Huawei P7 tråden
http://www.3g.co.uk/tinyimages/Huawei/Ascend_P7_side_black.jpg
GENERAL
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 900 / 1900 / 2100
4G Network LTE 800 / 900 / 1800 / 2100 / 2600
SIM Micro-SIM
Announced 2014, May
Status Available. Released 2014, June
BODY
Dimensions 139.8 x 68.8 x 6.5 mm (5.50 x 2.71 x 0.26 in)
Weight 124 g (4.37 oz)
DISPLAY
Type IPS LCD capacitive touchscreen, 16M colors
Size 1080 x 1920 pixels, 5.0 inches (~441 ppi pixel density)
Multitouch Yes
Protection Corning Gorilla Glass 3
- Emotion UI 2.3
SOUND
Alert types Vibration, MP3 ringtones
Loudspeaker Yes
3.5mm jack Yes, check quality
- Dolby Digital Plus sound enhancement
MEMORY
Card slot microSD, up to 64 GB
Internal 16 GB, 2 GB RAM
DATA
GPRS Up to 60 kbps
EDGE Up to 236.8 kbps
Speed HSDPA, 42 Mbps; HSUPA, 5.76 Mbps; LTE, Cat4, 50 Mbps UL, 150 Mbps DL
WLAN Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
Bluetooth Yes, v4.0 with A2DP, LE
NFC Yes
USB Yes, microUSB v2.0, USB On-the-go
CAMERA
Primary 13 MP, 4160 x 3120 pixels, autofocus, LED flash, check quality
Features Geo-tagging, touch focus, face and smile detection, panorama, HDR
Video Yes, 1080p@30fps, check quality
Secondary Yes, 8 MP
FEATURES
OS Android OS, v4.4.2 (KitKat)
Chipset HiSilicon Kirin 910T
CPU Quad-core 1.8 GHz Cotex-A9
GPU Mali-450MP4
Sensors Accelerometer, proximity, compass
Messaging SMS(threaded view), MMS, Email, Push Mail, IM
Browser HTML5
Radio FM radio
GPS Yes, with A-GPS support and GLONASS
Java Yes, via Java MIDP emulator
Colors Black, white, pink
- SNS integration
- Active noise cancellation with dedicated mic
- XviD/MP4/H.263/H.264/WMV player
- MP3/eAAC+/WMA/WAV/Flac player
- Google Search, Maps, Gmail,
YouTube, Calendar, Google Talk
- Organizer
- Document viewer
- Photo viewer/editor
- Voice memo/dial/commands
- Predictive text input
BATTERY
Li-Po 2500 mAh battery
Stand-by (2G) / Up to 422 h (3G)
Talk time Up to 22 h (2G) / Up to 14 h (3G)
Endret av MobilNerd
Noen som har erfaring med denne? Selges meget billig på Lefdal med Champion189 fra Tele2. Ser jo meget lekker ut og virker jo som den har greie specs.
Tror dere at teamet rundt Cyanogenmod vil lage en versjon til denne?
Endret av MobilNerd
God pris! Er det noe minstefakturering i tillegg til de 189? Hadde også vært interessant å vite hva bruddgebyret ligger på....
Totalpris 12 måneder 2268,-
Å etter det jeg skjønner skal det som står der inneholde ALT som kan faktureres før bruk.
Var innom Lefdal idag. De mente at det ble minimumsdebitering i tillegg til oppgitt totalpris. Har du kjøpt?
Ved minste totalpris skal vel alle utgifter som tilkommer være med. Dette var jo en stor sak for en stund siden. Ja har bestilt. Virker som en ok telefon til 2300,- totalt, samt at man får en sykkel :-).
Endret av MobilNerd
Til info: Det er en minimums debitering på 49,- kroner. Dersom telefonen kjøpes med intensjonen om å få den billig men bruke ditt egent abonnement så vil det tilkomme ca. 600,- kroner i løpet av 12 mnd. altså 2868,-
Dette er uansett billig siden den koster 3790.- idag uten abo OG du får med en sykkel.
TIPS: Er dere klar over at dersom man ikke trenger minnekort kan den sloten brukes til ett ekstra SIM-kort?
Man kan altså bruke TO ulike nummer i telefonen :-)
Det var det jeg trodde ja. Er det egentlig helt etter boka? Oppgi en minste totalpris som det ikke er mulig å oppnå? I tillegg til at det ikke står noe i avisen om at det tilkommer en minstedebitering.
Vil ikke minste fakturering pr mnd gjelde først når avtalen går ut og du skal betale 0,- i måneden? Når du betaler 189,- i måneden vil du jo uansett komme over minste fakturering på 49,-. Slik har det ihvertfall fungert hos Telenor de gangene jeg har benyttet dem.
Kan begge numrene være aktive samtidig?
Har gått litt gjennom tester på nett. De aller fleste er positive. Men de som er negative er veldig negative. De som er negative er stort sett negativ til emotion ui, men denne kan vel byttes lettvint bort?
Jeg håper at det kommer offisiell Cyanogenmod til telefonen.
  • 1 måned senere...
Har var det lenge siden noen hadde skrevet :(
Har et par problemer, først så vil ikke Endomondo fungere som det skal.
Etter en stund så virker det bare som om den avslutter midt i sykkelturen. Jeg har ikke sett noe mønster i det.
Jeg har også kjøpt Supra øreproppene som skal fungere både med Android og iOS ifht fjernkontroll.
Når jeg går med telefonen i lomma er det derimot svært få funksjoner som virker. Spotify vises heller ikke på låseskjermen. Hvis jeg låser opp telefonen og viser Spotify på skjermen virker derimot kontrollen til øreproppene.
Hvordan kan jeg få Spotify på låseskjermen?
Jeg mistenker at dette ville løse problemet med fjernkontrollen.
