQL Server 2008 R2 Management Objects Microsoft Corporation 12.04.2013 15.1 MB 10.50.1447.4
Microsoft SQL Server 2008 R2 Management Objects (x64) Microsoft Corporation 12.04.2013 9.97 MB 10.50.1447.4
Microsoft SQL Server 2008 R2 Transact-SQL Language Service Microsoft Corporation 12.04.2013 5.34 MB 10.50.1447.4
Microsoft SQL Server 2008 Setup Support Files Microsoft Corporation 12.04.2013 39.4 MB 10.1.2731.0
Microsoft SQL Server 2012 Command Line Utilities Microsoft Corporation 23.11.2014 876 KB 11.1.3000.0
Microsoft SQL Server 2012 Data-Tier App Framework Microsoft Corporation 23.11.2014 10.1 MB 11.1.2902.0
Microsoft SQL Server 2012 Data-Tier App Framework (x64) Microsoft Corporation 23.11.2014 10.1 MB 11.1.2902.0
Microsoft SQL Server 2012 Express LocalDB Microsoft Corporation 23.11.2014 158 MB 11.1.3000.0
Microsoft SQL Server 2012 Management Objects Microsoft Corporation 23.11.2014 21.7 MB 11.1.3000.0
Microsoft SQL Server 2012 Management Objects (x64) Microsoft Corporation 23.11.2014 14.0 MB 11.1.3000.0
Microsoft SQL Server 2012 Native Client Microsoft Corporation 23.11.2014 7.19 MB 11.1.3000.0
Microsoft SQL Server 2012 T-SQL Language Service Microsoft Corporation 23.11.2014 6.14 MB 11.1.3000.0
Microsoft SQL Server 2012 Transact-SQL Compiler Service Microsoft Corporation 28.04.2013 84.7 MB 11.0.2100.60
Microsoft SQL Server 2012 Transact-SQL ScriptDom Microsoft Corporation 23.11.2014 4.53 MB 11.1.3000.0
Microsoft SQL Server 2014 Express LocalDB Microsoft Corporation 23.11.2014 227 MB 12.0.2000.8
Microsoft SQL Server 2014 Management Objects Microsoft Corporation 23.11.2014 23.1 MB 12.0.2000.8
Microsoft SQL Server 2014 Management Objects (x64) Microsoft Corporation 23.11.2014 15.1 MB 12.0.2000.8
Microsoft SQL Server 2014 T-SQL Language Service Microsoft Corporation 23.11.2014 6.65 MB 12.0.2000.8
Microsoft SQL Server 2014 Transact-SQL ScriptDom Microsoft Corporation 23.11.2014 6.17 MB 12.0.2000.8
Microsoft SQL Server Compact 3.5 SP2 ENU Microsoft Corporation 12.04.2013 3.39 MB 3.5.8080.0
Microsoft SQL Server Compact 3.5 SP2 x64 ENU Microsoft Corporation 12.04.2013 4.51 MB 3.5.8080.0
Microsoft SQL Server Compact 4.0 SP1 x64 ENU Microsoft Corporation 28.04.2013 19.3 MB 4.0.8876.1
Microsoft SQL Server Data Tools - enu (11.1.20627.00) Microsoft Corporation 28.04.2013 14.1 MB 11.1.20627.00
Microsoft SQL Server Data Tools - enu (12.0.41012.0) Microsoft Corporation 23.11.2014 28.4 MB 12.0.41012.0
Microsoft SQL Server Data Tools Build Utilities - enu (11.1.20627.00) Microsoft Corporation 28.04.2013 1.32 MB 11.1.20627.00
Microsoft SQL Server Data Tools Build Utilities - enu (12.0.30919.1) Microsoft Corporation 23.11.2014 2.15 MB 12.0.30919.1
Microsoft SQL Server Database Publishing Wizard 1.4 Microsoft Corporation 12.04.2013 10.1 MB 10.1.2512.8
Microsoft SQL Server System CLR Types Microsoft Corporation 28.04.2013 940 KB 10.50.1600.1
Microsoft SQL Server System CLR Types (x64) Microsoft Corporation 28.04.2013 856 KB 10.50.1600.1
Microsoft SQL Server VSS Writer Microsoft Corporation 12.04.2013 3.59 MB 10.1.2531.0
Microsoft Sync Framework Runtime v1.0 SP1 (x64) Microsoft Corporation 12.04.2013 1.00 MB 1.0.3010.0
Microsoft Sync Framework SDK v1.0 SP1 Microsoft Corporation 12.04.2013 29.6 MB 1.0.3010.0
Microsoft Sync Framework Services v1.0 SP1 (x64) Microsoft Corporation 12.04.2013 2.84 MB 1.0.3010.0
Microsoft Sync Services for ADO.NET v2.0 SP1 (x64) Microsoft Corporation 12.04.2013 541 KB 2.0.3010.0
Microsoft System CLR Types for SQL Server 2012 Microsoft Corporation 23.11.2014 1.66 MB 11.1.3366.16
Microsoft System CLR Types for SQL Server 2012 (x64) Microsoft Corporation 23.11.2014 1.53 MB 11.1.3366.16
Microsoft System CLR Types for SQL Server 2014 Microsoft Corporation 23.11.2014 4.84 MB 12.0.2000.8
Microsoft Team Foundation Server 2010 Object Model - ENU Microsoft Corporation 12.04.2013 10.0.30319
Microsoft Visual C++ 2005 Redistributable Microsoft Corporation 10.04.2013 300 KB 8.0.56336
Microsoft Visual C++ 2005 Redistributable (x64) Microsoft Corporation 05.02.2013 620 KB 8.0.61000
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 Microsoft Corporation 27.04.2014 252 KB 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Microsoft Corporation 24.11.2012 596 KB 9.0.30729
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4974 Microsoft Corporation 12.04.2013 599 KB 9.0.30729.4974
Microsoft Visual C++ 2010 x64 Designtime - 10.0.30319 Microsoft Corporation 12.04.2013 272 KB 10.0.30319
Microsoft Visual C++ 2010 x64 Runtime - 10.0.30319 Microsoft Corporation 12.04.2013 20.2 MB 10.0.30319
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Microsoft Corporation 31.12.2012 16.5 MB 10.0.40219
Microsoft Visual C++ 2010 x86 Runtime - 10.0.30319 Microsoft Corporation 12.04.2013 15.6 MB 10.0.30319
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 Microsoft Corporation 23.11.2014 20.5 MB 11.0.60610.1
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 Microsoft Corporation 23.11.2014 17.3 MB 11.0.60610.1
Microsoft Visual F# 2.0 Runtime Microsoft Corporation 12.04.2013 5.81 MB 10.0.30319
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) Microsoft Corporation 23.11.2014 10.0.50903
Microsoft Web Deploy 3.5 Microsoft Corporation 23.11.2014 6.84 MB 3.1237.1763
Microsoft Web Deploy dbSqlPackage Provider - enu Microsoft Corporation 28.04.2013 764 KB 10.3.20225.0
Microsoft Web Platform Installer 4.0 Microsoft Corporation 28.04.2013 4.13 MB 4.0.1622
Mozilla Firefox 30.0 (x86 nb-NO) Mozilla 18.10.2014 67.2 MB 30.0
Mozilla Maintenance Service Mozilla 10.05.2014 341 KB 29.0.1
ON_OFF Charge B11.0110.1 GIGABYTE 24.11.2012 1.00.0001
Origin Electronic Arts, Inc. 27.04.2014 9.0.15.65
phpDesigner 8 version 8.1.2 MPSOFTWARE 27.04.2014
PowerISO PowerISO Computing, Inc. 27.04.2014 4.7
Prerequisites for SSDT Microsoft Corporation 23.11.2014 6.36 MB 12.0.2000.8
PunkBuster Services Even Balance, Inc. 07.12.2014 0.991
Raptr 14.06.2014
Razer BlackWidow Razer USA Ltd. 05.02.2013 65.8 MB 1.05.00
Realtek Ethernet Controller Driver Realtek 07.01.2015 7.90.826.2014
Realtek HDMI Audio Driver for ATI Realtek Semiconductor Corp. 27.04.2014 6.0.1.6650
Realtek High Definition Audio Driver Realtek Semiconductor Corp. 08.01.2015 6.0.1.7399
Renesas Electronics USB 3.0 Host Controller Driver Renesas Electronics Corporation 25.11.2012 1.25 MB 2.1.39.0
Revo Uninstaller Pro 3.0.7 VS Revo Group, Ltd. 29.09.2013 33.5 MB 3.0.7
SAMSUNG USB Driver for Mobile Phones SAMSUNG Electronics Co., Ltd. 14.06.2014 36.6 MB 1.5.42.0
Skype™ 7.0 Skype Technologies S.A. 24.12.2014 48.1 MB 7.0.102
Smart 6 B11.0512.1 GIGABYTE 24.11.2012 1.00.0000
Smart Dual Lan Realtek 24.11.2012 1.00.0000
Spotify Spotify AB 06.09.2014 0.9.11.27.g2b1a638c
TeamViewer 8 TeamViewer 27.04.2014 8.0.22298
Total Commander 64-bit (Remove or Repair) Ghisler Software GmbH 24.11.2013 8.01
Visual Studio 2012 x64 Redistributables AVG Technologies 27.09.2013 12.9 MB 14.0.0.1
Visual Studio C++ 10.0 Runtime TomTom International B.V. 06.07.2014 8.00 KB 10.0.0
VLC media player VideoLAN 29.08.2014 2.1.5
VueScan x64 22.10.2014
WCF RIA Services V1.0 SP2 Microsoft Corporation 23.11.2014 6.91 MB 4.1.62812.0
Web Deployment Tool Microsoft Corporation 12.04.2013 3.10 MB 1.1.0618
WestwoodOnline WestwoodOnline 25.12.2014 965 KB 1.0.0.0
WinRAR 4.20 (64-bit) win.rar GmbH 28.11.2012 4.20.0
Wisdom-soft ScreenHunter 6.0 Free Wisdom Software Inc. 27.04.2014
