nettverk "driver"
Gjest medlem-332567
Gjest medlem-332567
1. Install the “ethernet controller” first. This is the driver that allows you to connect to the internet. If it is missing, you will need to download it on a different computer that is connected to the internet, then transfer the driver to the formatted computer and install it. To locate this driver, go do your computer manufacturer’s website, then search your computer’s make/model. There should be a section of drivers you can download on the manufacturer website. Be sure to download the drivers for the operating system you are using. Look for the ethernet controller driver (sometimes called a network driver), then save it on a USB flash drive or external hard drive. Next go to your formatted computer and install the driver. If you are still seeing a yellow question mark in Device Manager next to ethernet controller after installing the driver, you have not located the correct one for your computer. Go back to the manufacturer website and try finding a different driver.
Det står at man skal laste ned fra der pcen er bygd, hvordan skal man laste ned det her hvis man har bygd pcen selv? hvordan skal man vite hvilken "ethernet controller" man skal laste ned
Post info om hovedkortet ditt, så finner man raskt driver til nettverkskortet.
Last så denne ned på en annen maskin f.eks til en minnepinne. Installer driveren på den nye maskinen din.
Alternativt følger det alltid med alle drivere du trenger med komponentene du bygde fra. På DVD'en til hovedkortet ditt er driveren til nettverkskortet.
