Overklokk nForce2 fra Windws!
endre84
NVIDIA System Utility
Version: 1.0
File Size: 5 MB
Release Date: October 27, 2003
Overview:
NVIDIA® System Utility is the ultimate utility for accessing, monitoring, and adjusting your system components, including temperature and voltages with clear, user-friendly control panels. Overclock your system for highest performance or underclock it for near silent operation. All changes are performed within the Microsoft® Windows® interface – enabling full functionality without the need to make changes in the BIOS and reboot your system.
Release Notes:
This is the initial release of the NVIDIA System Utility.
Supported products:
NVIDIA nForce™2 Ultra 400
NVIDIA nForce2 400
NVIDIA nForce3 Pro 150
NVIDIA nForce3 150
Supported operating systems for this release:
Windows XP
Windows 2000
Windows ME
Windows 98SE
Best when run at 1024x768 16-bit color
Products Supported
Full product functionality is only available on the products below. Check www.nvidia.com/motherboards periodically for updated vendor support of this utility.
NVIDIA nForce2:
ASUS A7N8X-E
Biostar M7NCG
Epox EP-8RDA+
Epox EP-8RDA3+
ABIT NF7-S
NVIDIA nForce 3:
Gigabyte K8NNXP
Shuttle AN50
NOTE: Some NVIDIA nForce products will require you to update your BIOS to enable functionality with the NVIDIA System Utility.
Last ned her:
http://www.nvidia.com/object/sysutility_1.0.html
