Blir stadig disconnecta fra Zyxel-ruteren
Hei.
Det her skjer altså noen ganger med små rom imellom og det er noen dager som jeg aldri mister nettet her. Hva er dette for noe tull? Hvorfor kan det ikke være stabilt?Kan ikke bruke kabel, så må forholde meg til WI-FI...
Ruteren som jeg er tilkoblet er rett over meg i etasjen over.
Jeg bruker en Zyxel P-2812HNU-F3 ruter.
Kan poste system-logen tatt fra modemet som jeg logget innpå her:
Oct 1 00:58:11 info 0:Tx Inform, evt=0x24, rty=5
9 Oct 1 00:58:12 info 0:Rx InformResponse
10 Oct 1 00:58:12 info 0:Tx EmptyPost
11 Oct 1 00:58:12 info 0:Rx SetParameterValues
12 Oct 1 00:58:12 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
13 Oct 1 00:58:13 info 0:Rx SetParameterValues
14 Oct 1 02:11:10 info WAN Physical Link Down
15 Oct 1 02:11:51 info HTTP Login Successfully from IP:10.0.0.78
16 Oct 1 02:12:11 info WAN Physical Link Up. Upstream 476 kbps Downstream 4220 kbps, DSL Type is ADSL_2plus
17 Oct 1 02:12:25 info sId[0]:SSL initialtion
18 Oct 1 02:12:25 info 0:Tx Inform, evt=0x20, rty=0
19 Oct 1 02:12:26 info 0:Rx InformResponse
20 Oct 1 02:12:26 info 0:Tx EmptyPost
21 Oct 1 02:12:26 info 0:Rx SetParameterValues
22 Oct 1 02:12:26 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
23 Oct 1 02:12:27 info 0:Rx SetParameterValues
24 Oct 1 03:18:13 info sId[0]:SSL initialtion
25 Oct 1 03:18:13 info 0:Tx Inform, evt=0x8, rty=0
26 Oct 1 03:18:14 info 0:Rx InformResponse
27 Oct 1 03:18:14 info 0:Tx EmptyPost
28 Oct 1 03:18:14 info 0:Rx SetParameterValues
29 Oct 1 03:18:14 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
30 Oct 1 03:18:15 info 0:Rx SetParameterValues
31 Oct 1 04:50:29 info WAN Physical Link Down
32 Oct 1 04:51:30 info WAN Physical Link Up. Upstream 476 kbps Downstream 4220 kbps, DSL Type is ADSL_2plus
33 Oct 1 04:51:45 info sId[0]:SSL initialtion
34 Oct 1 04:51:45 info 0:Tx Inform, evt=0x20, rty=0
35 Oct 1 04:51:46 info 0:Rx InformResponse
36 Oct 1 04:51:46 info 0:Tx EmptyPost
37 Oct 1 04:51:46 info 0:Rx SetParameterValues
38 Oct 1 04:51:46 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
39 Oct 1 04:51:47 info 0:Rx SetParameterValues
40 Oct 1 05:40:28 info WAN Physical Link Down
41 Oct 1 05:41:29 info WAN Physical Link Up. Upstream 476 kbps Downstream 4220 kbps, DSL Type is ADSL_2plus
42 Oct 1 05:41:43 info sId[0]:SSL initialtion
43 Oct 1 05:41:43 info 0:Tx Inform, evt=0x20, rty=0
44 Oct 1 05:41:44 info 0:Rx InformResponse
45 Oct 1 05:41:44 info 0:Tx EmptyPost
46 Oct 1 05:41:44 info 0:Rx SetParameterValues
47 Oct 1 05:41:44 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
48 Oct 1 05:41:45 info 0:Rx SetParameterValues
49 Oct 1 23:16:06 info WAN Physical Link Down
50 Oct 1 23:17:07 info WAN Physical Link Up. Upstream 476 kbps Downstream 4220 kbps, DSL Type is ADSL_2plus
51 Oct 1 23:17:22 info sId[0]:SSL initialtion
52 Oct 1 23:17:22 info 0:Tx Inform, evt=0x20, rty=0
53 Oct 1 23:17:23 info 0:Rx InformResponse
54 Oct 1 23:17:23 info 0:Tx EmptyPost
55 Oct 1 23:17:23 info 0:Rx SetParameterValues
56 Oct 1 23:17:23 info 0:Tx SetParameterValuesResponse [last message repeated 1 times in 1 seconds]
57 Oct 1 23:17:24 info 0:Rx SetParameterValues
58 Oct 1 23:19:07 info HTTP Login Successfully from IP:10.0.0.78
59 Oct 1 23:25:21 info HTTP Login Successfully from IP:10.0.0.78
Om dette er til hjelp.
Noen snille sjeler som kan være behjelpelig? :)
Endret av VaporHead
Så det først nå, men lar det jeg skrev tidligere stå. Var det utfall fra det trådløse nettet eller er det selve modemt?
Har du sjekket for interferens (forstyrrelser)? Det kan være mange ting som kan forårsaker dette.
Har skrevet om dette tidligere, som du kan sjekke. Nevner inSSIDer som et godt gratis program, se bort i fra dette siden de har gått over til å ta betalt.
https://www.diskusjon.no/index.php?showtopic=1513245&hl=
https://www.diskusjon.no/index.php?showtopic=1575573&hl=
Om du har godt strømnett kan du benytte deg av powerline, f.eks:
https://www.komplett.no/tp-link-tl-pa411-powerline-starter-kit/764471
Endret av cronbach alpha
Takk for svar :)
Skal sjekket det ut og kan komme tilbake om det har blitt noe bedre.
Men ang. den ruteren der så er det ikke bare jeg som opplever random disconnects. Flere som har hatt det samme. Skikkelig dårlig telenor-ruter som du får da modemet blir montert.
Den takler ikke heller alt for mange enheter som er tilkoblet samtidig. Men det er ikke hovedgrunnen. Har mistet nettet flere ganger selv om det er bare PCen som er på nettverk.
Men er dette noe jeg bare kan fikse ved å logge inn på modemet og konfigurere noe? Eller er det noe som rett og slett blokkerer signalene? Fins det ikke noe gratisprogram som er nogenlunde som InSSIDer?
edit: jeg vet ikke helt hvordan det er ang. interferens
Endret av VaporHead
Takk for svar :)
Har en Zyxel P-2812HNU-F3 liggende, og det har fungert fint under de forholdene jeg har testet det, men det kan kan være unntak. Jeg har ikke benyttet og testet det så mye, så skal ikke utale meg så mye om akkurat dette modemet.
"Fins det ikke noe gratisprogram som er nogenlunde som InSSIDer?"
Jeg har programmet, så har ikke sett etter noen alternativer. Men det er mange av de nye modemene som har denne funksjonen integrert, jeg husker ikke om Zyxel P-2812HNU-F3 har dette og får ikke sjekket det no da mitt er pakket ned i en eske av mange esker:P Men du finner sikkert noen alternativer om du leter på nettet. Er litt tilbakeholden med å henvise til program jeg ikke har benyttet selv.
"Men er dette noe jeg bare kan fikse ved å logge inn på modemet og konfigurere noe?"
Når det kommer til justeringer av kanalfrekvenser er dette noe du kan gjøre med å logge på modemet. Du kan også høre med Telenor om de har fått en ny firmware til Zyxel P-2812HNU-F3.
"Den takler ikke heller alt for mange enheter som er tilkoblet samtidig"
Modemet skal takle 16 klienter samtidig.
Gjest Slettet-fsaSP0zV
Google litt, så finner du en eldre versjon av inSSIDer som er gratis. Dersom du har Androidnettbrett eller -mobil, kan du bruke Netgear sin gratis-app i Play.
Oppdatert programvare til router finner du her: http://stup.telenor.net/zyxel-p2812hnuf3/ - nyeste versjon er 17. Oppdater over kabel, ikke WiFi. Ta en full reset etter oppdatering, og sett opp routermodem på nytt.
P2812 er egentlig en helt grei router. Er det kun på WiFi du blir disconnected, eller også på kablet? Gjetter på det som er sagt over, forstyrrelser fra andre nett. Du kan ev. begrense til 802.11 g, da bruker den smalere frekvensområde, og burde være mindre utsatt for forstyrrelser.
Endret av Slettet-fsaSP0zV
Det er ikke din router? Det er ganske vesentlig å oppgi? Om du skal oppdateren den med kabel så er det kun midlertidig. Har du laptop så kan jo du sitte ganske nærme den.
Et annet og mer anbefalt alternativ er å bridge modemet fra Telenor og bruke en skikkelig router. Det er ikke ditt, men siden du antageligvis får internett gjennom leie(?) vil det ikke være urimelig å kreve at det er stabilt.
Skal du ha et alternativ til inSSIDer på android kan du bruke wifi anyalyzer.
