Stamina mode på Z3 - mottar fortsatt varsler!
Teria
Hva kan det komme av at jeg mottar varsler (fb messenger, FB, Snap ol) selv om Stamina-modus er på? Den eneste appen jeg har gjort unntak for i Stamina-modus er FitBit-appen. Skjermen er av, men likevel mottar jeg forskjellige varsler.
Vi kan jo starte med å høre med deg om hvilken telefon du har? ;)
Det er en Sony telefon av typen Xperia.
Battery STAMINA Mode builds on the same technology as Extended Standby Mode, which is available in some Sony smartphones released last year. Starting one minute after the screen has been turned off, data traffic is automatically blocked and background activities are prevented from waking up the system. And then when you turn on the screen, the activities will resume again instantly. And as the IP address for your phone is kept, you will immediately have network access. This all makes it possible to bring you notifications when you need them and have time to look at the screen, and not while the phone is tucked away.
When Battery STAMINA Mode is on, you will still receive phone calls, SMS text messages and MMS notifications at all times. The preinstalled Calendar app and Alarm notifications will also work as normal, while the LED will only illuminate to indicate low battery.
http://developer.sonymobile.com/2013/04/03/how-sonys-battery-stamina-mode-works/
Queue background data
Another new and important power management feature is the Queue background data* functionality, which minimises the number of network connection attempts when the screen is off. By queuing and releasing all network requests at set intervals of 15 minutes, the time spent in the connected radio state is minimised and the battery life is increased. When Stamina Mode is enabled, the Queue background data will only queue the connections for white listed applications, since all other applications are already blocked from using network connections.
http://developer.sonymobile.com/2013/11/26/power-management-explained-sony-xperia-z1-and-xperia-z-ultra/
Endret av Thor.
