Roald! Skrevet 11. oktober 2004 Del Skrevet 11. oktober 2004 Hva som er så dårlig med Thats Write "General" plater fra komplett da? Dårlig holdbarhet? Lenke til kommentar
Gjest Slettet-10579 Skrevet 11. oktober 2004 Del Skrevet 11. oktober 2004 (endret) Har nettopp fått 4 spindler à 25 med Thats Write DVD+R fra Komplett. Optodisc desverre -------------------------------------------------------------------------- Unique Disc Identifier : [DVD+R:OPTODISC-OR4-000] -------------------------------------------------------------------------- Disc Type : [DVD+R] Manufacturer ID : [OPTODISC] Manufacturer Name : [Optodisc Technology Corp.] Media Type ID : [OR4] Product Revision : [Not Specified] Disc Application Code : [General Purpose] Recording Speeds : [1x , 2.4x , 4x] Blank Disc Capacity : [Not Supported By Method 2] -------------------------------------------------------------------------- [DVD Identifier - http://DVD.Identifier.CDfreaks.com] -------------------------------------------------------------------------- You`re warned. Endret 11. oktober 2004 av Slettet-10579 Lenke til kommentar
Roald! Skrevet 11. oktober 2004 Del Skrevet 11. oktober 2004 Eg har disse : -------------------------------------------------------------------------- Unique Disc Identifier : [DVD-R:PRINCO] -------------------------------------------------------------------------- Disc Type : [DVD-R] Manufacturer ID : [PRINCO] Manufacturer Name : [Princo Corp.] Disc Application Code : [unrestricted Use : Consumer Purpose] Recording Speeds : [1x , 2x , 4x] (8x Cannot Be Detected) Blank Disc Capacity : [2,298,496 Sectors = 4,489.3MB = 4.38GB (4.71GB)] -------------------------------------------------------------------------- ** INFO : An Empty Writable Disc Is Recommended For Accurate Results ** INFO : Drive = _NEC DVD_RW ND-3500AG [FW 2.16] ** INFO : Write Capabilities = DVD+R DVD+R-DL DVD+RW DVD-R DVD-RW ** INFO : Disc = [DVD-R:PRINCO] ** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below ** INFO : GET PERFORMANCE Write Speed Descriptor(s) Descriptor #1 = 5540 KBPS ( 4.00x) - [CLV/Non-Pure CAV] Descriptor #2 = 2770 KBPS ( 2.00x) - [CLV/Non-Pure CAV] ** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command] Descriptor #1 = 8467 KBPS ( 6.00x) - [CLV/Non-Pure CAV] Descriptor #2 = 7056 KBPS ( 5.09x) - [CLV/Non-Pure CAV] - [invalid Entry] Descriptor #3 = 5645 KBPS ( 4.00x) - [CLV/Non-Pure CAV] Descriptor #4 = 4234 KBPS ( 3.06x) - [CLV/Non-Pure CAV] - [invalid Entry] Descriptor #5 = 2822 KBPS ( 2.00x) - [CLV/Non-Pure CAV] Descriptor #6 = 1411 KBPS ( 1.00x) - [CLV/Non-Pure CAV] ** WARNING : Drive May Have Returned Incorrect Descriptors -------------------------------------------------------------------------- [DVD Identifier - http://DVD.Identifier.CDfreaks.com] -------------------------------------------------------------------------- Bør eg kjøpe noen andre? Lenke til kommentar
OC-Freak Skrevet 11. oktober 2004 Forfatter Del Skrevet 11. oktober 2004 Fikk en OPTODISC.OR4 4x plate av det nye partiet - brent av en kamerat på en NEC ND-2500A DVD-Brenner (som er en meget bra DVD-Brenner). 4x Brennehastighet er brukt. Her er scanneresultatet - ikke det værste jeg har sett men overskrider HELT KLART maxverdiene som DVD-Standardene spesifiserer. Max verdiene: PI: MAX verdien skal ikke overstige 280 PIF: MAX verdien skal ikke overskride 4. Så min konklusjon står fast: Optodisc er plater i den nedre del av kvalitets spekteret.. Lenke til kommentar
Roald! Skrevet 11. oktober 2004 Del Skrevet 11. oktober 2004 ok. Takk for hjelpen. Bestiller meg en pakken TY Plextor fra norwaydisc og en 25 pk spindel med verbatim eller noe Trudde komplett leverte kvalitet eg hehe Lenke til kommentar
vegge Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 DigitalImpuls i Trondheim selger 25pk eProFormance DVD+R 8x spindel for 95 spenn. Hvis jeg ikke tar helt feil er dette ekstremt billig!? Lenke til kommentar
Apathy Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Pakken fra Komplett inneholdt Optodisker. Jeg har brent en spindel på 4x uten problemer (hverken read eller write) på min NEC3500AG med orginal firmware. Men over 4x er bare å glemme. Lenke til kommentar
rayrod Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 En newbie har blitt skikkelig forvirra her inne nå Hvilke plater gir best verdi/kvalitet for penga når jeg har nec 3500AG med firmware 2.16? Lenke til kommentar
Paul G. Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 En newbie har blitt skikkelig forvirra her inne nå Hvilke plater gir best verdi/kvalitet for penga når jeg har nec 3500AG med firmware 2.16? eProformance 8x er hva jeg kjøpte nettopp. Billig, men bra kvalitet. Kjøpte forresten DVD-R fordi det var det eneste Norwaydisc hadde inne. Ble derfor litt sur når jeg så at DVD+R'ene kan brennes på 12x med den nye firmwaren. Noen som vet om DVD-R også kan det? Den firmwaren jeg har virker bra, så jeg vil ikke oppdatere uten at det er noen forbedring for meg. Lenke til kommentar
rayrod Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Så det er ett fett om det er DVD-R eller DVD+R så lenge spilleren takler det? Greit nok at det er litt forskjell i speeden, men det kan jeg leve med Lenke til kommentar
Inbreak Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Lite-On brennaren min har vore ganske so trøblete i det siste; nektar å lese cdar i Windows, men kan likevel brenne heilt fint. I tillegg har den lenge brent DVD plater ganske dårlig, sjølv skikkelige TY plater, og no vil den ikkje brenne cd heller. Så det er vel berre å kjøpe seg ny (har vore opp/nedgradert og flasha i massevis). Men kva bør eg eigentlig velge? Bitsetting er eit absolutt krav, så det utelukkar vel i alle fall Plextor? Ikkje at eg gidd betale så masse ekstra for ein Plextor heller men. Sjølv om det ikkje er absolutt nødvendig, hadde det eigentleg fore veldig greit å kunne brukt Kprobe vidare til å sjekke for feil (PI/PO) på platene. Ein kamerat anbefalar Nec ND-3500A, men denne støttar etter som eg har funne ut ikkje feilsjekking. Så kva bør eg eigentlig velge? Er Denne brennaren det beste valget likevel? Lenke til kommentar
Aetius Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Lite-On brennaren min har vore ganske so trøblete i det siste; nektar å lese cdar i Windows, men kan likevel brenne heilt fint. I tillegg har den lenge brent DVD plater ganske dårlig, sjølv skikkelige TY plater, og no vil den ikkje brenne cd heller. Så det er vel berre å kjøpe seg ny (har vore opp/nedgradert og flasha i massevis). Har akkurat samme problemet med min BTC 1008M, bare fem måneder etter innkjøp. Lenke til kommentar
Psh Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 (endret) Pioneer og NEC brennere (og noen til så klart) støtter pr i dag ikke å rapportere feil. Derfor vil ikke dette være mulig med disse..... Dårlig gjort ass..... Jaja, skal kjøpe ny brenner snart uansett og da blir det ihvertfall ikke Nec! Jeg "brenner" vel mest for en Benq Det kommer snart en ny CD-Speed (www.cdspeed2000.com) versjon som støtter rapportering av både PI, PIF og POF samt jitter for alle BenQ brennere - så det er ikke et dårlig valg Så da tror jeg ikke BenQ DW1620 er noe dårlig valg for deg Inbreak! Mener også denne støtter bitsetting for både singel og double layer plater... Endret 13. oktober 2004 av Psh Lenke til kommentar
Gerrard Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 (endret) Men kva bør eg eigentlig velge? Bitsetting er eit absolutt krav, så det utelukkar vel i alle fall Plextor? Ikkje at eg gidd betale så masse ekstra for ein Plextor heller men. Sjølv om det ikkje er absolutt nødvendig, hadde det eigentleg fore veldig greit å kunne brukt Kprobe vidare til å sjekke for feil (PI/PO) på platene. Ein kamerat anbefalar Nec ND-3500A, men denne støttar etter som eg har funne ut ikkje feilsjekking. Så kva bør eg eigentlig velge? Er Denne brennaren det beste valget likevel? PlexTools v2.17, har støtte for bitsetting.... Her kan du også måle PI/PO, men Plextor er kanskje litt dyrt. Ville vel kjøpt Benq DW1620 pr idag. Det kommer snart en ny CD-Speed versjon som støtter rapportering av både PI, PIF og POF samt jitter for alle BenQ brennere Er spent på Plextor PX-716A som kommer i slutten av måneden. Jeg kommer nok til å kjøpe Benq DW1620 selv snart, eller en Plextor-PX716A hvis det blir verdt pengene... Ps! Hold deg unna Nec (og Pioneer) hvis du vil måle feilverdier, da dise ikke støtter noen feilsjekkingsprogram i skrivende stund Endret 12. oktober 2004 av Gerrard Lenke til kommentar
Inbreak Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Denne CD-DVD Speed oppdateringa det er snakk om til BenQ eller? Last Updated: 10 October 2004 TOP Nero CD-DVD Speed V3.40 released! Changes: Create Data Disc: Test results can be recorded on the disc. Improved scoring system. Many small improvements and bug fixes Disc Quality Test: Added enhanced scanning capabilities for BenQ/Philips 8x DVD recorders. Added advanced jitter test for AOpen Combo drives and CD-RW recorders. -Added colored bars on the background to show the acceptable level of errors. Korleis er brenne/lesekvalitet på BenQ brennaren i forhold til Nec ND-3500A i grunnen? Og kva testing er det som ikkje vil fungere på Nec brennaren? Reknar med det er blant anna feiltesting i Kprobe? Kva med diverse testar i Nero / DVDInfoPro? Ein kamerat snakte om han fekk køyre feiltesting i DVDInfoPro med sin Nec 2510. Kan dette stemme eller? Er det forresten berre Lite-On som støttar Kprobe feiltesting, eller er det andre merker og? Lenke til kommentar
Gerrard Skrevet 12. oktober 2004 Del Skrevet 12. oktober 2004 Denne CD-DVD Speed oppdateringa det er snakk om til BenQ eller? Last Updated: 10 October 2004 TOP Nero CD-DVD Speed V3.40 released! Changes: Create Data Disc: Test results can be recorded on the disc. Improved scoring system. Many small improvements and bug fixes Disc Quality Test: Added enhanced scanning capabilities for BenQ/Philips 8x DVD recorders. Added advanced jitter test for AOpen Combo drives and CD-RW recorders. -Added colored bars on the background to show the acceptable level of errors. Korleis er brenne/lesekvalitet på BenQ brennaren i forhold til Nec ND-3500A i grunnen? Og kva testing er det som ikkje vil fungere på Nec brennaren? Reknar med det er blant anna feiltesting i Kprobe? Kva med diverse testar i Nero / DVDInfoPro? Ein kamerat snakte om han fekk køyre feiltesting i DVDInfoPro med sin Nec 2510. Kan dette stemme eller? Er det forresten berre Lite-On som støttar Kprobe feiltesting, eller er det andre merker og? Nero CD-DVD Speed V3.40 støtter Disc Quality test (PI/PO/Jitter) for Benq brennere ja. Lesekvaliteten på Benq er en god del bedre enn på Nec, som ikke er kjent for å ha de beste leserne. Min gamle Nec ND-1300A har hatt fler og fler CRC-error med tiden. Med Benq skal ikke dette være noe problem. Brennekvaliteten på Benq skal også være svært god. Pr idag er det vel ingen program som kan måle disc kvaliteten (PI/PO/Jitter) ved Nec brennere, men med Nero CD-DVD Speed kan man scanne platen og sjekke hvor mange prosent som er bra/skadet/uleselig. Det er vel bare Lite-On som støtter Kprobe ja, i likhet med plextools som bare kan brukes ved Plextor. De er noen særinger Så Benq brukere får vel holde seg til Nero CD-DVD Speed V3.40 Lenke til kommentar
2peewee Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Vett ikke helt om folk liker at jeg spør om dette her. Men jeg har tenkt å kjøpe en ny dvd+ brenner, eller en som kan brenne begge deler. Hvilken brenner bør jeg kjøpe da, og kaffor någen cd`er gir best kvalitet sammen md den brenneren?? ut i fra testen vil jeg jo si at Plextor PX-712A eller Philips DVDRW885 er de beste. stemmer dette?? viss dere mener jeg har posta feil plass, så gi beskjed så skal jeg flytte den. tenkte bare at siden jeg vil ha dette linka opp mot kaffor någen dvd plater jeg bør kjøpe, så burde dt gå bra her. peewee Lenke til kommentar
Gerrard Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Vett ikke helt om folk liker at jeg spør om dette her. Men jeg har tenkt å kjøpe en ny dvd+ brenner, eller en som kan brenne begge deler. Hvilken brenner bør jeg kjøpe da, og kaffor någen cd`er gir best kvalitet sammen md den brenneren?? ut i fra testen vil jeg jo si at Plextor PX-712A eller Philips DVDRW885 er de beste. stemmer dette?? viss dere mener jeg har posta feil plass, så gi beskjed så skal jeg flytte den. tenkte bare at siden jeg vil ha dette linka opp mot kaffor någen dvd plater jeg bør kjøpe, så burde dt gå bra her. peewee Plextor PX-712A støtter IKKE Double layer! Vent heller på Plextor PX-716A som kommer i slutten av måneden. Philips DVDRW885 er vel samme brenner som BenQ DW830A, derfor ville jeg heller valgt BenQ DW1620 (oppfølgeren til DW830). Jeg tror faktisk også at den blir billigere fordi Philips ofte har en høyere pris pgav navnet. Lenke til kommentar
c-man Skrevet 13. oktober 2004 Del Skrevet 13. oktober 2004 Kjøpte en 25-spindel med 8x dvd-r av merket eProformace på Rimi i går. Er dette plater av ok kvalitet? Lenke til kommentar
OC-Freak Skrevet 13. oktober 2004 Forfatter Del Skrevet 13. oktober 2004 Kjøpte en 25-spindel med 8x dvd-r av merket eProformace på Rimi i går. Er dette plater av ok kvalitet? Skal være det ja. Lenke til kommentar
