Geforce GTX 9xx Tråden
Strixen stopper jo viftene under ~60'C...
Men det gjør vel noen andre kort med tredjepartskjøler også?
Det mange ikkje tenker på er at det ikkje er alltid det er skjermkortvifta som bråker mest i datamaskinen. :p
Eller at PCen bråker mest i rommet. Ofte har mange en NAS, UPS el. stående 24/7 med en billig vifte.
Endret av Theo343
Förbannade powerlimit!!!!
Får 125% på 1550/4005 i heaven, men når aldrig över 42 grader vad jag än gör.
Är helt säker på att det finns så mycket mer i detta kort om man bara kunde utan att hårdmodda kortet.
Hvilken bios har du?
Here is a modded BIOS with 425W power target:
- Based on the EVGA SC BIOS, no boost limit
- 350W default power target at 100%
- 425W max power target at 121%
Use this BIOS if you want to avoid throttling. For flashing instructions see Page 1 of the Titan-X owner's club. thumb.gif
Be sure to use the nvflash utility posted there as well.
Last but not least: DO THIS AT YOUR OWN RISK.
980Ti-SC-425.zip 152k .zip file
Quote:
Here is a modded BIOS with 425W power target AND 1.281v when under load:
1.281v under load
THIS BIOS IS INTENDED FOR WATERCOOLING/BENCHING USE. Not recommended if you're on the stock air cooler.
Use PX or AB to dial in your +core and power target percentage. There is no need to adjust the voltage.
980Ti-SC-425-1281mv.zip 152k .zip file
Quote:
980 Ti MAXAIR BIOS for reference cards
This BIOS is intended for those who want to max out their OC on the stock cooler.
- Based on EVGA 980 Ti SC reference BIOS
- 1.250v at load
- 425W at 121% - 350W at 100%
To use this simply set +core, +mem, and power target in PX or AB. No need to touch voltage; the BIOS will provide 1.250v at load.
980Ti-SC-MaxAir.zip 152k .zip file
Quote:
Quote:
Just wanted to post my last and final bios after doing a lot of work to fix the bugs reported with my previous bios. So here we go.
Power Target: 375W
Voltage: 1.23v @ load. voltage slider in afterburner/Precision X does not do anything at all
Stock Boost Clock: 1291mhz (will not boost to 1493mhz like my earlier bios)
Have tested for the past 6 hours to make sure completely stable. please give it a try and share results. Thanks!
motivmanbiosfinal1230.zip 152k .zip file
I will really appreciate if OP will paste this to the front page and replace my previous bios. Thanks Again.
Endret av Nizzen
vet det er feil tråd... men er mer liv i denne enn titanX tråden.
Har fått på ocn til å lage en bios til meg, men har et spm når kortene er i idle..
så har kort 1 en core clock på 1215 mhz mens memory ligger på 4000mhz.
kort 2 og 3 ligger 135/405
er dette vanlig?
Om du har 144hz skjerm, så ja. :)
Brukte du han jeg sendte deg til?
  Yes , har det ja. Fint å vite :-) Yes, brukte han ja. Så nå har jeg en fin 1500/8000 oc :-)
Du kjører ikke tilfeldigvis en 1440p skjerm på 144 hz?
det gjør jeg. Takk for svar :-)
