c0nSi Skrevet 1. november 2003 Del Skrevet 1. november 2003 Jeg fikk ny maskine i går. I dag spilte jeg, plutselig begynte maskinen å "lagge" (hakke). Da restartet jeg maskinen for å se om lagginga stopet, men noe uventet skjedde; jeg fikk en feilmelding før jeg kom inn i Windows: "A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT_VOLUME If this is the first time you've seen this error screen, restart your computer. If tis appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardare or software manufacturer for any Windoes updates you might need. Of problems continue , disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Starup optoons, and then Select Safe Mode. Technical information: *** STOP: 0x00000ED (Dx8171EE30,0c0000032,0x00000000,0x00000000000)" Hva kan jeg gjøre med dette Min hardware er: XP 2500+ ABIT NFS 2.0 WD 80 GB ATI 9800 SE Lenke til kommentar
c0nSi Skrevet 1. november 2003 Forfatter Del Skrevet 1. november 2003 PLEASE HJELP MEG :( VIL SPILLE FOR F.... PLZPLZPLZPLZPLZPLZPLZPLZPLZPLZPLZ THX Lenke til kommentar
Kris_TheLord Skrevet 1. november 2003 Del Skrevet 1. november 2003 Hmm, høres ut som et biosproblem... Lenke til kommentar
