ericc2233 Skrevet 1. november 2003 Del Skrevet 1. november 2003 Har et dual hovedkort med dual minne..Hvordan sjekker jeg om den kjører i dual?har en mistanke om at den ikke gjør det.bruker sisoft sandra 2004. ooops sorry..burde kanskje lagt posten i hovedkort forumet.... Lenke til kommentar
Gjest Slettet-80wCWpIM Skrevet 1. november 2003 Del Skrevet 1. november 2003 vel.. du kan jø kjøre memory bandwith testen på sisoft sandra.. når du starter opp så skal du vel få en beskjed om at du kjører i dual. jeg får vertfall beskjed om at dual mode er aktivert. Lenke til kommentar
ericc2233 Skrevet 1. november 2003 Forfatter Del Skrevet 1. november 2003 så ikke noe om det. men kjørte testen nå. dette er det jeg fikk. SiSoftware Sandra ram bandwidth int buffered isse2 5015MB/S ram bandwidth float buffered isse2 5018MB/S Int Buffered iSSE2 (Integer STREAM) Results Breakdown Assignment : 4870MB/s Scaling : 4863MB/s Addition : 5164MB/s Triad : 5163MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 78% (estimated) Float Buffered iSSE2 (Float STREAM) Results Breakdown Assignment : 4875MB/s Scaling : 4867MB/s Addition : 5162MB/s Triad : 5170MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 78% (estimated) Test Status Memory Used by Test : 255MB NUMA Support : No SMP Test : No Total Test Threads : 1 SMT Test : Yes Number of Test SMT (per CPU) : 2 Dynamic MP/MT Load Balance : No Processor Affinity : No Chipset 1 Model : ASUSTeK Computer Inc 82875P Memory Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 6400MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.0-2-2-5CL 1CMD Channels : 2 Speed : 2x 200MHz (400MHz data rate) Width : 64-bit Performance Acceleration Technology : Yes Maximum Memory Bus Bandwidth : 6400MB/s (estimated) Features MMX Technology : Yes SSE Technology : Yes SSE2 Technology : Yes SSE3 Technology : No HTT - Hyper-Threading Technology : Yes Performance Tips Notice 5008 : To change benchmarks, click Options. Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance. Notice 5006 : Only compare the results with ones obtained using the same version! Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. kan ikke se at jeg kjører dual ..har 2stk 256mb brikker..denne testen bruker jo bare 1 så vidt jeg kan se... Lenke til kommentar
Antihero Skrevet 1. november 2003 Del Skrevet 1. november 2003 det står under oppstart første skjermen du får Lenke til kommentar
ericc2233 Skrevet 1. november 2003 Forfatter Del Skrevet 1. november 2003 det står under oppstart første skjermen du får du mener i bios?eller når jeg starter sisoft sandra? Lenke til kommentar
maedox Skrevet 1. november 2003 Del Skrevet 1. november 2003 Skal vel egentlig stå i oppstarten om dual channel er aktivert. Kan vel anta at det er aktivert så lenge du har to identiske brikker installert. Channels : 2 ... betyr ikke det dual da? En annen måte.. Test med bare én RAM-brikke. Hvis resultatene er litt lavere, så har du nok dual-channel aktivert. Lenke til kommentar
Gjest Slettet-80wCWpIM Skrevet 1. november 2003 Del Skrevet 1. november 2003 Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.0-2-2-5CL 1CMD der står det jo at du har 512mb totalt. er jo bare å bytte litt på minnebrikkene for å sammenligne, men tar jeg ikke helt feil så kjører du i dual ja. hvis ikke så hadde du ikke fått såpass båndbredde. Lenke til kommentar
ericc2233 Skrevet 1. november 2003 Forfatter Del Skrevet 1. november 2003 Logical/Chipset 1 Memory BanksBank 0 : 512MB DDR-SDRAM 2.0-2-2-5CL 1CMD der står det jo at du har 512mb totalt. er jo bare å bytte litt på minnebrikkene for å sammenligne, men tar jeg ikke helt feil så kjører du i dual ja. hvis ikke så hadde du ikke fått såpass båndbredde. ja.. men jeg kan ikke se noe om at dual er aktivert eller noe sånt. har satt minnebrikkene i de blå slottene i hovedkortet... Lenke til kommentar
Simen1 Skrevet 1. november 2003 Del Skrevet 1. november 2003 SiSoftware Sandra ram bandwidth int buffered isse2 5015MB/S ram bandwidth float buffered isse2 5018MB/S De hastighetene der er teknisk umulig med bare en brikke. (dersom du ikke har overklokket noe helt sinnsykt utrolig) Enkelt kanals PC3200-minne skal i teorien klare 3200 MByte/s Dobblet kanal skal i teorien klare det dobbelte. Teori og praksis er ikke det samme og praksis vil alltid ligge noe under. Dermed passer det veldig godt med tallene at du kjører dobbeltkanal. For å teste i praksis, kan du f.eks ta ut den ene brikken. Da skal hastgheten synke til noe under 3200 MByte/s. (jeg tipper ca 3000MByte/s i ditt tilfelle) Lenke til kommentar
ericc2233 Skrevet 1. november 2003 Forfatter Del Skrevet 1. november 2003 ja jeg kjører nok i dual. takk for hjelpen alle sammen :-) Lenke til kommentar
