Shadowxx Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 (endret) Heij lurer på om dette går å spilles med: Dali: Blue 6006 Specifications Product Series DISCONTINUED SERIES Speaker Type Front Frequency Range (+/-3 dB) [Hz] 39 - 25,000 Sensitivity (2,83 V/1 m) [dB] 91.5 Nominal Impedance [Ω] 4 Maximum SPL [dB] 112 Recommended Amplifier Power [W] 30 - 150 Crossover Frequency [Hz] 3,000 High Frequency Driver 1 x 1" Soft Textile Dome Low Frequency Driver 3 x 6.5" Paper Fibre Cone Enclosure Type Bass Reflex Bass Reflex Tuning Frequency [Hz] 43.0 Recommended Placement Floor Recommended Distance From Wall [cm] 10 - 100 Dimensions (HxWxD) [mm] 97 x 21.5 x 34.2 Weight [kg] 18.5 og DENON S.L.D.C DRA-1000: Continuous Power Output: 90W + 90W (4 ohms, 1kHz) Power: 10Hz -40 kHz (T.H.D. 0.15% Both chan driveb into 8 ohms) T.H.D.: (-3dB at raed ooutput 8 ohms Total harmonic distortion Freqyency Response CD out-put): 20Hz~50kHz +- 1.5 (at 1w) General power consumpion 190w powver oulet swiched 100w ps: hvor er det billige speks til høytaler Endret 22. oktober 2014 av Shadowxx Lenke til kommentar
Janbanan123 Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 Heij lurer på om dette går å spilles med: Dali: Blue 6006 Specifications Product Series DISCONTINUED SERIES Speaker Type Front Frequency Range (+/-3 dB) [Hz] 39 - 25,000 Sensitivity (2,83 V/1 m) [dB] 91.5 Nominal Impedance [Ω] 4 Maximum SPL [dB] 112 Recommended Amplifier Power [W] 30 - 150 Crossover Frequency [Hz] 3,000 High Frequency Driver 1 x 1" Soft Textile Dome Low Frequency Driver 3 x 6.5" Paper Fibre Cone Enclosure Type Bass Reflex Bass Reflex Tuning Frequency [Hz] 43.0 Recommended Placement Floor Recommended Distance From Wall [cm] 10 - 100 Dimensions (HxWxD) [mm] 97 x 21.5 x 34.2 Weight [kg] 18.5 og DENON S.L.D.C DRA-1000: Continuous Power Output: 90W + 90W (4 ohms, 1kHz) Power: 10Hz -40 kHz (T.H.D. 0.15% Both chan driveb into 8 ohms) T.H.D.: (-3dB at raed ooutput 8 ohms Total harmonic distortion Freqyency Response CD out-put): 20Hz~50kHz +- 1.5 (at 1w) General power consumpion 190w powver oulet swiched 100w ps: hvor er det billige speks til høytaler sjekk ut Dynavoice hos www.surround.no hvis du vil ha billige høyttalere Lenke til kommentar
Pop Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 Hva er det du egentlig spør om her? Om du spør om dette vil låte optimalt med tanke på hva høyttalerne kan gi er nok svaret nei. Lenke til kommentar
k-orm Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 Ja du kan du kople Dali Blue 6006 til Denon DRA-1000. Jeg luer også på hva du egentlig spør om... Janbanan123: Kan du være så snill å redigere innleggget dit og slette sitatet av Shadowxx. Ingen grunn til å sitere hele førsteinlegget. Vi greier å få det med oss det trådstarter skriver uten at du gjentar det. Lenke til kommentar
Shadowxx Skrevet 22. oktober 2014 Forfatter Rapporter Del Skrevet 22. oktober 2014 (endret) jeg har begge deler og lure på om eg kan spille uten og sprenge høyttalerne. er redd at forsterker er for kraftig. og om eg skal kjøre a+b eller bare a? Endret 22. oktober 2014 av Shadowxx Lenke til kommentar
Pop Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 jeg har begge deler og lure på om eg kan spille uten og sprenge høyttalerne. er redd at forsterker er for kraftig. og om eg skal kjøre a+b eller bare a? Om du skal ødelegge høyttalerne med den forsterkeren er det fordi den begynner å klippe, som kan ødelegge membranfestene i høyttaleren. Mao fordi forsterkeren ikke leverer nok kontroll, eller er kraftig nok. Lenke til kommentar
k-orm Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 For høy forsterkereffekt er stort sett aldri et problem. Det er for svake forsterkere som "sprenger" høytalere. som kan ødelegge membranfestene i høyttaleren.Feil. Klipping fører til overoppheting av talespolen, så den kan brenne av. (Skjer som oftest på diskanter p.g.a tynn spoletråd). Lenke til kommentar
Pop Skrevet 22. oktober 2014 Rapporter Del Skrevet 22. oktober 2014 Feil. Klipping fører til overoppheting av talespolen, så den kan brenne av. (Skjer som oftest på diskanter p.g.a tynn spoletråd). Selvsagt, jeg hadde nok tankene et annet sted da jeg skrev... Nå blir for så vidt konsekvensen noe av det samme, siden spolen kan brennes såpass at membranen ikke kan bevege seg lenger. Cluet er ihvertfall, for liten forsterker er ille, for kraftig skal mye til for å ødelegge høyttaleren. Lenke til kommentar
Shadowxx Skrevet 22. oktober 2014 Forfatter Rapporter Del Skrevet 22. oktober 2014 Da er eg så si trygg? hvor høyt kan eg sku på volumet ? Lenke til kommentar
Pop Skrevet 23. oktober 2014 Rapporter Del Skrevet 23. oktober 2014 Eh..... når lyden blir ubehagelig er forsterkeren utenfor comfort-sonen og du bør gå litt ned. Ingen fasitsvar. Man vil høre om den klipper og forhåpentligvis er promillen ikke høyere enn at man reagerer før det... Lenke til kommentar
