G-Oh-O Skrevet 31. august 2014 Del Skrevet 31. august 2014 (endret) Jeg kjøpte en Alfa awus036h USB nettverksadapter sak, det fulgte med en cd med drivere for linux men installasjonsveiledningen, jeg har installert diverse enkle ting i linux, men denne ble en smule komplisert for min smak. Dette var veiledningen: 1> $tar -xvzf DPB_RT2870_Linux_STA_x.x.x.x.tgz go to "./DPB_RT2870_Linux_STA_x.x.x.x" directory. 2> In Makefile set the "MODE = STA" in Makefile and chose the TARGET to Linux by set "TARGET = LINUX" define the linux kernel source include file path LINUX_SRC modify to meet your need. 3> In os/linux/config.mk define the GCC and LD of the target machine define the compiler flags CFLAGS modify to meet your need. ** Build for being controlled by NetworkManager or wpa_supplicant wext functions Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y'. => #>cd wpa_supplicant-x.x => #>./wpa_supplicant -Dwext -ira0 -c wpa_supplicant.conf -d ** Build for being controlled by WpaSupplicant with Ralink Driver Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n'. => #>cd wpa_supplicant-0.5.7 => #>./wpa_supplicant -Dralink -ira0 -c wpa_supplicant.conf -d 4> $make # compile driver source code # To fix "error: too few arguments to function ¡¥iwe_stream_add_event" => $patch -i os/linux/sta_ioctl.c.patch os/linux/sta_ioctl.c 5> $cp RT2870STA.dat /etc/Wireless/RT2870STA/RT2870STA.dat 6> load driver, go to "os/linux/" directory. #[kernel 2.4] # $/sbin/insmod rt2870sta.o # $/sbin/ifconfig ra0 inet YOUR_IP up #[kernel 2.6] # $/sbin/insmod rt2870sta.ko # $/sbin/ifconfig ra0 inet YOUR_IP up 7> unload driver $/sbin/ifconfig ra0 down $/sbin/rmmod rt2870sta Istedenfor prøvde jeg å google etter enklere løsninger, jeg fant en på denne siden: http://www.alfa.com.tw/press_c_show.php?sn=5 Men når jeg blir root og skriver "prepare-kernel-sources" så får jeg bare "bash: prepare-kernel-sources: command not found" så da stopper det litt opp. Noen tips? Endret 31. august 2014 av G-Oh-O Lenke til kommentar
siDDis Skrevet 31. august 2014 Del Skrevet 31. august 2014 Hei! Om driveren ikke er innebygd i Linux, så er rådet mitt soleklar å la være. I Linux skal ting fungere uten å installere drivere. Lenke til kommentar
AM2petterk Skrevet 6. september 2014 Del Skrevet 6. september 2014 Denne adapteren skal fungere out of the box med Linux (RTL8187). Du trenger altså ikke å installere noen drivere. https://bbs.archlinux.org/viewtopic.php?id=61226 Lenke til kommentar
