Siste Ordet 3
Ueland
Reglene er enkel.
Orker ikke å skrive de så jeg quoter:
1. Description
Snooker may be played by two or more players, either independently or as sides. The game can be summarised as follows:
(a) Each player uses the same White cue-ball and there are twenty-one object balls - fifteen Reds each valued 1, and six colours: Yellow valued 2, Green 3, Brown 4, Blue 5, Pink 6 and Black 7.
(b) Scoring strokes in a player's turn are made by potting Reds and colours alternately until all the Reds are off the table and then the colours in the ascending order of their value.
© Points awarded for scoring strokes are added to the score of the striker.
(d) Penalty points from fouls are added to the opponent's score.
(e) A tactic employed at any time during a frame is to leave the cue-ball behind a ball not on such that it is snookered for the next player. If a player or side is more points behind than are available from the balls left on the table, then the laying of snookers in the hope of gaining points from fouls becomes most important.
(f) The winner of a frame is the player or side
(i) making the highest score,
(ii) to whom the frame is conceded, or
(iii) to whom it is awarded under Section 3 Rule 14© or Section 4 Rule 2.
(g) The winner of a game is the player or side
(i) winning most, or the required number of frames
(ii) making the greatest total where aggregate points are relevant, or
(iii) to whom the game is awarded under Section 4 Rule 2.
(h) The winner of a match is the player or side winning most games or, aggregate points are relevant, with the greatest total.
Snooker er digg IMO.
Fra det ene til det andre... Jeg bestilte noe stuff til PCen fra USA her om dagen, og fikk pakken i går. Selvfølgelig manglet det noe som i følge pakkeseddelen skulle være der. :roll: Enten så har de glemt og legge det i esken, noe som er litt vanskelig å bevise... Eller så har tollvesenet stjålet det, som er ennå vanskeligere å bevise :grumpy:
Hvis du ikke vet hva du skal velge og ikke har så ekstremt ivrig på skola at det gjør noe så blir du hengende etter...det er bare slikt. ALT for mange av mine kamerater som har gjort samme tabben desverre, og meg da..
Poenget er vel mer det at ungdommsskolen gikk lekende lett, kom ut med toppers karakterer osv. Men nå er jeg stuck på allemen på en skole der det kreves så sinnsykt høyt nivå, og jeg er dritlei av å ikke leve opp til forventningene. Angrer noe jævlig på at jeg ikke tok media og komm.
Endret av HalTan
btw: jeg HATER excell...
EDIT: Og økonomilærern min... Her om dagen klarte hun å mose tommelen min i en overhead, fikk svinvondt. Så lo hun av det etterpå, mens jeg hoppet rund og sugde på tommern, hadde vondt i 2 dager liksom.
så, jeg HATER økonomilærern min.
Endret av HalTan
Yeah, jeg vet hva du snakker om. Begikk samme tabben selv.
Excel er faktisk veldig kjekt..Vi får lov til å bruke Excel 45 minutter på tentamen i matematikk ;) Skal btw ha Nynorsk tentamen imorgen...huff, det blir sugent!
Idag har jeg formatert og lagt inn windows 2000 igjen... Cleac..DIGG!
Også med litt ny hardware, så går det glimrende!
Excel er et stort, styggt, plagsommt regneark som kun er til for å plage elever på allemen og gi deres lærere enda flere grunner til å kjefte de ut fordi de ikke har giddet å lære seg hurtigtasten for "summer". Kort oppsummert.
:lol:
Noen tar vist etter GTF her ser jeg :mrgreen:
Gjest
