Koble sammen router?
Hei har 2 link sys routere , lurer på om det går ann og koble de sammen ? (tenker på når vi ska på LAN med kompiser osv ) .
Det er 1 wan port , 4 standar porter , 1 uplink port. De er helt identiske.
Så noen som vet om det går ann ? :-)
Ja ,
men hvorfor vil du benytte to rutere ?
Skal du ha flere separate nett ?
"... the Router?s LAN ports are all full and you still have PCs and/or devices to
connect, connect a hub or a switch to the Router using an Ethernet cable.
To do so, use the Router?s Uplink port to connect to a standard port on a hub
or switch. This leaves you with new, open ports on the hub or switch, to which
you can add more PCs and/or network devices.
If you have a PC/device connected to the port right next to the Uplink port (on
the 3- and 4-Port Routers), disconnect that PC/device and plug it into an open
port on the new hub or switch.
Since the Uplink port shares internal wiring with the port right next to it, you
can only use one of these two ports at a time; these ports are called shared
ports.
If your new hub or switch also has an Uplink port, it too can be uplinked when
you run out of ports, and so on."
Så sant begge rutere har forskjellig LAN IP ser jeg ingen grunn til at du ikke skal kunne koble LAN siden av to Multiport rutere via en Crossover kabel. Den ene ruter vil ha WAN disconnected og fungere som en 4 port svitsj.
