are47 Skrevet 26. oktober 2003 Del Skrevet 26. oktober 2003 Hvordan får jeg laget hotkeys i VB 6.0 vet dette med &Avslutt' men jeg mener at når du trykker inn ctrl-tab så skal frmeks1.show vbmodal hvordan gjør jeg det? noe med keyascii og gjøre... hva er keyascii? Lenke til kommentar
aadnk Skrevet 31. oktober 2003 Del Skrevet 31. oktober 2003 Tja, vel, det er mulig. Lim dette inn i en form: Private Declare Function RegisterHotKey Lib "user32" (ByVal hWnd As Long, ByVal id As Long, ByVal fsModifiers As Long, ByVal vk As Long) As Long Private Declare Function UnregisterHotKey Lib "user32" (ByVal hWnd As Long, ByVal id As Long) As Long Private Declare Function PeekMessage Lib "user32" Alias "PeekMessageA" (lpMsg As Msg, ByVal hWnd As Long, ByVal wMsgFilterMin As Long, ByVal wMsgFilterMax As Long, ByVal wRemoveMsg As Long) As Long Private Declare Function WaitMessage Lib "user32" () As Long Private Const MOD_ALT = &H1 Private Const MOD_CONTROL = &H2 Private Const MOD_SHIFT = &H4 Private Const PM_REMOVE = &H1 Private Const WM_HOTKEY = &H312 Private Type POINTAPI x As Long y As Long End Type Private Type Msg hWnd As Long Message As Long wParam As Long lParam As Long time As Long pt As POINTAPI End Type Private bCancel As Boolean Private Sub ProcessMessages() Dim Message As Msg 'loop until bCancel is set to True Do While Not bCancel 'wait for a message WaitMessage 'check if it's a HOTKEY-message If PeekMessage(Message, Me.hWnd, WM_HOTKEY, WM_HOTKEY, PM_REMOVE) Then 'minimize the form Me.Show End If 'let the operating system process other events DoEvents Loop End Sub Private Sub Form_Load() 'KPD-Team 2000 'URL: http://www.allapi.net/ 'E-Mail: [email protected] Dim ret As Long bCancel = False 'register the Ctrl-F hotkey ret = RegisterHotKey(Me.hWnd, &HBFFF&, MOD_CONTROL, vbKeyTab) 'show some information MsgBox "Press Ctrl-tab to show the form" 'process the Hotkey messages ProcessMessages End Sub Private Sub Form_Unload(Cancel As Integer) bCancel = True 'unregister hotkey UnregisterHotKey Me.hWnd, &HBFFF& End Sub Lenke til kommentar
Rep Skrevet 1. november 2003 Del Skrevet 1. november 2003 Det er mulig å få til dette på en enklere måte uten API calls. En idé som bare spratt opp for meg, helt utrolig på denne tiden av døgnet Dim CTRL_NEDE As Boolean Private Sub Form_Load() Form1.KeyPreview = True End Sub Private Sub Form_KeyDown(KeyCode As Integer, Shift As Integer) If KeyCode = vbKeyControl Then CTRL_NEDE = True ElseIf KeyCode = vbKeyTab And CTRL_NEDE Then Form2.Show vbModal CTRL_NEDE = False End If End Sub Private Sub Form_KeyUp(KeyCode As Integer, Shift As Integer) If KeyCode = vbKeyControl Then CTRL_NEDE = False End If End Sub ASCII er tallkodene for hver bokstav/tast på tastaturet se mer her http://www.asciitable.com/ Lenke til kommentar
aadnk Skrevet 1. november 2003 Del Skrevet 1. november 2003 Joda, det er selvsakt mulig uten API, men jeg fikk så lyst å vise en ekte hotkey kode. Koden registrerer knappekombinasjonen Ctrl-tab og programmet oppfatter når den presses ned. Lenke til kommentar
