Cities: Skylines - GamesCom trailer
Nytt spill på vei fra Colossal Order, som står bak to Cities in Motion.
Ser ut som den bruker samme spillmotor (Unity), samt generelt mye av den samme motorikken i forhold til hvordan veier, nabolag, terreng etc. er bygd opp.
Blir spennende å se hvordan dette blir i forhold til ressurshåndtering, politikk etc. :D
Redigert: litt mer kjøtt på beina..
Singleplayer: Yes
Multiplayer: No
Controller: No
The Sky is no limit!
Inhabit a world where you define the rules. Cities: Skylines invites you to create the city of your dreams in a sprawling landscape dominated by cloud hugging structures and jaw dropping architectural marvels.
Developed by Colossal Order, Cities: Skylines offers sprawling landscapes and maps with endless sandbox gameplay and new ways to expand your city. Key to progression is the ability to influence your city’s policy by incorporating taxation into districts. All this including the ability to mod the game to suit your play style makes this the definitive city building simulation.
You’re only limited by your imagination, so take control and reach for the sky!
Main features:
  • City policies: Set policies to guide how the city and districts develop over the course of your playthrough.
  • City districts: Personalize city districts with names of your choice for variety and personality.
  • Road building and zoning
  • Unlock buildings and services
  • Taxation: Fine-tuning the city budget and services and setting tax rates to different residential, commercial and industrial levels and controlling what kind of areas are more likely to spawn in the zoned areas
  • Public transportation: Build transport networks throughout the city with buses and metros
  • Outside connections: Make industry and commercial districts flourish with new customers in the neighboring cities
  • Wonders: the ultimate end-game content that the players strive towards
  • Huge maps: Unlock new map tiles with unique possibilities to expand the city
  • Water flow simulation: Add new challenges to water services.
  • Polished visual style and core gameplay
  • Modding tools: Built in feature designed to encourage creative pursuits.
Screenshots kan sees på nettsiden deres.
https://www.paradoxplaza.com/cities-skylines
Endret av OlaHaldor
Dette har jeg klokketro på!
Motoren i Cities In Motion 2 er helt fantastisk, og det å lage avanserte kollektivløsninger med opphøyde og nedfelte veier og spor i alle retninger er for å si det rett ut: jævlig moro! Og det er nesten mer morsomt å bygge by i CIM2 tross de få funksjonene man har til rådighet for det, enn det er å bygge by i SimCity!
Hvis dette blir CIM2 med fokus på bybygging i tillegg, og alt tilsier at det er akkurat det dette spillet blir, så blir der tidenes simulator for min del, og den endelige og verdige arvtager etter Sim City 4.Takk for nyheten OlaHaldor!
Dette gleder jeg meg til!
CitiesXL var konge, helt til det bugget ut pga minne og alt annet feil. Sim City baiset på leggen fra start og kom aldri i mål.
Cities in Motion2 har jeg brukt mye tid på, og ser frem til at de lager et skikkelig by spill!
Fin demo! Allerede i alpha!
