SimonOlsen Skrevet 4. september 2014 Del Skrevet 4. september 2014 Hei! lurte på om noen kan hjelpe meg med problemet mitt jeg har beskrevet her: http://www.computerforum.com/230466-synaptics-driver.html Dersom du ikke vil klikke deg inn på linken kommer et sammendrag her: Hello! I recently bought a laptop from multicom.no. It was delivered without OS or drivers, so I installed everything myself. Now, everything is working but multi touch features on the touchpad. I know that the touchpad supports it. I have downloaded the newest synaptics driver, but it still only support single touch. When I install the synaptics driver it says "ready to use" but none of the software actually gets installed. I dont get the synaptics gesture suite or anything... However, when I uninstall the driver it stays unfunctional untill I reinstall the driver... Any ideas? Running Win7 ---------------------------------------------- What is the make and model of laptop or did you have them custom build it?I'm not sure if synaptics supports all the touchpads out there. I know there is Alps and one more but I can't remember the name. Ok, just found out the major manufacturers are.Alps Electric CorporationCirque CorporationSynapticsElanTechElantech was the one I was thinking of. You may have to install the Alps or Elantech driver. ------------------------------------------ This is the model: http://www.multicom.no/Xishan-W355S-...-p/c/p10629134They say that the synaptics driver should work, and that the touchpad supports multitouch... Problem is when I install the synaptics driver, I get no of the software, so I cant configure anything either, and no synaptics program shows up in add/remove software... ------------------------------------------------------ When you install the synaptics software does it say the install completed? When you reboot is there a synaptics icon down in the systray by the clock? ------------------------------------ No thats the weird part. The installation goes way too fast to be real, but when it is finished it says installation complete and ready to use. After the reboot there are no synaptics icon on the system tray by the clock, no synaptics software installed, but the touchpad works with single touch but no multi touch... ------------------------------------------- I wonder if I could extract the inf file and all dll's and install manually? What is the link to the driver? -------------------------------------- This is the link to the page where I downloaded the driver: http://www.synaptics.com/en/drivers.php This is the direct download link to the exact driver:http://drivers.synaptics.com/Synapti...4_Acme_Inc.zipNow, I did actually try to install an older version of the driver, then it took longer to install, so atleast something happened during this installation, but still no multitouch functions. Are there maybe a way for me to manually go in and delete every synaptics / touchpad driver/dll and everything remotely connected to the synaptics driver / touchpad and do a completely clean install of the driver? Iva had some programs installed (uninstalled now) that maybe can have something to do with the case... : Razer SynapseTwo Finger Scroll (https://code.google.com/p/two-finger...downloads/list)There is also a light above the touchpad that used to be on when the touchpad was on, and off when it was switched off. Now the light is off @ all times. Lenke til kommentar
