Hjelp!
Gjest medlem-30598
Gjest medlem-30598
Sorry vist dette er feil forum, men jeg valgte vertfall å poste det her.
Problemet er at pc`en min ikke vill virke lengre, når jeg starter opp får jeg følgende beskjed :
" A problem has been detected and Windows has been shut down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first tim you have seen this stop error screen, restart your computer. If this screen appears again, follow these steps :
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware ore software manufacturer for any windows updates you migt need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove ore disable components, restart yor computer, press F8 to select Advanced Startup Options, and then select safe mode.
Technical information:
*** STOP: 0x000000ED (0x81EF2900, 0xC0000006, 0x00000000, 0x00000000) "
Dette er altså det som skjer når maskina prøver å starte opp windows.
Vist noen her med litt mere peiling en meg kunne ha hjelpet meg ved å si hva jeg skal gjøre så hadde jeg vert veldig takknemlig!
Vist det betyr noe så er oppsettet mitt slik :
- AMD XP2500
- Sapphire Radeon 9800 Pro
- Abit NF-7s
- Twinmos 512 DDR-DIMM
- 80GB hardisk
- SB Live Value
Gjest
