Q: Why does 3DMark2001 SE inform me that I haven't run a def
leste hos Madonion...her har jeg Formatert og lastet 2001se flere ganger også er alt rett allikevel GRRRRRRRR........
Fra Madonions 2k1/se FAQA: Our bad! That small issue slipped thru our QA tests, and we are very sorry for that. You get that text eventhough you have benchmarked using the exact default settings. If you want to make sure that you are using deafult settings, they need to be as following:
Resolution: 1024x768
Color Depth: 32bit
Antialiasing: None
Frame Buffer: Double
Texture Format: Compressed
Z-Buffer Depth: 24bit or 32bit
Rendering Pipeline: Any
jeje null more Foramtering av en install som virker yuk yuk
